Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Kenmore elite 665.13963K015 has an error f4E1 how do i fix it
3 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: du error code on a kenmore elite oasis he what
Door unlock failure
Excessive force on door lid is preventing lock bolt from
retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an
unlocked state. See TEST #8, page 14
Posted on Jun 11, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore elite calypro CA error code. Plus makes
The CA indicates that an average current limit on the drive motor has been exceeded (see images below). This is an extremely hard problem to diagnose and one that I've seen cause the best service techs to pull their hair out. It can be one of so many different components, and you have to catch conditions just right to have half a chance to discover which one it is.
Try removing some of the clothes; this could be caused by overloading. You could have a mechanical failure in the universal joint, wiring harness, the drive motor, central control, or the motor controller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 11, 2010
F4e1 error
You can try resetting unit by disconnecting it from the outlet or by switching off the designated circuit breaker for 2 or 3 minutes, then restore power. If the reset doesn't work, I think you need to call a technician to properly diagnose
Jun 21, 2014 | Kenmore 24 in. 17482 / 17484 / 17489...
Error code F4E1 need reset
Turn off the power to the dishwasher for about 5 minutes before you power it up check that the water supply line is on. Also check for restricted drain area. Power it up and clear the power fail fault see if it works
Feb 24, 2014 | Kenmore 24" Built-In Dishwasher, Stainless...
Dishwasher f4e1
This is an error that means the controller is not talking to the motor. You need to check the connections on the motor
Feb 09, 2014 | Kenmore 665
CODE F4E1 will not go away
This error means that the controller cannot communicate with the motor. It is possible that something came loose when you replaced the clamp. Recheck all the connections .
Feb 09, 2014 | Kenmore 15322 / 15324 / 15329 Built-in...
Kenmore elite dishwasher has an error code f4e1
I had the F4E1 code on my Kenmore Elite 665x. This means a water leak. I eventually pulled the machine from the cabinet and noticed some water beneath the machine and the water pump hose loose. I reattached the pump hose using a new hose clamp and zip tied the pump in place to keep it from happening again. Afterwards I had to reset the machine by pushing the smart wash pots and pan then normal wash in sequential order 3 times then shut the door. The machine then does a diagnostic test. After the test I pushed the cancel button and it was ready to go.
Hope this helps someone else!
Nov 21, 2012 | Dishwashers
Du error code on a kenmore elite oasis he what does it mean and what can i di to fix the problem
Door unlock failure
retracting.
Jun 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Fl4 problem, kenmore elite won't spin or drain anymore.
EEPROM Error
The Central Condrol Unit (CCU) receives it's data from an EEPROMonboard the CCU.
If there is an error reading this data, it will cuse this error.
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
Check CCU
So its likely you'll need a new CCU board. Check your owners manual, some models have up to a 5 yr. parts warranty on that CCU.
May 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
42 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
