Question about Avaya 700340193 Corded Phone
Avaya phone comcode 700016694 how to fix the date on the phone
How do id fix the date on display
Are you using Partner ACS release 3.0 or higher. If so, go to extension 10 or 11 and press Feature 00. Then press the Left Intercom button twice. This will take you into system programming. From there press #101 and enter MM/DD/YY. I also have included a PDF link for the Partner system. https://downloads.avaya.com/elmodocs2/partneracs_r4/456804_2.pdf
Sep 08, 2014 | Avaya Corded Phone avaparp18d
How do i change the date on my Avaya Euro 18D
Log into System Programming by pressing Feature 00 then left Intercom button twice. Then press #101 and enter date MM/DD/YY. Then press Feature 00 to exit and save.
Jul 02, 2014 | Avaya Eurostyle 18D Corded Phone
Date and time
If it is part of a phone system, it needs to be done at station 10. The date and time is not done on a per phone basis. Changing it at station 10 will fix all phones.
Aug 27, 2012 | Avaya 700340193 Corded Phone
Have Callmaster lll phones. We want mute button disabled. Agents have figured how to enable the mute buttons on individual phones. Looking for way to permantly disable mute feature on 700 phones. Thanks
First make sure headset/handset adaptors are not plugged into the phone
Press Select
Press Mute
Dial 68 (this will show the current setting)
Press * to change the setting
When the setting is at what you want press # this will save tyhe setting and exit programming mode
Hope this helps.
Mar 16, 2011 | AT&T LUCENT / AVAYA CALLMASTER IV PHONE...
How do you change the date on an Avaya phone?
Changing the date on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#101"
the display should say system date and the current programmed date
enter the new date in mmddyy format
press feature "00" to logout
Nov 10, 2010 | Avaya Corded Phone avaparp18d
My phone only rings once. is there a way to change that?
yes ask your local admin to make the ring changes in the station configuration
Apr 21, 2010 | AT&T LUCENT / AVAYA CALLMASTER IV PHONE...
Program Date and Time
From the phone at extension 10 or 11 press FEATURE 00 Left Intercom Left Intercom #103 and enter the 4 digit military time. (if you need it, the date is #101 in mmddyy format).
Press FEATURE to exit
Carl
Mar 20, 2009 | Avaya Corded Phone avaparp18d
Avaya 8434DX Display won't show date and time as normal display
You should be able to hit the Menu button, then the arrow directly below the TmDay display and then hit exit once the date and time are displayed. The date should disappear but the time should stay.
Feb 12, 2009 | Avaya Definity 8434DX Corded Phone
Time Change
you will need the administrator password to change the time. Access the time and date function by entering Options, System Options, enter password, set date and time, exit.
Mar 11, 2008 | Avaya Merlin Magix 4406D+ Corded Phone
Avaya 700340193 Corded Phone Logo
Top Avaya Lands Phones Experts
george  peters
george peters
Shehu Pro
Shehu Pro
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
