Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
MIRAGE OS HELP
i downloaded mirage os for a ti 83/84 calc and i got z tetris (size 03292 (bytes?)) but i cant get any other games like mario or donkey kong to work. they show up in mirage os when i add another ":" at the beginning of each prog., but when I try to run it, the screen blinks once and nothing happens. I have a ti 84 silver edition with 22552 ram free and 214307 arc free.BTW my OS is 2.40   -thanks,mike
  • xoshi101 May 11, 2010
    when you put the program on the calculator, BEFORE YOU MODIFY IT, does it show up in MirageOS?
  • 360 Answers
I'll just tell you your calculator is going to crash big time if you don't get the 3rd party software off of it. sooner more than later.
Posted on Sep 24, 2009
  • Richard Klein
    Richard Klein Oct 02, 2009
    The games may have conflicts with other programming, and you just can add on in the Mirage os. They need there own separate on the menu select from the menu. You may have reached the limit memory available too, because of big programs, and you may not be archiving and unarchiving the correct files. By looks, you should have enough RAM, so check your procedures and compatibility Of Mirage os to operate ths type of programming. I don't really think it matters because your guaranteed to crash with this os on there.
2 Suggested Answers
SOURCE: mirage os calc
yo i had the same problem, i ended up going back to os 2.40 - alot of times when oyu download mirage its from an unreliable source. the same thing happened to me cuz i wanted to play mario, but it isnt worth ******* up the insdes of the calculator man.
Posted on Jan 24, 2009
I inherited my sister's graphing calculator and she forgot the password to Mirage OS. Is there any way I can reset or find out the password? Thanks.
Yeah. Go into memory (2nd, +, 2, 1) and then scroll down until you see something called Mirage OS it should be 42 bytes. Delete it and you're good to go.
Feb 15, 2011 | Texas Instruments TI-83 Plus Calculator
I need to delete a program that has an admin password
You have to re-install for instance; Mirage OS and, have Mirage OS uninstall itself. Your calculator will be locked up if you don't. It is almost impossible to fix. I was lucky one time that, I was able to re-install it to have it take itself off.
Jan 06, 2011 | Texas Instruments TI-84 Plus Silver...
When ever i turn on mirage os my screen slantes. i can't even see properly! what do i do?
In the desert, a mirage is produced by the incurvation of the light rays due the presence of a strong temperature gradient close to the ground. In view of this physical fact, is it any surprise that Mirage OS makes your screen appear slanted? To restore you calculator to its normal state delete the Mirage and you will straighten the screen.
Hope it will help you recover proper eyesight.
Thank you for using FixYa.
Do not forget to rate the solution.
Nov 24, 2009 | Texas Instruments TI-83 Plus Calculator
Can you delete ram with ti connect?
This is your question which I think is the solution for this question!
I downloaded Mirage OS, and now I can't download any of the games. I downloaded tetris before, and then I came back and can't download anything through TI connect.
Obviously, at times ti connect is going to be worthless to you if you have OS Mirage. So, that's correct! Plus, it didn't cost me a calculator to find that out!
For you to get it off? I can think of a few, I glad I don't have too..
May 26, 2009 | Texas Instruments TI-84 Plus Silver...
How do you download os s
go to tieducation home and search ur model OS Then connect and load
Mar 02, 2009 | Texas Instruments TI-84 Plus Silver...
Mirage os calc
Jan 20, 2009 | Texas Instruments TI-84 Plus Silver...
TI Connect problem with Mirage OS
It is possuble that you have run out of archive space. To clear some up, press 2ND - MEM (the + key), 2 then 1. This will give you a list of all things on your calculator. Some of these may be neccessary for some math courses, but you can always put them back on later, so you can remove anything you want from here without any irreversable effects. Delete anything you don't need (excluding the games and Mirage, of course) by moving next to it with the up and down arrow keys and pressing the DEL key.
Dec 20, 2008 | Texas Instruments TI-84 Plus Calculator
Is there a way to play games and put in a password on a TI-83 plus?
Yes, there is. There is a program called mirage os and another one but i forgot the name. You should google it to find online. You need to have ti connect which you can get it off the ti website. Well mirage os can have a password by pressing alpha in it. Also in order to have a password to turn it on you would need to go to mirage and then press on and then it should turn off. To program you would need to know assembly or ti basic (they are basically the same language). To start programming he would need to press the prgm button and the options are reached by pressing the prgm button again.
Sep 10, 2008 | Texas Instruments TI-83 Plus Calculator
Misinterpreting Program Types
many times it all as to do with how much memory you actually have. the more games the less memory, and if you use too much memeory on the actuall files it doesnt have enough to run games, to free up space either delete some files or archive them (archiving renders them unuseable untill u rearchive them) but archiving has alot more space
also some games are not compatible with mirage os or ti 84
hope this helped
May 17, 2008 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
338 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
