Question about Plumbing
Can't remove Moen eva aerator - Plumbing
4 Suggested Answers
  • 122 Answers
SOURCE: How do I remove the aerator on a moen pull out
It should just unscrew. You might need some needle nose pliers as the aerator may be slightly recessed.
Posted on Jan 28, 2010
radar001
  • 1051 Answers
SOURCE: I have a Moen kitchen faucet, model 87511, that
Unscrew the retaining ring that holds the aerator and "O" ring. Note the O ring may be made out of brass or rubber. If brass it must be inserted with the beveled edge "in" Replace the retaining ring, sealing the threads with a small amout of plumbers putty or teflon tape. You can get a a repair kit which contains everthing you'll need for a couple of bucks at most hardware stores.
Posted on Mar 11, 2010
  • 65 Answers
SOURCE: how to remove the handles,moen,eva,two handles
the small hole underneath handle where you put your hand has a small set screw(alan wrench)-should be able to see hole,loosen and wiggle handle should pop off, spin off packing underneath and pop out stem make sure water is off - whole new stem is cheap
Posted on Jan 30, 2011
Just bought 4 moen Oxbridge bathroom sink faucets. Water pressure is very low compared to old faucets. Checked the aerator but no adjustment is available. New shower head is the same issue.
These days, you may find a disk with a small hole intended to restrict flow. It may be installed above the aerator. Check the flow with aerator removed.
Aug 13, 2017 | Moen Plumbing
How do I remove a recessed moen aerator on bathroom faucet? Looks rectangular in shape and seems like I need an allen wrench
The only ones I've seen that are recessed come with a tool, same diameter as aerator with gear like teeth on it. The teeth match up with the teeth on aerator and you just simply unscrew it. If you don't have the tool I have used a pair of needle nose pliers instead. Point pliers straight up, one point on each side of the aerator slid in between the teeth then turn the pliers (counterclockwise)
Jun 06, 2017 | Moen Plumbing
How to repair a Moen faucet aerator
SOMETIMES AERATORS JUST GET STOPPED UP WITH CALCIUM YOU CAN TAKE IT APART AND CLEAN IT OR JUST BUY A NEW ONE THEY ARE'NT THAT EXPENSIVE SOME AERATORS ARE VANDAL PROOF YOU WILL NEED A AERATOR TOLL OR YOU CAN PUT CLOTH OR SOMETHING SIMULAR OROUND THE AERATOR AND SQEEZE IT WITH A PAIR OF PLIERS TO LOSEN IT.
Oct 07, 2014 | Moen Plumbing
Just put in a new moen kitchen faucet, why does it have hardly any water pressue?
You might have a clogged aerator screen. Remove the aerator from the faucet and see if the flow is normal. You can rinse the aerator off if it's clogged. It's also possible the stops (shutoff valves) aren't open all the way. Sometimes, if they're old, they don't turn on fully again after you shut them off to put in the new faucet. If you still have low pressure after removing the aerator, you may need to replace the valves.
I don't know if the instructions mentioned it, but it's good practice to remove the aerator and run a faucet to flush the water line after installing it. There's usually a lot of debris that comes through at first. That's usually why you'll have low pressure in a new faucet.
Jul 14, 2011 | Microwave Ovens
Can't get the Moen Eva towel ring fixture to release so I can move it.
check underneath for a small setscrew. back this out and it should be removable
Jul 07, 2011 | Moen YB2818 Eva Towel Bar Bathroom...
Moen Eva two handle lavatory faucet - hot water leak from faucet. Old cartridge removed (had to get a special tool to remove it), new cartridge installed, and leak fixed. Four days later, leak is back...
Hot water side of most faucets give most problems try heating with hairdryer pryor to trying to remove,contact moen tell them of your situation they will more than likely send you a new cartridge free of charge if you raise enough stink about just replacing cartridge.
Jun 08, 2011 | Moen T943/MO4999 Eva Deck Mount Whirlpool...
How do you remove the eva towel rack holder
The Moen YB2824 is attached to the mounting bracket with a set screw through the base. You would simply need to loosen this set screw to remove item from the wall.
May 07, 2011 | Moen YB2818 Eva Towel Bar Bathroom...
Tighten up a loose Moen Eva towel bar wall mounted bracket
u have to really push hard up on the spring and at the same time pull towards u
Apr 18, 2010 | Moen YB2818 Eva Towel Bar Bathroom...
I have a moen #7560 faucet that makes a whistle sound when it is turned on and running. what is the cause
to much or too little water pressure or some sort of build up in the aerator.
Try removing the aerator and turning the water on and see if you have the same result....if not replace the aerator....if so check for scale build up inside spout or the water pressure.
Dec 03, 2009 | Moen Plumbing
Plumbing Logo
189 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
