Question about Protron 7" Portable DVD Player
Wrong disk while playing dvd player stopped and now attempts to load and then says "wrong Disk"
    Genius:
  • 2,985 Answers
There are many chip sets for DVD machines and each has preferences for a range of disk types- most will play straight commercial discs- but things get a bit tricky with the many and various types of 'burned' disks from computers. The strange thing is - it seems the cheaper the player the more versatile they be whilst a Hi grade one can be a tad fussy about what it will and will not do. So what does this mean to you? Check the types of disk you have been playing on it and stick to it- come back with exactly what disks it don't like
Posted on Jul 11, 2007
SOURCE:
Says loading disk and then says wrong disk everytime. tried several different dvds. always the same answer!
The DVD portable player and the DVD disc came from the same countries?Ur DVD portable player and DVD disc u are using might have the wrong region DVD disc format frequencies.Like PAL frequencies only play Euroupean,Asia,Middle East,Austriala and Africa products.NTSC frequencise play only USA,Canada and Mexico DVD Disc products.
Dec 13, 2010 | Coby 7" Widescreen TFT Portable DVD Player...
Suddenly my DVD player is saying "no disc" after trying to load DVD. Why isn't it sensing the DVD has been loaded?
When a DVD goes into DVD player it has to spin it and read it. If your DVD player is not reading the disk. The disk could be dirty. The DVD player might need to be cleaned. You could be trying to play a PAL disk on a NTSC player or Visa Versa. or the region coding might be wrong. Try playing a clean disk that you have played in it before. That might tell you if you need to clean the DVD player.
Mar 03, 2010 | GoVideo DV2130 DVD Player/VCR
DVD Player Not loading Movies
optical sensor is burned out or the spindle is not spinning the disk to read it.
Nov 06, 2009 | Coby DVD-224 DVD Player
Portable dvd player
the laser may be broken,and can not read...
Apr 15, 2009 | Mintek MDP-1720 Portable DVD Player
DVD player wont play just says loading and than stops
there might be dust on the lens. try cleaning both the lens and dvd itself.
Mar 28, 2009 | Durabrand PDV-709
My Sony DVP-cx995v stopped playing DVD's
I had the same "Cannot play" problem - happened suddenly, I don't think I was doing anything unruly at the time.
After checking repair (exchange) prices in excess of $250 from Sony, I decided to open the cover to see if I could see anything wrong - normally a futile exercise with electronics except that in the past I have cleared errant disks that have lodged themselves near the drive/player at the rear of the library.
Upon opening and watching the library try to load and play I noticed the drive itself was not spinning the disk once loaded. It would sit for awhile, thinking about it I'm sure, then would unload and load the next dvd, again failing to spin.
I thought okay, maybe try to spin the dvd while in the player to see if it's jammed or otherwise hard to turn. It was not hard to turn and spun freely. In fact, when I put my finger through the hole at the exposed side of the player at the hub to spin the dvd, clockwise, it suddenly started to spin - and play!
I put the whole thing back together to test and all seems to be working fine at this point. Not sure what would cause the motor to stop spinning and remain in that state through poweroff/on cycles etc. but I'm sure this is not the last time I will have trouble of this kind.
I would note that when replacing the library back in its home on the shelf, be careful not to tip the library, especially toward the player area because the disks will spill out of the carousel near the player and become jammed when you power it on and attempt to load. A final tip of the library away from the player area may clear this if you hear the disks rolling out of their slots and you don't want to open the top again (it's a darned heavy box when fully loaded).
Jan 05, 2009 | Sony DVP-CX995V Multi-disc DVD Player
DVD stopped working and cannot do setup.
You probably need to reset your DVD/VCR/Combo. Go to www.samsung.com. Go to <Support>. In the search box, type in the model of your DVD/VCR/Combo. Or type in, >how to reset DVD/VCR/Combo<. Each model has different reset method and there are hundreds of models!
853. How To Reset Your Samsung DVD Player STEP 1
STEP 1. DVD Reset List
Samsung DVD players have a built-in reset procedure that resets the DVD player to the factory defaults. You can use the reset procedure to reset settings that don’t work with your TV or to resolve issues such as unit lock up. To run the reset procedure, you press one or more buttons on the front of the DVD player and hold them for at least fifteen seconds. The buttons your press depend on the model you have.
Important: For the reset procedure to work, you must press the buttons on the front of the player, not on the remote control for the player.
Below is a list of all Samsung DVD players and the buttons to press to run the reset procedure.
DVD511 - Stop / Play
DVD611 - Stop / Play
DVD709 - Stop / Play....
Many, many other models follow but cannot be listed here because of this site's text limitations.
Jun 15, 2008 | Samsung DVD-V4600 DVD Player/VCR
Error message
Uh oh.. Time for a service visit as the optical assembly has stopped scanning properly...accordianman
Mar 21, 2008 | TruTech TT320
Disk reading
2 questions her 2 problems 2 answers. 1.Recording The machine is probably fussy about the type and brand of blank disk it will work with. Check your manual and sample several brands 2. Playing the burned disk you wish play if from another device has to be finalized in the burner machine.
Jul 30, 2007 | Sony RDR-GX315 DVD Recorder
Protron 7" Portable DVD Player Logo
194 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
