Question about Dynex "- 60"" Universal Tripod DX-TRP60"
Replace handle on dx-trp60
I need to replace the handle.
Need code for urc-152 remote for my tv
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Mar 01, 2014 | Dynex Original DX-RC02A-12 LCD LED TV...
- I need a quick release plate for this tripod DYNEX DX-MW010.
Try http://www.tripodquickrelease.com/Dynex_Quick_Releases.htm Check the dimensions of what you have against this one listed see if it will work for you.
Apr 02, 2013 | Photography
What size film does the minolta 150bf take
It takes 35mm film, with DX coding (look for the DX logo on the box, but it's difficult to find non-DX coded film these days). It can handle 100, 200 and 400 ISO film speeds.
Jul 14, 2011 | Minolta Photography
DX8800 iron power light (red in handle ) comes on but, no heat to foot and water comes out the bottom hole on each side of foot when tipped one side or the other
Ur iron needs to check and adjust the THERMOSTAT SWiTCH for the heat! Check also the THERMAL FUSE that might been blown and replace it w/ similar part! U need to bring that iron to ur electronic technician if u can't dismantle it to adjust and replace the said parts! hope that may help u out!
Nov 13, 2010 | Rowenta DX-8800 Iron
Need adapter plates for a dynex dx trp60 tripod
Try www.TripodQuickRelease.com for that part. There is listed the widest selection of quick releases and support more brands than any other web site I’ve seen.
Jun 11, 2010 | Photography
How to adjust frequency on transmit??? Galaxy
hELLO THERE
hERE IS SOME MODIFICATIONS FOR THIS RADIO
Galaxy Mods DX 2527 - VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...Hi Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VC 1....10.240, VC 2....10.240. DX 2517- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5....FM Deviation, VR 6....SSB Carrier Balance, VR 7....TX Offset, VR 8....CW Beep Level, VR 9....RF Meter, VR10...Final Bias, VR11...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM/FM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM/FM Low Power, VR601..13.8 Volt Power Supply. DX 22B- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...High Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VR21...TX Offset, VC 1....10.240, VC 2....10.240. DX 11B- VR 1....AM/FM S-Meter, VR 2....SSB/CW S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...CW Tone Level, VR20...Final Bias, VR21...TX Offset, VR601..13.8 Volt Power Supply, VR803..AM/FM Low Power. DX 77HML, DX 88HL, and DX 99V- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...AM/FM Low Power, VR20...Final Bias, VR21...TX Offset.
Unmarked VR in R189..AM/FM Medium Power for DX 77HML only. DX 33HML, DX 44V, DX 55V, DX 66V, and DX 73V- VR 1....AM/FM S-Meter, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 8....RF Meter, VR12...Low Power AM Modulation, VR13...AM/FM High Power, VR14...High Power AM Modulation, VR16...AM/FM Low Power.
Unmarked VR in R188..AM/FM Medium Power (DX 33HML only)
Unmarked VR in C139..Med Power AM modulation (DX 33HML only) DX 949,DX 959- VR 1....AM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM Squelch Range, VR 6.....SSB Carrier Balance, VR 7....TX Offset, VR 9....RF Meter, VR10...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM Low Power, VC1....10.240. DX 2517 and DX 2527-
Symptom:Buzzing or motorboating sound in either the transmit or receive.
Problem: TR602 is oscillating
Cure: Replace C602 with a .01uF cap {Cap is located in the power supply board}.
RG 66,99,DX2517 Replace Q54 2SB754 60watt 7A with a higher power 2SB817 100 Watt 12A. Derating of this component will cool operation, provide better voltage stability,decrease wobble, allow voltage increase to 14.5 volts comfortably. (replace 10 volt caps in this section of the radio to a minimum of 16 volts before increasing supply voltage to this level)and provide faster swing rise time, Replace Q37 2SA473 to a 2SA1012-0 or ECG153 this will improve the clarity and volume of the modulation and it will also run a lot cooler.
Nov 12, 2009 | Galaxy Radios DX-949 40-Channels Base CB...
I am trying to fix a door handle that will not open from outside
Turn the window handle to where you can see a small 1/2" slot rt at its base where it meets the panel.you'll notice a small brass v shaped clip,you'll need hooked pick or something simular to hook this clip and pull it out of its slot,this release's window crank handle. Once this is off the rest of panel is held on by plastic panel clips that pull loose by pulling panel outwards from door ,and also by a few various screws. once panel is off temp. slide window crank back on and crank window all the way up. You then should have clear view of outer door handle. Handle has two rods attached to it,one for lock assy., one for latch release.This is the one you'll be looking at.Most likely you will find rod has came loose due to broken retainer clip at handle,or casting on handle itself has broken off.If clip is broke you can buy new clip at dealer or at some autoparts outlets,replace and reattach rod(make sure rod locks into place).If handle casting is broke will need handle replaced.It is held in place by two 10mm bolts,two rods preeviously mentioned. If handle is body color matched will need color code(on door jam sticker)to order handle from dealer to match.Lock assy will need to be transfered to new handle,it is held in by two spring clips.You notice two holes one on each side of lock,you will need to push release clips inwards through each hole to release lock and slide it out.to install just push down into newhandlle until clips engage. Let me know if you run into problems. Good luck and if this was able to help you please leave me some positive feedback. Thanks and good luck, Joel
Oct 12, 2009 | Honda Civic Cars & Trucks
Need a quick release plate for Dynex tripod 60
Quick release plates can be purchased on amazon, here: Amazon com Dynex tripod quick release plate. Take a look. Wish you ebst of luck.
Thomas
Nov 03, 2008 | Dynex 60" Universal Tripod
Dynex "- 60"" Universal Tripod DX-TRP60" Logo
55 people viewed this question
Top Dynex Photography Experts
pontelemon
pontelemon
Tony
Are you a Dynex Photography Expert? Answer questions, earn points and help others
