Question about Homedics Health & Beauty
Won't turn on
It's a brand new handheld percussion massager. I put in new batteries - size c, alkaline. I slide the switch from off to lo or hi, but nothing happens.
  • 619 Answers
SOURCE: Battery problem
Hi , mostly camera complaining about draining the power of the battery , actually at present rechargeable battery , Im using Nickel Hydride battery ,typical 2500mAh I use to take pictures more than 200 shoots with flush. mostly selling rechargeable battery are 750 mAh the power is shorter .
Posted on Jan 15, 2008
meleemore
  • 19 Answers
SOURCE: Makita Percussion Drill HP2051F keyless chuck release problem
jacobs come out with this all metal keyless chuck(i think thats what you have) and if thats the case, there is no solution for this youll have to replace the hole chuck, being its new, it may be under warrenty
Posted on May 05, 2009
  • 11967 Answers
SOURCE: Canon Powershot A540, batteries need replaced
According to Canon, your camera needs servicing.
Posted on Dec 20, 2009
sunil06
  • 394 Answers
SOURCE: brand new nokia 6700 classic don't turn on for the first time
I think you hsave to upgrae your software
Posted on May 26, 2010
  • 457 Answers
SOURCE: When I slide the power switch, nothing happens
Try to slide and hold the power switch until after you see three blinks on the power LED. Should happen after ~5 seconds of holding.
Posted on Dec 22, 2010
My hhp-100 compact percussion massager is not working. I just put new batteries in it. HELP!!
batteries in the correct way?
could be a faulty on /off switch
look for a reason why the contacts at each battery
are not making a circuit and full voltage and powering the motor
HoMedics HHP 100 Downloadable Instruction Book
Oct 11, 2016 | Health & Beauty
I was given a homedics percussion action handheld massager with heat. It won't work at all. It does nothing!
Check that you have power and that there is a lit LED when a massage attachement is put into the top. Otherwise check this link for further instructions and power issues.
The 3 Best Handheld Percussion Back Massagers Under 50 Back Pain Relief...
http://back-pain-relief-products.net/handheld-percussion-back-massagers/
Feb 09, 2015 | Homedics Health & Beauty
I have plugged the Homedics handheld percussion massager in to a 220 v instead of 110 v. How do i repair it?
Hi, you will need to replace the transformer and diodes that manages the power supply.
Jan 05, 2015 | Homedics Health & Beauty
I cannot switch the camera on
sure your batteries are still tip top?
Try two new AA sized NiMH rechargeable batteries or if you have some new alkaline batteries, put them in. the alkaline batteries won't last long, but it it could hint if the camera is still working and worth buying new rechargeables.
AA manganese (Zinc-Carbon) batteries cannot be used with this camera.
Nov 27, 2013 | Vivitar ViviCam 5100 Digital Camera
Missing one black rubber knob that fits over one of the two massage posts.
You can try the manufacturer for the replacement part. Their number is 1-800-THUMPER (848-6737). If you need a new massager, try Chiropractic Consignment at http://chiropracticconsignment.com/massagers-and-accessories/
Aug 24, 2013 | Thumper Min pro Ii Massager, Three...
Directions to reprogram hunter 952g
You need remote control.
Go to your circuit breaker or fuse box, and turn off the power to the fan you will be programming.
  • 2 Turn the fan's remote control over, and remove the battery compartment cover. Take out the remote's 12-volt alkaline battery, and set it aside.
  • 3 Match the DIP switches inside the remote's battery compartment with the DIP switches on the fan's receiver unit.
  • 4 Reinsert the 12-volt alkaline battery into the remote's battery compartment, and replace the battery compartment cover.
  • 5 Go back to your circuit breaker or fuse box, and turn the power to your fan back on.
  • 6 Press the "Hi," "Med" and "Lo" buttons on the remote control in quick succession. Complete this step within 20 seconds of completing Step 5. The remote is now programmed and ready to operate your fan.
  • Sep 06, 2012 | Hunter Dryers
    Hi, I have two IC-R10's in very nice condition. Previous owner passed away several years ago and left the rechargeble batteries inside the units(The contacts had very little corrosion left from the...
    • Hi, I can help.
    • It is very possible that the corrosion could be a little worse than initially thought. Look for unnoticed corrosion and clean the contacts real real well with a pencil eraser.
    • Under the third battery is a switch marked (Charge) OFF/ON. When using the power supplies to power the scanner the switch should be off (pushed to the left). When using batteries the switch should be turned to on (pushed to the right)
    • The internal charger is meant to charge Ni-Cad batteries not Alkaline batteries. If you have Alkaline batteries in the unit then you should never have that switch to on with the power cord plugged in or a charge will be attempted on the Alkaline batteries and they will explode/leak.
    • The problem will be that switch, unnoticed corrosion or the batteries you are using are not good.
    • If you have any comments please feel free to leave them here.
    • Hope this helps and thank you for using FixYa.
    Regards, Tony
    Aug 29, 2011 | Icom IC-R10 Handheld Scanner
    My neck hurts...
    hi try to put liniment oil on your neck and massage gently..i already try it and it works!
    Apr 12, 2011 | Panasonic Personal Care Reach Easy...
    Massager Parts
    Wow , I've never hear of wearing out the balls - I dunno.
    Apr 17, 2010 | Homedics Pa 100h Percussion Massager With
    Health & Beauty Logo
    Top Homedics Health & Beauty Experts
    Ankit Chandel
    Ankit Chandel
    Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
