Question about Whirlpool LER4634J Electric Dryer
Can't remove motor from Whirlpool dryer (LER3624EQ1)
I'm trying to replace the motor in my Whirlpool dryer (LER3624EQ1). I can't figure out how to disengage the motor shaft from the blower wheel. I've tried pulling and I've tried unscrewing, but it just won't come out. Is there a set screw or pin that holding them together that I'm missing? Thanks.
  • detective241 Jan 25, 2009
    Which direction do you turn the motor shaft to release the fan blade?
  • housejob Jan 31, 2009
    which way do you turn it
  • 640 Answers
No set screw,,,put the motor back,,,put the motor clip back on...lock it back down...ok now take a wrench and put it on the end of the motor where the belt goes,,if your by your sef,,prop the wrench againt the inner cabnit wall,,,than turn the blower wheel its hard but it will come off you..just lock that motor shaft down,,grip pliers..wracket,,,please use glovers to turn blower wheel..housing is very sharp..onthejob
Posted on Jan 25, 2009
Dryer shuts off during cycle - Whirlpool MOD LER3624EQ1
Here are your parts
Replacement parts for WHIRLPOOL LER3624EQ1 ' AppliancePartsPros.com
If you have to wait several minutes before you can restart it then it is probably the motor overheating. It then trips it's internal thermal protect.
You have to wait till the motor cools down and the thermal protect resets before you can restart.
Try manually turning the drum in the correct direction. It should turn fairly easily.
If not it may be overloading the motor.
You may want to try this on a couple other dryers to get a feel for it.
If it is hard to turn run your fingers along the back and front edges of the drum just to ensure something has no gotten jammed in there. Be careful in case it is a sharp object. If nothing is there you will have to open it up and find out what is causing excessive drag on the drum.
Check/clean your vent system. Could be a partial clog is forcing hot air back onto the motor. May be the blower seal (Item 16 in Section 3) is shot.
Could just be that the interior of the machine is clogged with lint.
If all OK then odds are that your motor is on it's last legs.
__________________
Oct 11, 2017 | Whirlpool Dryers
Ler3624eq1 whirlpool makes clunking noise
May have a bad bearing go to Repairclinic.com and watch their video on dryers
Dec 13, 2013 | Dryers
My dryer isnt getting hot. its a wp model number LER3624EQ1
Check the thermal fuse, the heating element, all thermostats and the thermal cutout. If these are all right could be the centrifical switch on
the motor.Or wiring of course.Hope this helps
Oct 04, 2011 | Whirlpool LER4634J Electric Dryer
Electric dryer doesn't heat.
Probably a bad heating element. There are a few different styles, you'll just need to lookup your model number on an appliance parts website, find the right part, and then do a quick search on replacement. There are probably ten or fifteen websites that have instructions to replace heating elements.
Here's one where you can buy the part, the element is part number 17.
http://www.appliance-parts-warehouse.com/whirlpool-parts/Whirlpool-Dryer-Parts/Whirlpool-Parts-LER3624EQ1/Whirlpool-Parts-81777.cfm
Jan 15, 2010 | Dryers
Dryer will not heat; it runs but just does not get hot dryer is a Whirlpool LER3624EQ1 model
Sounds like your problem may be with the heating coil.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
Good Luck,
Hope this helps
Oct 08, 2009 | Whirlpool Dryers
Whirlpool dryer froze and wont tumble just makes noise where try
Hi, This dryser only has 1 belt. When you chacked the belt, was the belt located in the middle of the drum?
This model has an idler pulley that is no longer being used. They have went back to the roller style idler which is easier on the belt.
Raise the top and then remove the 2 screws holding the front to the cabinet. Remove the front cabinet and locate the idler next to the motor pulley. Look at the belt while you have the front off and see if there is any bad spots in it.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 02, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
465 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
