Question about Teac CD-RW880 CD Recorder
Com. error appears during recording and shut the recording process down why/ is the unit defective
What is the error code E5 on bluestar air conditioners mean
Problem
Overheat of inverter compressor motor
Cause
Shortage of refrigerant amount Leakage of four way valve
Defect of connector contact
Aug 14, 2014 | Heating & Cooling
Tip
No recording, open close error.
Details:
  1. Open - close error, can not load dvd and the led is blinking.
  2. After replace Main PCB, Loader and HD, conditions still same as before.
Follow this method:
Format the Hard drive, with steps as below :
a. DVD condition on --> Loading.
b. Press cancel button on remote until ST-BY appear on display set.
c. Press cursor up or down on remote until CD-UP appear on display Set.
d. Wait until formatting is complete.
Test open - close DVD.
a. If process open - close is normal, change the Assy Loader.
b. If Process open - close is fail , change the HD.
Damage loader can cause open-close error and error on HD.
on Mar 29, 2011 | Samsung DVD-HR735 DVD Recorder/HDD...
The unit turns itself on and off every 30 seconds. The screen displays hello and then 30 seconds says off and then a 30 second pause. What can I do?
This is a shut down due to an error in the system and is related to the malfunction of the main drives or the optical units.
You need to check the loading and drive sections, check the power to the main board/ processing section. Some times a fault in the mother board can result in such a shut down and will require a flow chart check up.
Take consensus without tampering.
Sep 08, 2011 | TruTech TT1620 DVD Recorder
After i have finish recording and i am finalizing the the cd code OPC appears on the screen, and being finalize the cannot play in other cd player why?
OPC means the unit had trouble Optical Processing Calibration, which means the disc surface may be damaged. Using brand name media and being careful to not touch the recording surface would help.
It's not completing the finalization so it won't play in a CD player yet.
It's mostly in the manual
http://www.retrevo.com/support/Harman-Kardon-CDR-20-CD-Players-manual/id/386dj191/t/2/
OPC: Stands for Optical Processing Calibration.
When you see this message in the Information
Display for the Record DeckK, it means
that the laser transport inside the unit is making
the calibrations and adjustments needed so that
the recording process is optimized for the specific
disc in use.
When an unfinalized CD-R or CD-RW disc is
placed in the Record Deck%, the letters
OPCwill flash once the Table of Contents has
been read. This indicates that the unit is optimizing
its circuits for maximum compatibility with
the specific recordable disc in use. the number
and total running time of any tracks that have
already been recorded will appear in the
Information DisplayK, and the appropriate
indicator SPwill light to tell you if a CD-R or
CD-RW disc is in use.
To Finalize a disc, place it in the Record
Drawer%. Once the disc's Table of Contents
information has been read and the OPC process
has been completed, press the Finalize button
E@and note that the Finalize Indicator
Uwill begin to flash. Within three seconds,
press the Select button9*and note that
the Finalize IndicatorUwill stop flashing.
The Finalization process will take up to two
minutes, depending on the length of material
recorded on the disc. During the Finalization
process the Record Deck will not accept any
operating commands.
Dec 29, 2010 | Harman Kardon CDR20 CD Player
Won't self clean. I am getting an error messag FSE 1.
Most likely it is F5-E1 code. self clean latch will not lock. follow procdures below,but likely problem is failed lock motor
All F5-E Codes - Door Switch Defect - This occurs when the door switches do not match. If door is latched, disconnect power from unit and check wires and connections. If damage is found, replace appropriate part. If connections are not damaged, reconnect power and hold down any key until the F5 error clears. Once the F2 code appears, select 'cancel' and observe for one minute for errors. If door is NOT latched, disconnect power from unit and check wires and connections. If damage is found, replace appropriate part. If connections are not damaged, measure door switch (door open = latch open) and latch switch (unlatch = switch open) and replace either if defective. If corrections are made during any step, power should be reconnected and the unit should be tested. Press and hold any key to clear the error code and F2 code should appear. Select 'cancel' and observe for one minute for errors. If error continues, disconnect power and replace control.
Dec 28, 2010 | Whirlpool GR460 Electric Kitchen Range
Kenmore gas oven continuously beeps F-5 when on. I have to cancel and not use. Please help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 23, 2009 | Kenmore 47732 / 47734 / 47739 Electric...
Model No'DMR-ES15 - U61problem
no comunication betwen control y dvd
May 11, 2008 | Panasonic DMR-EZ27K
Sharp LC-32D43U
This unit probably has a bad power supply. It may also be shutting down because if this unit has recorded 5 lamp errors it goes into shut down. To eliminate lamp errors you can force the unit on in the service mode and look for lamp errors. To do this, you unplug the unit, and while depressing the volume up and channel down buttons at the same time, plug the unit in. Hold for 1 second and release. The unit will then power on and a small k should appear on the screen. If this does not happen then there is definately an internal failure that will require a sharp auth. service center. If the unit does come on with the k, use the remote and press the channel up button. This will produce a menu on the screen and you will note on line will indicate lamp errors. On the right side of that line will show the # of lamp errors. If it reads 0, lamp errors are not the issue, however if it reads 5, you can highlight that line by using the channel down button. Then use the curser right arrow to select the error and then again to reset them. Once the lamp errors have been reset to 0, unplug the unit and wait at least 25 seconds before plugging in. The unit will now power up normally and this may cure the problem for good. If this process corrects the problem and it occurs some time later or right away that will be an indication that either the unit has bad backlights or inverter has failed and will again require service.
Feb 07, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
Tracking error (LG HL-DT-ST DVDRAM GSA-4081B DVD-RAM RECORDER)
please provide a photo software for samsung sghx620 mobile.
Feb 05, 2008 | Computers & Internet
Lens error M425-12 (7f80) appears/ camera shuts down
if the blue light flashes 4 times Main power led to on/off switch is crushed and not enough power gets through.
you have disassemble the camera.
I would think first before tring this.
Remove 3 screws on bottom, 1 in battery compartment, and 1 at very top of usb flap (look good).
Now slide the side piece starting at the usb flap then apply pressure to top and away from unit.
now look for 1 silver and three black screws (facing back and front, look good).
See the big red wire leading to main on off switch if it crushed thats the problem.
I replaced it with a longer piece of wire.
Remember to replace battery door first if it fell off during process.
*TEST NOTE: You can place batteries in and place a penny across the bottom to test before you put it back together.
Dec 27, 2007 | HP Photosmart M425 Digital Camera
Teac CD-RW880 CD Recorder Logo
41 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
