Question about Home Security
Instructions for shed alarm model no. KF-7A I want to change the 3 digit alarm code
The factory setting for this product is 333. I have lost the instruction sheet of this product.
5 Suggested Answers
informatica
  • 1114 Answers
SOURCE: setting alarm
You can download the manual from the link below: http://emersonradio.com/owners/SmartSet%20Series/CKS3020_072706.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 27, 2007
informatica
  • 1114 Answers
SOURCE: Emerson Smartset alarm clock
Hi - You can download the manual from the link underlined in blue below:
CKS3528
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Posted on Jul 30, 2008
SOURCE: alarm clock came with chinese instructions manual,I need English
1.slide "return to time"to off, slide "backlight" to on
2.each press of the mode button goes through "time, temperature, year, month(M looks like an H) and day(D), alarm1, "2, "3, , Birthday Celebration, countdown/stopwatch"
3. when on the category u want to change, press and hold set button for 3 secs, adjust with up and down and the hit set when done with each adjustment
Buttons on the bottom in order from left to right are(buttons on the top part of the clock bottom when turned on its side) mode, set, up, down
Posted on Jan 23, 2009
gotgeek2
  • 565 Answers
SOURCE: Lost the instructions need help setting it up for
Here ya go:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt300.ashx
Posted on Dec 08, 2009
Testimonial: "great instructions, thanks"
Brookstone Model cks 2022 Alarm clock radio Instructions
I searched on your product name and found an instruction manual for a Brrostone self-setting alarm clock radio:
http://www.brookstone.com/webassets/pdf/607960p_manual.pdf
Apr 23, 2014 | Brookstone SmartSet Alarm Clock
Factory Reset Grandstream GXP 2000 w/o using the menu?
From the Granstream User Manual (Page 44):
Restore Factory Default Setting
WARNING: Restoring the Factory Default Setting will delete all configuration information of the phone.
Please backup or print all the settings before you restoring factory default settings. Grandstream is not
responsible for restoring lost parameters and cannot connect your device to your VoIP service provider.
INSTRUCTIONS FOR RESTORATION:
Step 1: Press "OK" button to bring up the keypad configuration menu, select "Config", press "OK" to
enter submenu, select "Factory Reset" (Please refer to Table 5-1 of keypad flow chart)
Step 2: Enter the MAC address printed on the bottom of the sticker. Please use the following mapping:
0-9: 0-9
A: 22 (press the "2" key twice, "A" will show on the LCD)
B: 222
C: 2222
D: 33 (press the "3" key twice, "D" will show on the LCD)
E: 333
F: 3333
Example: if the MAC address is 000b8200e395, it should be key in as "0002228200333
395".
NOTE: If there are digits like "22" in the MAC, you need to type "2" then press "->" right arrow key to
move the cursor or wait for 4 seconds to continue to key in another "2".
Step 3: Press the "OK" button to move the cursor to "OK". Press "OK" button again to confirm. If the
MAC address is correct, the phone will reboot. Otherwise, it will exit to previous keypad menu interface.
https://www.grandstream.com/products/gxp_series/general/documents/gxp_usermanual_english.pdf
Apr 03, 2014 | Grandstream GXP-2000 IP Phone
Ihave a minder shed alarm (4 button model) the batteries ran out and i dont know how to reset it any1 help!
Factory Code settings 1234, To change the factory code press button 1 for 2 seconds, wait for 2 beeps, now enter your new 4 digit code, you will hear a further 2 beeps to confirm the new code. If the battery is removed the code will revert to the preset code(1234)
Nov 05, 2011 | Stoves 720EF Electric Double Oven
I bought a 99 expedition used... can i reset the keyless door entry pad?
I did a search and found this answer for you
Here is the location with full instructions:
The module is fastened to the top of the firewall directly behind the fuse box. It can be reached easily when you lie on your back in the driver floor area with your head close to the brake pedal. Just look up and you'll see it is clearly marked and the sticker also displays the factory-set access code for your truck.
Once you locate the module Make a note of the 5-digit access code on it.
Once you find the code, here is how to program it:
Now that you have the codes follow these steps to operate it completely. Remember from the driver's door, all operations must start with the 5 digit code first then follow it with the other options.
When pressing the controls on the keyless entry keypad, press the middle of the buttons to ensure a good activation.
IMPORTANT: Every step outlined in every procedure below must be done within five (5) seconds of the previous step.
