Question about Smoothfitness Exercise & Fitness
How to change from km/hr to mph on smooth 7.1hr treadmill
The speed indicator is in Kilometers and I'd like to be able to switch it to Miles per Hour.
  • 61 Answers
SOURCE: Changing from mile per hour to km per hour
okay,for one,the odometer doesnt read in miles per hr,it reads miles driven, and two i have no idea if its possible to change the odometer to km traveled,if you're talking about the speedometer,its already there,get a european cluster :p
Posted on Aug 10, 2008
  • 2712 Answers
SOURCE: Km to Mph for 04' GG 450FSE
Copied from the manual. You can download it here: http://www.gasgasmotos.es/rcs/manual...04_fse_eng.zip Quote: To change to kilometers per hour or miles per hour: - Disconnect the battery. (the total distance will be saved). - Re-connect the battery whilst holding down either button and it will read either; met -- for km/h mil --- for mp/h - The white plastic block connector on the speedo is for the display backlight. - The red wire is positve. - The black wire is negative. - Warning; your speedo is set for the diameter of your front wheel enduro 21 supermoto 17 If you get the display to read a 00 then you are in the rolling radius changing mode. you can trim the speed to run fast or slow. It ranges from a-25 to a 25. NOTE Standard setting is a 00 we recommend you keep it at that. 0.0 Trip distance 0000,
Posted on Nov 10, 2008
SOURCE: how to change mph to kmph
ther is 1.6 kilometers to a 1 mile
Posted on Mar 25, 2009
SOURCE: distance screen on treadmill
It's in Miles The treadmill goes a max of 14km an hour - if you increase the speed it only goes to 8 - 14km per hour is 8.4 miles per hour and I've been running between 5.5 and 6.5 and covering 3 miles which would be about right :) Hope this helps
Posted on May 27, 2009
SOURCE: pro form 520 treadmill
I know this thread is a little old, but did you get your treadmill working? I have a 550e that does the same thing. The company has sent me 2 controller boards, but still doesn't work.
Posted on Jan 27, 2010
If 360 km per hour is equal to 40 miles per hour, please show me how to calculate using formular
360 km/hr is NOT 40 miles/hr.
1 mile is about 1.6 km
To go from km to miles, multiply by 0.62
To go from miles to km, multiply by 1.6
Kilometers per hour to Miles per hour
Feb 23, 2017 | Cars & Trucks
Changing kilometer from mile on afg 7.1at treadmill
Hi there. I add the same problem as well. Below are the steps I used to fix my problem.
In order to switch your distance calculation between miles and kilometers, please follow these instructions:
  1. Turn on treadmill, put safety key in place
  2. Press and hold the INCLINE + and SPEED - keys for about five seconds or until machine beeps three times. En90 or Eng0 should appear.
  3. Use the SPEED + key to navigate to En93.
  4. Press ENTER once.
  5. Press START to choose unit (miles or km). The display will change accordingly.
    1. Miles: 0
    2. Km: 1
  6. Press and hold STOP or exit and replace the safety key to return to the normal start screen.
NOTE: To be sure that the treadmill is displaying your desired unit, simply press START and observe the first start speed to display. If it displays 1 or .5, it is in miles. If it displays .8 or 1.6, it is in kilometers. Also note that by changing in metrics the Lbs will also convert to Kg.
Hope this help.
Dan
Dec 25, 2012 | AFG 7.1AT Treadmill
Distance 1.00 equal 1 mile
Dear Sir:_
I will try to help you.
Please check this:
It is simple to change your treadmill so it reads MPH.
Treadmills are an easy and relatively inexpensive way of maintaining physical fitness. Most modern treadmills have a readout on their console that will track your speed over time in kilometers per hour or miles per hour. If your treadmill came with the wrong setting, it is possible to toggle between these two settings.
Instructions
Things You'll Need
  • Pencil
Oct 19, 2011 | Weslo Cadence 55 Treadmill
What is the speed of an automobile in kilometers per hour if it is trveling 45 miles per hour?
There are 1.609344 kilometers in 1 mile. So you can just put it this way.
45 miles x 1.609344 kilometers
1 mile
The answer is 72.42048 km or just 72.42 kilometers
Therefore the automobile is traveling 72.42 kilometers per hour.
Hope this helps.
Jun 27, 2011 | Casio FX-9860G Graphic Calculator
How would you convert 40.32 km/hr to m/sec
There are 1000 m in a km and 3600 sec in an hr. Thus, multiplying 40.32 km/hr by 1000 m/km gives 40320 m/hr. Dividing this by 3600 sec/hr gives 11.2 m/sec.
Of course, the two operations can be done in the other order.
Some calculators have unit conversions built-in. Without knowing the make and model of your calculator, I can't tell you whether yours does so or not, let alone tell you the keystroke sequence to do it.
Jun 09, 2011 | Office Equipment & Supplies
Grace walks 80m in one minute. how far does shewalkin one hour in kilometers
First we look at the constants that we know. First we know 1 m = .001 km so, 80 m = .08 k. Second we know 60 min = 1 hr or 1 min = .016667 hr. So, plug in piece by piece what we know 80m per 1 min = .08 k per 1 min = .08 k per .016667 hr. this can also be written as .08/.016667 k per hr which is 4.8 kilometers per hour.
Apr 05, 2011 | Sharp EL-1701C Calculator
Is the Welso Cadence 927 Treadmill in miles or Km?
hi, the console can display speed and distance in either kilometers or miles!
step 1/ move the key and hold down the stop button.
step2/ reinsert the key into the console, after you hear a bleep tone release the stop button and an "m" for kilometers or an "e" for english miles will appear in the display. press the speed in-crease button to change the unit of measurement.
step 3/ when you have chosen the miles take the key off and reinsert it. hopefully you should have changed your units to whatever you have chosen.
Nov 08, 2010 | Cadence Weslo 927 Treadmill Walking Belt
How do i change from killgrams to miles per hour
Do you mean kilometers to miles ? 1 km = .621 miles
rule of thumb, 100km/hr = 60mph.
80km/hr = 50mph.
Apr 04, 2009 | 2006 Cadillac STS
Nov 10, 2008 | 2004 Gas Gas EC 450 FSE
Jul 05, 2008 | 2003 Mazda Mazda6
Exercise & Fitness Logo
98 people viewed this question
Top Smoothfitness Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Smoothfitness Exercise and Fitnes Expert? Answer questions, earn points and help others
