Question about Bell & Howell 357b Autoload Super 8 Movie Projector Vin
I have an autoload super 8 projector that I bought in the late 60's. I am unable to keep the film advancing forward once it has started. I have tried stopping and starting and reversing which is the only way it will go?
3 Suggested Answers
SOURCE: belle & Howell Super 8 Projector model 254RS loading problem
Don't have the motor switch in the still position when loading -make sure it is on FORWARD. Look at the little holes in the film and make sure the film is on the same side as the little grooves on the drive gear.
PS -let the bulb cool off before try to move the projector ,the bulbs are very expensive and hard to find.
If you do use the still position to view a frame do it for just a few seconds or the bulb will burn the film. Good luck- Tom.
Posted on Aug 12, 2008
  • 10 Answers
SOURCE: Bought a Bell & Howell Super 8 projector 481A
I found a web (D'Antiques Movie Projectors ) site for an 482a projector which is almost identical to the 481a projector. It had the information I needed.
You also dalled and provided a toll free number at which I may be able to purchase an owners manual.
Thank you
Posted on Dec 27, 2009
Will the bell and Howell model 256 dhow super 8 film
No it won't.
http://store.tvedenlampmodules.com/Vintage-BELL-HOWELL-256-AB-8mm-HOME-MOVIE-FILM-PROJECTOR-w-LAMP-CONVERSION-P5123061.aspx
To be crystal clear; This is a Regular silent movie projector. It will not run, or play Super8, or Super 8mm movie films, with or without sound.
Bell howell autoload 8mm projector user manual english
Dec 05, 2016 | Cameras
THREADING FILM IN A ELMO FP-C PROJECTOR
Is your film super 8mm? If yes, then the red sprocket above the lens should be pushed in, and the bottom black sprocket will stick out. If you have regular 8mm, then the black bottom sprocket should be pushed in. If the sprockets are not in the correct position, push the green lever forward (towards the screen) then open the two orange tabs, then push in the correct sprocket. Once you have the correct sprockets aligned, close the orange tabs. How to tell if you have 8mm or super 8mm film: Look carefully at the film image. If the sprocket hole is next to the middle of the image, it's super 8mm. If the sprocket hole is between images, it's 8mm.
Jan 10, 2013 | Sewing Machines
HAVING TROUBLE THREADING FILM - ELMO FP-C
Is your film super 8mm? If yes, then the red sprocket above the lens should be pushed in, and the bottom black sprocket will stick out. If you have regular 8mm, then the black bottom sprocket should be pushed in. If the sprockets are not in the correct position, push the green lever forward (towards the screen) then open the two orange tabs, then push in the correct sprocket. Once you have the correct sprockets aligned, close the orange tabs. How to tell if you have 8mm or super 8mm film: Look carefully at the film image. If the sprocket hole is next to the middle of the image, it's super 8mm. If the sprocket hole is between images, it's 8mm. If your green lever is stuck in the forward position, that's because the film is not threaded. Once your film threads correctly, the green lever will spring back.
Bell & howell 356 projector runs slow
You have this posted in the car and truck forum, please re-post in the correct product category.
Feb 21, 2012 | Cars & Trucks
Eumig 610D Super 8 projector take-up reel not engaging at hub so will not rotate. Hub will rotate, not the reel. Perhaps worn key?
I think the Eumg 610D was a dual guage projector, capable of showing both Standard 8 and Super 8 films. (I'm basing my comments on the S810D I have in front of me, its sound "big brother").
To move between formats, there were two cogs internally that had to be changed, a film gate (two parts), and two adaptors/liners inserted into the centre of the film reels that transformed the centre from "a fat one" to "a thin one".
If the take up driver cog is rotating, but the reel is not, check whether the adaptor is in place.
You can see what they look like on eBay....
http://cgi.ebay.com/NEW-Super-8-Movie-Projector-Reel-Adapter-Film-8mm_W0QQitemZ170450331975QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item27afa1a947
If the rear driver cog is not rotating, then it might be a worn/defective drive belt, in which case leave a further comment and we'll explore that.
Hope this helps
Jan 02, 2010 | Cameras
I am looking for a free manual for the Eumig Mark 8 Projector. I have an old projector and want to show film of my late mother. Film is original 8mm film 'not' super 8mm. Unfortunately I do not know how to...
was there any chance of me getting a free manual or is this site just a money making idea, obviously if it sounds too good to be true..it usually is!
Sep 14, 2009 | Cameras
I have a Bell and Howell Model 456 Autoload Super8/Regular 8mm Projector bought in 1969. During projection, when the very end of the advancing film is no longer engaged by the rotating teeth, the film...
The Bell and Howell Model 456 Autoload was made that way ON PURPOSE. The last foot or so must be manually pulled from the projector. As described in the manual, "this safeguard has been designed to prevent the end of your film from flapping against the projector after your movie is completed."
If the entire film was going into the take up reel at the end automatically, then THAT was a defective occurence. It is not supposed to do that.
Apr 04, 2009 | BenQ (200NSH-LAMP) Projector Lamp for...
Belle & Howell Super 8 Projector model 254RS loading problem
Jun 21, 2008 | Bell & Howell Photography
Downloadable instruction manual for Bell Howell 456 super 8 mm dual movie projector
May 20, 2008 | Photography
Bell & Howell 357b Autoload Super 8 Movie Projector Vin Logo
Top Bell & Howell Video Cameras Experts
abdul rauf
abdul rauf
Richard Lane
Steve
Are you a Bell & Howell Video Camera Expert? Answer questions, earn points and help others