REMEMBER THIS: If you try the factory code first and it doesn't work try to reset the keypad back to the factory code. Your personal code does not replace the factory-set code. So no matter what you can erase anyone's code back to the factory OEM setting. You can use either code to unlock your vehicle. Each time you set a new personal code the module will erase the previous one in favor of the new code.
Deprogramming (erasing) your own or pre-set personal code and leaving only the factory-set
1. Enter the factory-set code. (5 digit) from the sticker on the RAP module.
2. Press the 1/2 control.
3. Press the 7/8 and 9/0 controls at the same time.
The system will now only respond to the factory-set code.
Unlocking the driver's door (also disarms the perimeter alarm system)
1. Enter either the factory-set code or your new personal code. The interior lights will illuminate as soon as the first valid digit is pressed.
Unlocking all doors
1. Unlock the driver's door (5 digit code) then press the 3/4 control.
Locking the doors (also arms the perimeter alarm system)
1. Press 7/8 and 9/0 controls at the same time. The 5-digit code does not have to be entered.
Deactivating/Activating Auto lock
1. Enter the five (5) digit code.
2. Press and release the 3/4 control while holding the 7/8 control, then release 7/8.
Programming your own personal entry code
1. Enter the factory-set code (keypad will illuminate when first digit is pressed).
3. Enter your personal 5-digit code.
Sep 12, 2011 | Ford Expedition Cars & Trucks
I have lost the instruction manual how do i change the setting from miles to kilometers
If you have the model, Ped Alarm - PE319, it doesn't have metric units. Correctly, Brunton sells one model programmed for metric and one with Imperial units. The units are fixed, and no conversion information is programmed into the units. The product web site doesn't come up correctly on my browsers: http://www.brunton.com/product.php?id=45. However a FAQ is available at http://www.brunton.com/faq.php . The manuals are also available here, for the Ped Alarm, click on Instruments and look in the list for that model (followed by .PDF).
I wish I could be of more help.
Oct 30, 2010 | Brunton Digital Pedometer with Alarm
Changed factory code once and need to change it again
I really need the model no. of your lock to be sure I give you the right info, but you can go to www.alarmlock.com and click on "support" at top of home page, then scroll down to bottom of support page and click on "technical library". On the next page, scroll down to DL Programming Manuals and click on your model number. Tip: in the programming instructions, when they refer to the "A" or the "AL" key it is located where the # key is on a phone keypad (to the right of 0).
This key has the alarm lock logo on it. Hope this helps!
Apr 14, 2009 | Trilogy Alarm Lock T2 TRILOGY® Digital...
Maual to safehouse burglar alarm Model 49-307
Not sure about model 49-307, but it's probably the same as modle 49-537...
1) hit *
2) enter old code (which after power-on reset is the factory default of 1234)
3) hit * again
4) enter your new 4 digit code
5) hit * one last time
Your new 4 digit code should now work to arm and disarm it.
If you enter any wrong digits hit the # key to clear the error, and re-enter the code.
hth,
Paul W.
Mar 23, 2009 | Home Security
Need instructions for Timex 1440 Sport watch
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to sesume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
Nov 22, 2008 | Timex 1440 Nylon watch
Quorum Elert
Hang on...I might have a line on the manual. I'll post when I get it.
Dec 16, 2007 | Computers & Internet
Setting a generic one-button digital watch
I too lost the instructions for my generic 4 button digital watch and had to find the functions by trial and error and the results are below.
Adjust Alarm/Time/Date - Press and hold Mode Button. When alarm displays, release. Start-Stop Button SELECTS, Lap-Reset Button ADJUSTS selection. Pressing the Mode Button again changes from Alarm to Time/Date, ADJUST as above. Pressing it again exits.
Select/Deselect Alarm, Hourly Chime or Both - Press and hold Lap-Reset Button, Start-Stop Button TOGGLES through the above options.
Select 12/24 Hour Mode - Press and hold Lap-Reset Button, Mode Button TOGGLES through the above options.
Select Stopwatch - Momentarily press the Mode Button, use the Start-Stop and Lap-Reset buttons to control.
Display Date - Press Start-Stop Button in normal time
display mode.
Display Alarm - Press and hold Lap-Reset Button in
normal time display mode.
Cancel Alarm - Press Lap-Reset Button in normal time
display mode to silence alarm.
Hope this is helpful,
George.
Nov 06, 2007 | Watches
Home Security Logo
1,725 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
