Question about LG WM-2277HW Front Load Washer
LG Tromm WM 2075 error code with standing water
Will not cycle. I tried washing 1 towel, water filled, started cycle and then stopped with error code.
  • 100 Answers
SOURCE: LG TROMM WM 2077CW LE Error
An LE error is a locked rotor. The hall sensor on the stator part of the motor is not sensing the rotor part of the motor is turning. So the short version is you need a new stator(which has the sensor on it or just the sensor) replaced which should have a 5 year warranty on it so call LG for your nearest authorized service center
Posted on Dec 05, 2007
BADBOYJAY
  • 264 Answers
SOURCE: LG Direct Drive WM-16220FD loud vibration during spin cycle
the pump hose is knocking if you can unplug the machine and tilt the machine on its back you can see the hose get a cable tie big one you can cable tie it down that would stop it from moving that's why its knocking if the pump is not on that side then your suspension leg is on its way out meaning you will have to call your local second hand shop to have a look but be for you do have a loo your self save money
Posted on Jan 05, 2008
SOURCE: lg tromm wm2277hw code de
Error Code "de" is for "door switch assembly faulty".
You can down load the service manual from this site:
http://136.166.4.200/contents/Laundry/WM2277.htm
Have fun!
Posted on Mar 06, 2008
  • 72 Answers
SOURCE: LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
Posted on Jun 19, 2009
jan mczeal
  • 632 Answers
SOURCE: lg tromm front loader washing machine display panel reading l-E.
error code 'IE' means water does not enter the detergent drawer..if your water is hard or contains traces of lime deposits, the water inlet filter may become clogged..regular cleaning is suggested..clean the filter using hard bristle brush..
note: hard water is the one not undergone any treatment..in other words it is directly from the ground through your water pump and to the washer.
Posted on Jul 19, 2009
UE Error Code on LG Tromm Washer
From back or underneath, check that all three shock absorbers are attached. Take top off and check if both springs are in place and un broken
Mar 22, 2017 | LG Tromm Front Load Washer And Dryer Set
I have an LG Tromm washer. I start it up it start
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jul 25, 2010 | LG WM0642H Front Load
I am getting an message LE. I am trying to wash
LE unfortunately is the fault code for a faulty Hall sensor or faulty Motor.The Hall sensor is attached to the motor. If you have or can borrow an electrical test meter the I can guide you throe the testing.80% of the time it is the Hall sensor.Hope this helps please reply for further help.
Jun 06, 2010 | LG WM-2277HW Front Load Washer
LG WM-2077C CODE LE
LE stands for locked motor error. Sometimes just unplugging it for about 10 minutes will fix it, but if not you will probably have to replace the motor position sensor(hall sensor) or the motor.
Dec 05, 2009 | LG WM-2077C Front Load Washer
Lg tromm front loader washing machine display panel reading l-E.
Jul 17, 2009 | LG WM-2277HW Front Load Washer
"FE" error code; won't stop filling
Hello Sheri Tucker,
The "FE" code is referring to a bad or malfunctioning water valve. The machine continues to fill because the solenoid on the valve inside the machine isn't closing to stop the water. The valve should be inspected and/or replaced if bad. This will require some dis-assembly, if washing machine repair isn't something your comfortable with then a service call is the best bet. If you are going to try and inspect yourself please make sure you unplug the machine before starting any dis-assembly. Hope this helps.
Thanks,
edgin96
May 19, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
"CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Sep 01, 2007 | LG WM-3677HW Front Load Washer / Dryer
LG WM-2277HW Front Load Washer Logo
114 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
