Question about Pacific Laser Systems PLS Laser PLS-60570 PLS HLE 1000 Kit, Red/Yellow from Pacific Laser Sy
HOW DO I CALIBRATE PLS HLE 1000 - Pacific Laser Systems PLS Laser PLS-60570 PLS HLE 1000 Kit, Red/Yellow from Pacific Laser Sy
I have a accugreen 1000. The wire for the settings has gone slack and I can't adjust the settings. It just stays open. How do I fix this.
You can try to calibrate the spreader, tightening the screw at the end of the control wire should fix the situation. If calibrating the spreader does not help please call us at 800-543-8873 for more assistance. To Calibrate the Accugreen 1000: 1. Adjust the micrometer setting to a 6. 2. Flip the spreader over. 3. Use your foot to squeeze the trigger against the handle. 4. The front edge of the shutoff bar should be aligned with the calibration line engraved on the bottom of the hopper. 5. To adjust the alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer insect.
Jun 13, 2011 | RTO Accugreen 1000 Drop Spreader
I have acer n30 pc pocket. when i connect the usb cable for chasrging it dosen't get start and i can see the message on the scree "align screen" so what is a exctly solution pls tell me...
This happens when you get new one or after reset. It wants from you, to touch 5 points on the screen to calibrate touch screen.
Start acer without connecting usb cable and calibrate it first.
Jun 10, 2011 | Acer n30 Pocket PC
How do i calibrate a PLS 180 laser
the pls is a pendelum system you need to open it from the rear and shift the weight it is usually a set screw that you turn in or out to change the resting pointof the pendulem
Feb 26, 2010 | Pacific International Pacific Laser...
How do I calibrate my touch screen
Calibrate the g1 touch screen on the device by going to Start>Settings>System Tab>/Screen then Click Align Screen If you cannot get to the Screen Alignment utility using the menu’s, it can also be accessed by pressing the Volume Up and Center Navigation Buttons at the same time.
hope this helps, pls appreciate by rating as fixyaa
Jan 13, 2010 | HTC G1 Smartphone
My harmony touchscreen remote is working intermittently. sometimes taking out the batter works but it is not working now.
try recalibrating the lcd. to do this, please follow the steps below:
One can incorrectly calibrate the remote by pressing areas on LCD other than the ones marked during the calibration process.
Solution
To re-calibrate a remote which has been incorrectly calibrated, please follow these steps:
  1. Put the remote in safe mode.
    1. Remove the battery
    2. Hold down the System Off button on the remote while inserting the battery back into the remote
    3. Continue to hold the System Off button until the remotes LCD has lit up and reads Safe Mode
    4. Let go of the power button
  2. Reboot the Remote
    1. Remove the battery once more
    2. Re-insert the battery
  3. Follow the calibration wizard on the Remote to re-calibrate it by pressing on the areas indicated.
Jan 12, 2010 | Logitech Harmony 1000 LCD Touchscreen...
How do I calibrate my acugreen 1000 drop spreader?
The spreader comes already calibrated. The opening of the gate is determined by the setting that you input from the handle. This will correspond to the recommended settings provided on the fertilizer bag.
Best regards, --W/D--
Aug 09, 2009 | RTO Accugreen 1000 Drop Spreader
Note callibration
no all HD TVs have note lagg
to calibrate the guitar simply click the options in the main menue
and click calibrate
follow the instructions an voila
pls rate.
Dec 14, 2008 | Nintendo Guitar Hero Wireless Guitar - Wii...
Error / Ribbon Jam/Broken
When you open and close the lid on this printer, it tries to realign the ribbon. If you are getting this error, I suggestion you Calibrate the print ribbon through the print driver printing preferences on the Calibrate tab.
Dec 12, 2008 | Fargo DTC550 Thermal Card Printer
Pacific Laser Systems PLS Laser PLS-60570 PLS HLE 1000 Kit, Red/Yellow from Pacific Laser Sy Logo
87 people viewed this question
Top Pacific Laser Systems Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Pacific Laser Systems Measuring Tool and Sensor Expert? Answer questions, earn points and help others
