Question about IBM Computers & Internet
What kind of RAM I can install on my Phoenix AwardBIOS v6.00PG motherboard?
Phoenix AwardBIOS v6.00PG W9128II2 v6.00 031006 Intel Pentium 4 CPU 3.2GHz Currently I have two Kingston KVR400X64C3A/1G 2.6V sticks with two slots empty. I get an error upon boot that states "Mixed Mode Memory - Running in Non-ECC Mode", yet the two sticks seem identical.
5 Suggested Answers
melnavz
  • 1226 Answers
SOURCE: Upgrade
hello,
Please see documentation of the motherboard. if there is available ugrade of the processor, im sure the Ram can be upgraded upto 2Gig or higher but im not sure about the processor.
Anyway i recommend you to refer to you motherboard manual.
hope this help. melnavz
Posted on Apr 08, 2008
map9966
  • 2351 Answers
SOURCE: please help me in my RAM
Hi hope13,
you had it correct the first time. The DDR2 533MHz memory should be in the Blue slots. When using two DIMMS the motherboard requires the DDR2 533MHz memory be of the same size, brand & speed. For you to get a blue screen has nothing to do with you're memory. If there was a problem with you're memory, you bios would let you know by beeping a series of repeating beeps. Blue screens are usually caused by software & some hardware like you're hard drive. If you have data on you're hard drive & you do not want to erase it by re-installing windows fresh (That includes a must format), than I can suggest you download this software from this site. Click on the link.
http://www.ultimatebootcd.com/ Read what the software can do for you. If you do not want the software. Than break out you're windows CD & load it into you're CD-ROM drive. Boot the PC to the CD-ROM drive & in-stall windows. You're PC will function again when you finish installing windows & you're motherboard driver cd.
Good Luck!
I would have posted sooner but I though another was answering you're question.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
Posted on May 22, 2008
joecoolvette
  • 5660 Answers
SOURCE: computer will not boot to windows.
The light you're referring to is the HDD Activity Lamp.
(HarDDrive)
It blinks green when it's operating, and orange for inactivity, or not operating.
You're getting to the BIOS Post screen, but BIOS is handing over the computer to the Operating System.
(Windows XP is an example of an O/S)
When you press the Power On button;
1) A temporary connection is made from the motherboard to the power supply. A 5 volt circuit is made. This turns the power supply on. (Soft Power On)
2) The BIOS chipset, is the first chipset to receive power. (Chipset is a slang term for IC. Integrated Circuit)
The BIOS program, ( 64MB in size), looks to see what all devices are connected.
(Harddrive, optical drives, mouse, keyboard, etc.)
3) Then BIOS does a Ram Memory count,
4) Turns the Processor on,
5) Then hands the computer over to the Operating System.
It looks like BIOS has recognized your Intel Pentium 4 processor, (2.66GHz frequency rate, 533MHz FSB), but hasn't turned the processor on.
[Let me stop,and explain something real quick.
Where you see -
Intel (r) Pentium (r) 4 cpu 2.66ghz (133x20.0)
The r stands for Registered. Intel and Pentium are registered trademarks of Intel Corporation.
It's a Pentium 4 model.
2.66GigaHertz is the Frequency Rate. Slang term for frequency rate is 'Speed'.
Giga = Approximately 1 Billion
Hertz stands for Cycles per Second.
At maximum capacity, your Pentium 4 processor can operate, at a 2.66 Billion Cycles per Second frequency rate.
133 stands for 133Mhz. 133 MegaHertz.
Mega = Approximately 1 Million
This is the Clock Rate. Intel processors are 'Quad-Pumped', so the FSB is actually 533MHz.
(FSB = Front Side Bus)
The 20.0 is the multiplier.
20 times 133Mhz = 2600 Mhz,
or 2.66GHz ]
Now, why is the processor not turning on?
Suspect the Power Supply.
Not enough power to turn the Processor on.
1.ALL the lights for your computer use less than 1 Watt.
2.EACH fan uses 2 to 3 Watts.
3.A typical processor uses 55 to 125 Watts!
(The Processor hasn't been turned on, so nothing else is receiving power yet)
This is the basic specifications for your processor,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_.2890.C2.A0nm.29
Scroll down the left column of the list.
Where you see Pentium 4 505, Pentium 4 505J, and Pentium 4 506. Your processor is one of these three.
Scroll across. You will see 2667 MHz. 2667Mhz is rounded off to 2660 MHz, or 2.66GHz.
You will see 533M/T as you scroll across.
M/T stands for MegaTransfers. A more accurate description of FSB. Front Side Bus.
Scroll further across. You will see 20x. This is the Multiplier. (Look up)
Lastly scroll across a little further. You will see 84W.
This stands for 84 Watts.
Your processor operating at maximum load, uses 84 watts.
Why do I suspect the power supply?
Because it's the number 1 thing to fail in a computer.
Electrolytic Capacitors fail inside, or are failing.
They have Electrolytic Paste inside them.
The paste has developed a gas, (Hydrogen gas), and has popped seals for the capacitor's case.
This results in Electrolytic Paste slowly oozing out of the capacitor, and resulting in the capacitor failing, or has failed.
Electrolytic Capacitors are used as Filters in a computer power supply. They filter the incoming AC electricity from your house, and the outgoing DC electricity made from the power supply.
When capacitors are failing, or have failed, they create a bad power rail.
There are three main power rails in a computer power supply.
1) The 3.3 Volt power rail
2) The 5 Volt power rail
3) The 12 Volt power rail.
With a weak power rail due to failing capacitors, or a bad power rail due to failed capacitors, you do not have enough power to turn the processor on.
Solution?
Use a known, good, compatible power supply for a test. If the power supply is found to be bad, replace it.
Questions?
