Question about Dell A920 InkJet Printer
Connect Windows 8 to Dell A920 printer
Will I be able to connect a new HP computer with Windows 8 to my Dell A920 printer
SOURCE:
SOURCE: Dell A920 with Windows Vista
Believe it or not... the driver is buried on the Dell site for Vista 64-bit. I search and searched ... and there it was.
http://support.us.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R153048&formatcnt=1&libid=0&fileid=203948
In any case, I downloaded it, installed it, and it works fine. All the buttons (scan/copy) on the top work as well as printing. Now if I could just get my old XP machines to print to it on the network. But.. I think that is another thread.
Posted on May 01, 2009
  • 624 Answers
SOURCE: Dell Printer A920 + macbook
The Dell printers sold right now are Lexmark printers manufactured specifically for Dell. Dell only sells Windows PCs so there are no printer drivers for the Macintosh OS. I?m surprised your Mac doesn?t at lest recognize the printers presence but even if it did there are no software drivers so it isn?t going to work. Sorry for the bad news, please don?t shoot the messenger :)
Posted on Jul 15, 2007
  • 2715 Answers
SOURCE: my windows xp doesn't recognize my printer any longer
Reinstall the driver and software.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PRN_ALL_A920&os=WW1&osl=en&catid=&impid=
Posted on Apr 20, 2009
john_yap
  • 51 Answers
SOURCE: dell a920 printer not recognized by computer
You've tried to uninstall and reinstall the printer driver of your printer. But still no luck. The printer still won't print. Or it would say printing but it won't finish printing.
You can try these steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software
5.Delete any items under the ff keys:
HKLMSystemCurrentControlSetControlPrintEnvironmentsWindows NT x86DriversVersion-2
HKLMSystemCurrentControlSetControlPrintEnvironmentsWindows NT x86DriversVersion-3
HKLMSystemCurrentControlSet001ControlPrintEnvironmentsWindows NT x86DriversVersion-2
HKLMSystemCurrentControlSet001ControlPrintEnvironmentsWindows NT x86DriversVersion-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLMSystemCurrentControlSetControlPrintMonitors
HKLMSystemCurrentControlSet001ControlPrintMonitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLMSystemCurrentControlSetControlPrintPrinters
HKLMSystemCurrentControlSet001ControlPrintPrinters
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
From the start search box type spool and press .
The spool folder located at c:windowssystem32spool opens.
Rename c:windowssystem32spooldriversw32X86 to c:windowssystem32spooldriversackup.
Rename c:windowssystem32spoolprtprocsW32X86 to c:windowssystem32spoolprtprocsackup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
have a great day :)
http://tinyurl.com/yddyuw6
Posted on Oct 01, 2009
etaf
  • 779 Answers
SOURCE: im trying to connect a dell v305 printer to a new mac
NO Dell do NOT support Macs on there printers - BUT most of Dells printers are re-branded Lexmark engines - so if you can find the equivalent lexmark - you may find a driver lexmark makes all of dells printers the v305 or v305w is a lexmark model X4650. the Mac driver is here http://support.lexmark.com/index?page=content&productCode=LEXMARK_X4650&actp=PRODUCT&id=DR9768&segment=DOWNLOAD&userlocale=EN_US&locale=en
Posted on Apr 11, 2010
Is there a windows 7 driver for the A920
First run Delete Print Jobs to remove any stuck print job in the queue.
Disconnect the printer.
Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
Restart your computer. Make sure the printer is removed.
Manual Printer Driver Removal
Download the Vista 32-bit drivers for Windows 7 32-bit or the Vista 64-bit drivers for Windows 7 64-bit. Install the Vista drivers in the Vista
Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on).
Links to the patch/drivers can be found at...
Dell A920 All-In-One Inkjet Printer owners thread (W7)
Remember virus programs and firewalls will block communications.
Rick
Oct 19, 2011 | Dell A920 InkJet Printer
I have a dell printer A920 and an acer computer with windows 7. Having trouble getting the printer to work
First run Delete Print Jobs to remove any stuck print jobs in the queue.
Restart your computer. Make sure the printer is removed. Manual Printer Driver Removal
Download and install the Vista 32-bit drivers for Windows 7 32-bit or the Vista 64-bit drivers for Windows 7 64-bit. Install the Vista drivers in the Vista Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on)
Virus programs and firewalls will block communications.
Rick
Apr 18, 2011 | Dell A920 InkJet Printer
I connected my laptop with my dell A 920 and on my computer when i look to add printer it is not listed. It does nto print at all, i guess it is not recognised
You have to install the printer drivers. Click here to download the driver for DELL A920. Select the driver file according to your Operating System (e.g. Windows XP). After downloading the file, just double click it and follow the on-screen instruction. This will install the printer and you would be able to print.
Good Luck!
Hope this helps!
CreativeTECH
Dec 13, 2010 | Dell A920 InkJet Printer
Hi!
That A920 is working with vista, here is the drivers for thet:
http://support.dell.com/support/downloads/driverslist.aspx?os=WLH&osl=EN&catid=-1&impid=-1&servicetag=&SystemID=PRN_ALL_A920&hidos=WW1&hidlang=en&TabIndex=
Dont forget to download and install the application to, you need all the files on that site
For that 968 printer, uninstall it, download the files from the link below and reinstall it, that will make your printer work again
http://support.dell.com/support/downloads/driverslist.aspx?os=WLH&osl=EN&catid=-1&impid=-1&servicetag=&SystemID=PRN_ALL_A968&hidos=WNT5&hidlang=en&TabIndex=
Let me know how it goes
Good luck
Nic
Mar 30, 2009 | Office Equipment & Supplies
Dell all in one a920 printer
to get that issue resolved try downloading the latest vista drivers for the printer from the dell website and this would resolve the issue
Jan 23, 2009 | Dell A920 InkJet Printer
For a Dell A920 (Personal All-in-One), pls download OS appropriate driver(s) from here. Pls select Vista, thereafter, install.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 21, 2008 | Dell A920 InkJet Printer
Dell a920 all-in-one printer
just try by reloading the software for the printer & scanner
Jul 23, 2008 | Dell A920 InkJet Printer
see if you can get a driver from dell web page that works with vista
Feb 22, 2008 | Dell A940 All-In-One InkJet Printer
Dell A920 InkJet Printer Logo
827 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
