Question about Refrigerators
I have a hotpoint fzs150 it will onny work when the super freeze button is pressed ?
LEFT DOOR OPEN OF FREEZER. CLOSE3D DOOR FOR 24 HRS. nOW LIGHTS FLASHING ON SUPER COOL AND SUPER FREEZE.
You will need to unplug and defrost the fridge for a few hours then replug the power. Leaving the doors open allows moisture to freeze on the evaporator while compressor continues to run confusing the control board
APPLIANCE911
Apr 10, 2016 | Hotpoint Combi FFFL1810G Graphite 297 l...
I just bought a used (but never installed) wf 1061 (freezer with a wine fridge). the unit and dsidplay lights up as normal...but i don't hear the compressor starting...can it be in demo mode?...
Try this also:
Super freeze 5 seconds set desired temp press super frees briefly again then adjust the wine cooler temp press super freeze again briefly, Next press menu and select normal. Then press menu again. To exit press super freeze again until it no longer blinks.
Kelly
Aug 28, 2011 | Freezers
Aquarius wf620 super silent washer has "test" in
  • to de- activate press and hold the start/cancel button untill all the lights come on.
  • then press and hold the on/off and start/cancel buttons together until d-off appears
that should do it and if not get back to me, there is another way you can do it.
Jul 11, 2011 | Hotpoint Aquarius WF220 Front Load Washer
Alarm has stopped working on hotpoint freezer fzs175g I have reset as per instructions but there is no light and no sound
We had a problem with ours, try setting the temp dial to off and then hold the super freez button for 5 secs, you should hear a bleep and hopefully all should be well.
Nov 27, 2010 | Hotpoint Freezers
My hotpoint quadrio amber lights at the top of the fridge door are flashing is this anything to worry about - they are indicated with the words ''super cool'' and ''super freeze'' (sorry but cant find...
my hotpoint quadrio is causing problems the fidge part is no longer cooling the light is coming on but thast is all what can cause this. can anyone help
Feb 20, 2010 | Refrigerators
Hotpoint Fridge Freezer FF187e - 3 lights flashing
i have just fixed my fridge freezer by following the instruction from KarenBa and GWoman i have also managed to stop the lights (super cool and super freeze) from flashing by turning the temperature to zero on both fridge and freezer so they turn off then holding both super buttons down for about 15 seconds then turning the temperature back up. hope this helps
Oct 19, 2008 | Hotpoint FFS70 Bottom Freezer Refrigerator
Have a Zanussi ZCF132 Chest freezer. In normal mode the freezer has ceased to freeze even with setting to highest position i.e. 7. However when the super freeze switch is pressed it does as described,...
sounds like the thermostat.when you engage the super freeze button you merely bypass the thermostat to enable full time running of the freezer this is all the superfreeze button does
Aug 12, 2008 | Refrigerators
Hotpoint Aquarius super silent
Try pressing the "on" and "start" button together for over 5 seconds..............or till the display vanishes. You will tell me the result...............vote too.
Mar 17, 2008 | Hotpoint Aquarius WF210 Front Load Washer
HOW CAN I GET MY HOTPOINT AQUARIUS 1400 - OFF CONSTANT TEST PROGRAM?
This works
To exit the TEST mode, press and hold down the "Start/Cancel" button until ALL of the console lights light up. Press both "Start/Cancel" and On/Off buttons simultaneously until " dOFF " appears in the display. The default setting will now appear and the machine can be used normally.
Feb 04, 2008 | Hotpoint Washing Machines
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
