Question about Bosch Dishwashers
NEED SCHEMATIC FOR BOSCH SHE6APO6UC/05 DISHWASHER
E24 ERROR MESSAGE
SOURCE: bosch dishwasher lfestyle automatic runs for 1 min
e24 means the water supply isn't getting in
www.homeclick.com/PE-Links/Bosch/Bosch-SHE68E15UC-manual.pdf
This manual has troubleshooting that you can use for yours too.
Posted on Mar 31, 2010
techbuster
  • 5081 Answers
SOURCE: E24 error
E24 indicates a draining failure.
If the appliance has stopped full of water then you have to check the drain hose for blockages, especially where it connects to the drain. Check the pump for a blockage, bail out the water manually and remove the filters. You should find a cover held by a screw covering the pump impellor. Take out the screw, take off the cover and remove anything jamming the pump. Refit the cover and try the appliance again.
Posted on Apr 07, 2010
SOURCE: bosch dishwasher has e24 error code and does not
An error 24 code on your Bosch dishwasher means that you have a clog or that your pump is bad. Check and clean out your airgap. If that doesn’t work and your machine is still under warranty, call Bosch. Bosch won’t tell you what the error code means, only that you need a service call, and they will then give you some phone numbers for Bosch authorized appliance repair places, one of which was Mr. Appliance. The appliance repair place will want to put in a new part whether you need it or not so that they can get paid by Bosch. I found this out the hard way. Hey Bosch, be smart and tell your customers what the error codes mean so that they are informed and you don’t look like you are trying to rip them off. Leave that to Mr. Appliance. You can always remind the customer that working on the actual dishwasher voids the warranty. It doesn’t take a rocket scientist to figure out how to clean out the airgap, which isn’t a part of the dishwasher, but rather part of your plumbing connected to the dishwasher. I suspected this to begin with, but because you told me I needed a service call, I had to assume it was beyond basic owner maintenance. Great way for you to flush money down the toilet and look bad doing so.
Posted on Apr 30, 2010
  • 608 Answers
SOURCE: I have a bosch dishwasher
Error code 24 for a bosch dishwasher is either a bad pump or a plugged drain or airgap. This is where your washer connects to the plumbing system. If you are under warranty have it fixed if not I would start by seeing if your system and make sure it isn't plugged first. After that it could be the pump has failed.
Hope this helps
Posted on Dec 09, 2010
Daniel S
  • 4323 Answers
SOURCE: My Bosch Eco Sense dishwasher shows error code
Hi
E24 error indicates draining failure and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Hope this helps... Please post back for any further assistance.
Daniel
Posted on Jun 20, 2011
Bosch dishwasher stopped working after few minutes. And LED displayed E:24. What is the problem?
Fault Code E24
Symptom: Dishwasher not draining properly.
Cause: Drain filters blocked.
Action: Clean the filters.
Go to:Why is My Bosch Dishwasher Not Draining?
For more detailed codes see ...
http://www.drdishwasher.com/troubleshooting/manufacturer/bosch/error-codes
Sep 05, 2016 | Bosch Dishwashers
Bosch silence plus 50 dba dishwasher not draining it says E24
Error codes are cryptic but usually indicate the obvious. Probably drain pipe blocked with junk build up. Clear blockage. Spring curtain rod up the pipe. Ouch....
Perhaps a little draino.
Mar 02, 2015 | Bosch Dishwashers
Error -24 message want let me download it
Hello you haven't said the make of the dishwasher.
  • The E24 error is one that I am used to with Siemens and Bosch models. E24 indicates one of two things.
  • Frontally there may be a water evacuation problem. Check the drain outlet under the sink where the hose connection is
  • check inside the "well" of the dishwasher. You can remove the plastic pump cover to check for foreign items stuck in there.
  • If this is all clear then the E24 will be associated with the wash pump being stiff. Possibly due to a worn bearing.
  • You will need professional service to fix this.
Good luck.
Nov 21, 2014 | Dishwashers
Error message e21. Bosch dishwasher
My mom had the same issue with her fancy bosch dishwasher! It ended up being a hose, if I remember correctly. Her problem also took two repair trips, I know for sure it was not a new motor issue. I would have someone check the hoses and the electrical panel.
May 28, 2013 | Bosch SMS68M02AU Dishwasher
My bosch dishwasher she6af02uc is showing an E-24 error what is this
error code E24 = Drain hose blockage or pump impeller failure, suppose running it with filter unsecured would allow some goodies to get in there.
Changing the fine mesh filter should fix this.
Jun 29, 2012 | Bosch Dishwashers
Dishwasher will not run, gives a message "E-24"
Feb 12, 2012 | Bosch Dishwashers
Bosch dishwasher lfestyle automatic runs for 1 min then displays e24?
Mar 31, 2010 | Bosch 24 in. SHU6802UC / SHU6806UC...
Dishwashers Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
