Question about Dometic RM2852 Refrigerator
Dometic tj80ac compressor won't kick in on 12 volt or 240 volt it tries to start but then won't
It use to do this when the battery voltage a got a little low but always worked on 240 volt shore power.
    Top Expert:
  • Dometic Master
  • 6,394 Answers
Bad start up capacitor or compressor
Posted on Oct 06, 2017
5 Suggested Answers
22yooper
  • 828 Answers
SOURCE: Dometic Caravan Fridge 7271
Your refrigerant may have completely separated in the system. Shut of the gas, disconnect the electrical and remove refrigerator from the coach or if you have sufficient room inside set it on a clean area. This operation is what is called burping the system.
1. From the base roll it onto the door and wait five minutes.
2. roll it onto the top and wait five minutes.
3. Roll it on the back and wait five minutes.
4. Return it to the base and wait five minutes.
Reinstall it or test it on electrical. It should show signs of cooling in about 30 minutes in the freezer compartment if the system is not plugged in the boiler.
Posted on May 26, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: My dometic frig will not work no power. Has 12 volt and 110 volts
Replace the bulb and also check the relay and the sensor in the back of the unit. But first try replacing the bulb
Posted on Feb 13, 2009
motor1258
  • 6674 Answers
SOURCE: cant find the fuse for the refrig. no power
Check connection for 12 volts, at back of fridge behind vent cover .(outside) Make sure 12 volts getting to the lugs where they join. If you have 12 volts to there, unplug fridge at receptacle usually on left side by back of fridge, just to be safe. Remove cover on circuit board and look for a blown (glass type fuse in there.)
Posted on May 09, 2010
motor1258
  • 6674 Answers
SOURCE: dometic s 1621 works on shore power but won't
What exactly happens when switched to propane? Have someone switch to propane while you stand by vent cover outside and listen for sparking when switched. Make sure it's calling for cool, as in maybe leave door open for a few minutes prior to trying. Let me know if you hear any "ticking" sound as if trying to light on propane.
Posted on Nov 13, 2011
The battery won't stay charged
Hi it is possible that you Alternator is faulty,if you have access to a VoltMeter ,check the battery voltage in the morning before you try to start it you should have around 12.7 volts for a charged battery if not fully charge your battery again and check the voltage with your car running you should have around 14 volts with the engine reving at 1500 revs.ifyou get around 12 volts then your lights are taking more power from the battery than the Alternator can replace.You could also get your local garage to Drop Test your battery to see if any of the Cells are faulty
Jan 11, 2013 | 1987 Volvo 740
Can my 240 volt compressor run on 208 volts?
Being an Authorized Service Center for a couple air compressor companies I can tell you I have replaced several 240 volt motors because they were run on 208 volts. Not knowing what model you have or what motor is on it, yes your compressor will run on 208 volts but it is very ******* the motor. At startup, all voltages have a dropoff then come back up to their rated voltage. The dropoff is determined by the original voltage and length and guage of lines getting the power from your transformer to the compressor With 208 volts it typically drops to around 190 volts at startup then comes back up to 205 to 208 volts while running. The motor needs the full 240 volts when it restarts and there is already pressure in the tank If the motor's not marked, call the manufacturer and see if it's rated for up to 240 volts or only for 240 volts.
Feb 08, 2012 | Craftsman Air Tools & Compressors
WON'T START CONTINUOUS BUZZING FROM SOLENOID
Sounds like the battery is dead. You can try a jump start and see if the car will start. If it does I wouldn't have any issue with replacing the battery and see what happens. You can also measure battery voltage with a voltmeter. You should see 12 volts with the key off, on, or cranking. If the battery voltage is not 12 volts than it is dead or low on charge. Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
Feb 02, 2012 | Mazda Cars & Trucks
A/C Compressor won't turn on Can jump compressor from battery and compressor comes on & cools. Hi pressure switch checks out ok and 12 volts going to hi pressure switch no voltage to compressor
the high pressure switch kicks the compressor off when the pressure rises, the low pressure switch kicks it on, check that switch, unplug the wire and use a continuity meter to see if the switch functions, also check for power getting to the plug itself
Sep 25, 2011 | 2002 Chevrolet Blazer
Servicing battery charging system. car won't start. 2006 chevy impala.
Check the battery terminals for cleanlyness and tightness.
Check the voltage when stopped, it should be 12 volts.
Check the voltage with the motor running, it should be 14 volts. If not the alternator is not charging.
If the battery voltage is low then it may need replacing.
Sep 05, 2011 | 2006 Chevrolet Impala
Won't start unless I keep a battery tender on it every time I park it kick start doesn't work either. This is in all weather from summer to winter,,it sucks. I did replace the battery within two...
have the battery draw checked, batteries can register 12 volts but thats idle voltage, when you use it, it creates a draw on the battery,, using amps , if you have a walmart near you they check them for free
May 20, 2011 | 2008 Yamaha Vino 125
I HAVE MY RV AC PLUGGED DIRECTLY IN A110 LONG EXTENSION CORD.....COMPRESSOR RUNS COLD 20 SECONDS THEN FAN ONLY 20 SECONDS THE COMPRESSOR BACK ON 20 SECONDS THIS REPEATS IT SELF OVER AND OVER IS THIS A...
Susan, I really couldn't tell how long the extension cord you're using is or the gauge wire of the cord. I suspect it was a type-O. In any event, for an A/C unit the gauge wire of the extension cord should be no smaller than a 12 gauge and should have a grounding plug. The length shouldn't be more 10 to 12' . Any longer and you may have some voltage loss, when the compressor kicks in (surges) to start cooling.
Hope this helped to answer your question.
Apr 19, 2011 | Dometic Rooftop RV Air Conditioner
PHO24-IB GODDMAN CONTACTOR CLOSES, RUN CAPACITOR HAS CORRECT MFD, OHMED/MEGAOHMED COMPRESSOR...BUT IT STILL DOESN'T START.
I assume that is a 240 volt unit. If you have a volt meter, check for power across the contactor . If it is a 240 volt unit you should get 240volts on both sides of the contactor. If you DO have voltage across the contactor (after it closes) you need to try and get to the compressor where the wires connect to it. There should also be 240 volts at the compressor terminals marked "C" and "R". If you have power at the compressor between C and R and the compressor is still not even trying to start, the compressor windings are open. Here is really what any tech will need to know to really help you:
(1) Is the fan motor running?
(2) what voltage is the unit?
(3) is the compressor humming or trying to start?
(4) do you have the proper voltage at the unit?
If you can answer these questions and you want to email me, do so and I will step you thru it. Be very careful , as you are dealing with high voltage.
Apr 14, 2011 | Goodman HDC24WMC24 Air Conditioner
Not working on 240 volts ok on 12 volts
The Dometic brand use separate heat elements for the different voltages. The heat elements are located in the back right hand corner (looking from the rear) about 6 inches up from the bottom. You will see 4 wires coming from the box, 2 for each element. They may be marked which is for each voltage, but if not an ohm meter will be needed to see which one is bad.
Apr 18, 2010 | Dometic Refrigerators
Dometic RM2852 Refrigerator Logo
133 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