Posted on Dec 20, 2009
Testimonial: "wow. what great and informational help. thank you."
  • 11800 Answers
SOURCE: will intel d845grg motherboard accept ddr pc3200
yes
http://www.intel.com/support/motherboards/desktop/d845grg/sb/cs-010374.htm
Posted on Oct 09, 2010
I have this motherboard PACKARD BELL BV GA-T671MG. how much ram memory can it have? can i use ddr3? my pcie port supports a 2.2 graphic card?
System
System : PACKARD BELL BV ISTART F2310 AIO
Mainboard : PACKARD BELL BV GA-T671MG
Bus(es) : ISA AGP PCI PCIe USB
Multi-Processor (MP) Support : 1 Processor(s)
Multi-Processor Advanced PIC (APIC) : No
System BIOS : Phoenix Technologies, 255.255
Total Memory : 767MB
Intel Pentium D 3.00GHz
Packard Bell BV (GA-T671MG)
SiS chipset (Si671V11)
DDR2
1024mb ram
PACKARD BELL BV
Model GA-T671MG
Chipset Vendor Silicon Integrated Systems (SiS)
CPU Intel Pentium D
Cpu Socket LGA775 [Socket 775]
Processor Upgrade ZIF Socket
Max CPU Speed 3000 MHz
System Slots 2 PCI, 1 AGP
Memory Summary
Location System board or motherboard
Maximum Capacity 1024 MBytes
Memory Slots 2
Error Correction None
Use System memory
Maximum Memory Module Size 4096 MBytes
Manufacturer PACKARD BELL BV
Model GA-T671MG
CPU Intel Pentium D
Memory Summary
Memory Slots 2
Use System memory
it seems this might vary i have listed 4
hope this helps
May 17, 2011 | Computers & Internet
Ram upgradation for Intel(R) Pentium(R) D CPU 2.80GHz
You defiantly need to install the maximum ram the PC will hold and be able to use. Simply go here: http://www.crucial.com/ On that page click the "Scan My Computer" tab and allow the download of the scanner. It will safely scan your computer and tell you exactly what you can install and the price.
Nov 14, 2009 | Cars & Trucks
Computer Information Manufacturer: JETWAY Model: System Information Chipset: Intel 945G/GZ/P/PL Express Memory Controller Hub PCI standard host CPU bridge Motherboard: LakePort CPU: Intel(R)...
U may always refer to it motherboard to get to know the supported hardware that plug to it. Since u are mention about Intel 945G/GZ/P/PL family motherboard, each type of the motherboard (type G, GZ, P, PL) have their own specification, but the same thing is their are design to support Intel Core 2 Duo. Pentium D or Pentium 4 processor. And all can support DDR2 memory. Here you can refer to the manual of the motherboard for more details e.g. pg17 (availability 2009Nov16): http://www.intel.com/design/chipsets/datashts/307502.htm
YBC (/)
Nov 14, 2009 | Intel Computers & Internet
Hi There , I Bought a PM8M-V Motherboard cause my old mb died , aand im having problems with this! Intel(R) Pentium(R) 4 CPU 2.40GHz MB ID - P4M800-8237-6A7L6009C-00 MSI PM8M-V H (MS-7104 v2) 512 MB PC3200...
When it gets slow, start the Windows Task Manager.
Click the "Performance" tab.
Check what percentage of the CPU--power is being used.
Check what percentage of the RAM is being used.
Click the "Processes" tab.
Click the 'CPU' column-heading *TWICE* to sort the processes,
so that the "big" users of CPU are listed at the top.
Scan for computer-viruses.
Oct 29, 2009 | MSI PM8M-V Motherboard
Is it compatible a intel dual core processor to a
Hi..
If you want to upgrade you unit be sure that the motherboard socket are totally fix with the processor. The compatibility is important because if it is not compatible the motherboard can not support the processor,
Good luck !!!
Regards
PCmania
Jul 15, 2009 | ASUS P5PE-VM Motherboard
Need mother board driver:phoenix Phoenix - AwardBIOS v6.00PG
Version EVEREST v2.20.405
Homepage http://www.lavalys.com/
Report Type Quick Report
Computer CRYSTAL_XP
Generator crystal
Operating System Microsoft Windows XP Professional 5.1.2600 (WinXP Retail)
Date 2010-03-04
Time 09:01
--------[ BIOS ]--------------------------------------------------------------------------------------------------------
BIOS Properties:
BIOS Type Award
Award BIOS Type Phoenix - AwardBIOS v6.00PG
Award BIOS Message P4M80-M4 (4M80M609 BF)
System BIOS Date 06/09/07
Video BIOS Date 08/15/06
BIOS Manufacturer:
Company Name Phoenix Technologies Ltd.
Product Information http://www.phoenix.com/en/products/default.htm
BIOS Upgrades http://www.esupport.com/biosagent/index.cfm?refererid=40
Oct 11, 2008 | Intel Motherboard
Upgrade
to upgrade your going to have to take the laptop apart and remove the heatsink on top of the cpu, then disconnect the cpu, and then install another cpu in place of it, apply therman greeze and put the cpu heatsink back on. and reassemble your laptop.
Mar 31, 2008 | Computers & Internet
Intel ASUS P4 845 GL Motherboard
Hi, For an ASUS P4BGL-VM Intel 845GL Chipset Ultra ATA100 MATX CPU Type: Intel Pentium 4 478-Pin (OEM), the Asus site specifies max of 2 x 184-pin DIMM Sockets support max. 2GB PC2100 / PC1600 non-ECC DDR or SDRAM memory but not "and". Personally, I find it more practical to install 2 X 1Gb rather than a single 2Gb. Hope this gives you some idea. Kind regards.
Aug 07, 2007 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
Computers & Internet Logo
29 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
