Question about Razor USA Razor Pocket Mod Electric Scooter
Light on power switch still not working
This thing was given to us hardly used ...don't know if I need a new battery...saw that it could be a fuse going to check that tomoroow.
    New Friend:
  • 26 Answers
Recharge again the battery and if it still doesn't start, then buy new one to replace.
Posted on Sep 01, 2014
    Genius:
  • Razor USA Master
  • 1,508 Answers
Do you own a multimeter to check the voltage output from the battery
Posted on Jan 17, 2013
What did I do
You have bypassed the underhood fuse boxes power supply from the battery. Use factor battery cables routed correctly DON'T "ROOT OBERG IT"
Apr 26, 2013 | 1997 Mercury Grand Marquis
Proform elliptical 820 left sitting for months in florida room but worked fine before, batteries replaced, now the rpm's don't show and programs won't start. i have a feint memory of havin
1) replace by new batteries with the same type fulll charge, with the same mark, with the same polarity
2) clean the contacts batteries with contacts cleaner for a dirty, corrosion, etc
3) adjust the REED switch, test it, clean it, and tight any plug or connector.
4) tight the ribbon cables for keypads good connection.
Try again.
Of course you must know the power cord is o.k the c. breaker you must reset and some fuse is o.k o replace see the b.diagram
God bless you
Nov 19, 2012 | Exercise & Fitness
1996 Camry reverse lights don't work
Check if you are getting power to the reverse light switch. Turn ignition on, disconect terminals to the switch and check for power on the positive terminal using a light bulb or a test meter whatever. If power is there jumpthe 2 terminals and check if light backup light works. If it does replace switch. If ther is no power at switch check wiring from fuse box. If light does not work when switch is jumped check wiring to back.
Sep 11, 2012 | 1996 Toyota Camry
I just purchased a 2006 Navigator and the button to lower the rear seats, does not work. I don't have manual yet, and don't know how to check the fuses, or if this is even the problem...
locate the fuse box under driver side instrument panel,use a test light hook clip to ground and probe each side of each fuse test light should light when you touch or probe top both side of fuse test light should light.if one side dont light fuse blowed both sides light fuse good.also use test light see if power at the switch if yes problem in the seat motor lower mechanism.
Sep 01, 2012 | 2006 Lincoln Navigator
Blade continues to spin after turn off
I don't know the make or model of your saw but the blade brake on circular saws is controlled by the power switch. If your saw previously did brake the blade rotation, you need a new switch to make it work again. Also a generic switch will not do, you have to have the brake switch made for your saw or it will do the same thing.
Apr 07, 2012 | Saws
Where is the fuse for power windows on 1997 Rav4?
Well the thing is, it's not a fuse issue. If the drivers side works but the passenger and rear windows do not you most likeley have a bad master window switch (drivers side front). I now that it sounds odd but the only common thing with the remaining windows that are not working is the ground source located in that main switch. You can check to see if there is a ground from that switch but this may be a litle confusing. If you are able to remove that main switch in the drivers door but leave it plugged in here is how you check for a ground. Get a test light and connect the "alligator" clip part of it to a hot (positive) wire or terminal. In the back of that plug stick the "pointy" end of the test light into different wires. The wires you will want to check is the green & red one, The blue and white one, The red and yellow one, the red and blue one, the blue and black one and the blue and red one. If none of those wires makes the light turn on it means you do not have the ground you need. You have constant power but want makes the windows go up and down in the switches is a ground. All the windows get power from the same place so that's why I say it's a grounding problem since the drivers window is working and Like I say the only common source is in that switch. I hope I didn't confuse you with this but this is the best way I can explain it to you at this point. If you have questions or need this more detailed with some pictures, email me at csautomotivecars@att.net and I will do my best to help. No there will not be a charge if you email me. I don't mind helping and I am an automobile electronics specialist and sometimes it's hard for me to put it in plain nontechnical terms. Please remind me of your problem and what we are working on if you do write. I hope I was able to help at least a litle bit as to your problem.
Nov 27, 2011 | 1997 Toyota RAV4
I put 3 brand new batteries in and it still don't start not even a light will come on. Don't know what to do please help.
I have two post for your problem. In one post you say that you have installed three new batteries in your bike. All of them have have been pulled down to completely dead but you didn't say how long it took to do this. Also, not lights or anything will work on the bike. Evidently you have a serious electrical problem to say the least. If this is the case, you should be getting a tremendous spark whenever you're trying to connect the new batteries. Look behind the triangular plate on the left side of your bike and see if the fuse panel is behind the plate. Take all the fuses out and then reconnect the battery. When you connect the battery, notice if you get a spark. If you have taken the main fuse out and you're getting a spark, you have a direct short between the battery and this fuse panel. There is only one wires that goes from the battery to the fuse block. If you don't get a spark, put the main fuse back in and then the other fuses one at the time. When you go to put one of the fuses in that creates a large spark, this is the circuit that is draining your battery. You'll need a schematic to determine what electrical equipment is on this circuit. You'll have to trouble shoot each piece of equipment to find the one that is draining your battery. When doing this test, leave the ignition switch off because you should be leaving the switch off when you're not riding the bike.
Good Luck
Steve
Sep 18, 2011 | Harley Davidson XL 1200N Nightster...
1997 eclipse dash lights not working i know there are two fuse boxes i dont know which one o look at and which fuse it is help?
Your tail lights, license plate ights, and side marker lights are protected by the same fuse that supplies power to the dash lights. Hint: if your other lights are working, the fuse is NOT blown and you don't have to spend time looking for it.
The next thing that deserves mention is the fact that the dash lights are controlled by the dash light rheostat (dimmer switch). Make sure you don't have them turned off with the switch.
If after reading the above, you still think you need to find the fuse, it is fuse #5 (15 Amp) located in the dedicated fuse and relay box in the engine compartment. It is most likely marked "Taillight Relay".
Please also review the following articles:
Where's The Fuse?
What Else Could Be Wrong?
Sep 18, 2011 | 1997 Mitsubishi Eclipse
Reyjoshua07 suggested (determine which wire is in the trunk by disconnecting connector. I did all this and alarm goes off any given time day or night and now i have to remove battery cable. DISTURBING...
i can not use private chat some thing wrong with it you need to find the alarm and cut the power to it or look in the owners manuel and find out what fuse turners it off i no you have motion detectors and ill bet the micro switch that is in the motion detector is bad most times you will find the alarm under the hood i don't no what kind you have so its hard to tell you where it is
hope this helps you
bob
May 19, 2011 | Cars & Trucks
Razor USA Razor Pocket Mod Electric Scooter Logo
132 people viewed this question
Top Razor USA Toys Experts
Adam Fjeld
Adam Fjeld
Steve P
Steve P
Are you a Razor USA Toy Expert? Answer questions, earn points and help others
