Question about HP Pavilion dv1000 Notebook
Need to replace usb ports dv1000
I have connection problems with USB ports on my DV 1000 & want to replace. Does anyone know how to? I think 2 of them reside on the motherboard, but one is on the other side of the laptop. I really need a schematic of this unit.
  • 4 Answers
If the problem is with the ports themselves, you may not be able to or be willing to resolder them. How about just adding a USB card to get by?
Posted on Jan 25, 2009
Can i charge my hp pavillion dv1000 from my desktop through a usb port?
NO! You will damage one or both computers. You really need to repair the laptop or ac adapter to correct the charging problem. The HP dv 1000 as well as the other HP entertainment laptops have had a lot of problems. Not charging just one of them. I would strongly suggest a professional repair of this laptop.
Apr 01, 2011 | Computers & Internet
I have a Panasonic NV-GS22 Camera and I don't know what wire I need to connect it into the computer. I think it is a fire wire but I don't know what port I need to put it into on my computer.
This type of camera usually downloads video over a Firewire (DV, IEEE1394) connection. Some mini-DV cameras have a USB connection but it is used only for stills.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card. If you have a MAC, you may already have a port.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. My Samsung mini-DV camera came with the correct lead. I did not need a driver, just some sort of video editing software that can accept input. Even Windows Movie Maker that ships with Windows will work.
Jan 22, 2011 | Panasonic NV-GS22 Mini DV Digital...
I am trying to connect my Sony DCR-TRV10E to my home computer via ilink-USB cable, but my computer does not recognize the Camcorder.... I guess this is due to missing drivers for Windows 7. Can anyone help...
USB and i.Link cables are not the same thing. What Sony call i.Link everyone else calls Firewire, DV or IEEE1394, and it is a different standard from USB with different connectors.
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection (if they have one) for stills and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file. If you are trying to use a USB cable for video download, then it won't work for this camera. The driver is not the problem, this model is not on the Sony list of cameras that will download video over USB.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. My camera came with the correct lead.
There is a Sony tutorial page for downloading at THIS LINK You will need to select Windows as the operating system, then Mini-DV as the camera type, then select the type of connection. As you will see, the USB option warns that it won't work with many Mini-DV cameras.
Jan 02, 2011 | Sony Handycam DCR-TRV10 Mini DV Digital...
How cain i connect my laptop Hp pavillion dv 1000 to TV
you can purchase a usb device with TV outputs. look on ebay or purchase one from your local PC retail shop.
Apr 16, 2010 | HP Pavilion dv1000 Notebook
USB Ports are not working
A USB device, such as a camera, scanner, or printer, loses its connection and stops working unexpectedly. The device may appear to work fine when Windows first starts up but later stops working. Use the steps in this document to resolve this issue. Disable power management on the USB hub To preserve power, Microsoft Window XP tries to disable USB when a device is not used. Under certain circumstances this function does not work and may cause USB devices to fail to respond when called. To resolve this issue, disable power management on the USB hub by doing the following:
  1. Click Start , and right-click My Computer .
  2. Click Properties , then click Hardware .
  3. Click Device Manager .
  4. Double-click the Universal Serial Bus Controllers branch to expand it.
  5. Right-click USB Root Hub , and then click Properties .
  6. Click Power Management .
  7. Deselect Allow the computer to turn off this device to save power .
  8. Repeat Steps 5 through 7 for each USB Root Hub.
  9. Click OK , and close Device Manager .
If this doesn't help download everesthome. Run the program click on the chipsets and google the northbridge for updates.
May 01, 2008 | HP Pavilion dv1000 Notebook
USB ports not working DV 1000
i need more details cuz i can not understand what the problem really is, is it with the hardware or software... please rewrite your problem
thank you for your corporation
Dec 16, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
I just fixed this problem on my dv1000. The problem I found was apparently the USB ports on lower right and left side only mounted on the mobo with light soldering and no soldering on the other side of mobo. Due to heat I guessed, they came loose. I opened the mobo (using guide from a pdf file on the net, sorry i forgot the exact guide but you can ask uncle google).
I took the mobo out and resolder those two ports with plenty of solder from the top surface only of the mobo as I unable to access the other side. Now they work again like charm.
The top right USB is different beast. It is on different card along with S-Video port and apparently in permanent damage.
Dec 06, 2007 | HP Pavilion dv1000 Notebook
DV Studio 3.1E-SE Download Request
1. The software is not required - if you have Windows Movie Maker that will work just as well.
2. It does require the DV (firewire) connection. USB connection creates a master-slave interface for "copy and pasting" or transferring low-frame video content (web-cam) or significantly compressed video w/ special drivers. This camcorder records digitally and requires a digital to digital peer-to-peer interface which the firewire connection allows for.
3. For those looking for Vista USB drivers - there are none from the manufacturer. Vista and XP have adequate native drivers for plug and play - camcorder should work just by plugging it in. If it's not recognizing, it could be a number of things:
-bent or broken USB pins
-inactive USB controller
-erroneous system drivers for USB
-camcorder is not plugged into AC power or is not on
-hotsync manager software from cellphones and PDA interference.
Aug 26, 2007 | Panasonic Palmcorder PV-GS15 Mini DV...
HP Pavilion dv1000 Notebook Logo
110 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
