VAIO VGN-SR13GN fails to boot
Hello, I have a problem with my VAIO VGN-SR13GN. When I try to turn on my Notebook, It's suddenly crash. I'm trying to open recovery setup on the Computer , but the Laptop Fails to Boot and the BIOS Screen doesn't Appear. How to fix it?
mrd00d
  • 36 Answers
SOURCE: my IBM t30 wont boot up
Use Knoppix to save your data if you need to, otherwise it sounds like you may need to reinstall the OS.
ftp://ftp.uni-kl.de/pub/linux/knoppix/KNOPPIX_V5.1.0CD-2006-12-30-DE.iso (to download Knoppix 5)
You could try using the recovery console, as previously mentioned as well. If you don't need to save data, just blow it all away and reinstall XP.
RESOLUTION loadTOCNode(1, 'resolution'); If it be the connector cable problem then replace the 40-wire cable with an 80-wire UDMA cable.
If it's a BIOS settings problem then load the 'Fail-Safe' default settings, and then reactivate the most frequently used options such as USB Support.
If it's a damaged file system case then:-
1.Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.At the command prompt, type chkdsk /r , and then press ENTER.
6.At the command prompt, type exit , and then press ENTER to restart your computer.
This takes a bit longer, but the system should boot back into Windows.
Posted on Dec 21, 2007
rockitman187
  • 2559 Answers
SOURCE: Vaio Recovery Center not working
If the hard drive is full, clear some space.(run disk clean up)
locate and empty the TEMP folder.
Then
  1. Click Start. Point to Settings, then click Control Panel.
  2. Double-click the System icon in Control Panel.
  3. Click the Environment tab in the System Properties dialog box.
  4. In the Variable edit field, type TEMP.
  5. In the Value edit field, type the folder name that will receive temporary files. For example, C:\TEMP (if the TEMP folder exists on drive C).
  6. Click OK.
Please rate this a fixya
Posted on Feb 01, 2009
  • 26 Answers
SOURCE: can't boot and forgot bios password on ibm r50e
You need to remove, or short, the cmos battery. I'll be on the motherboard somewhere, possibly under the keyboard. Remove all screws, carefully, slide back any tabs on the keyboard and carefully remove. Only do this if your warranty has expired.
Posted on May 15, 2009
SOURCE: ASUS EEE 1000H fails system recovery procedure
Shut down Comp. Hit F2 continually whilst powering up. Now go to boot up and make dvd boot first choice.
Save the settings and exit.
Unit will auto start restore.
Follow actions and don't try to rush things.
Posted on Jul 27, 2009
micromend
  • 748 Answers
SOURCE: Sony Vaio VGN-NR498E recovery disk
Hello
Well, the recovery disks won't allow you to go to your present system. The recovery disks are designed to put everything back the way it was when you bought the computer, minus all your applications and data. If it's your data that you need then a reputable repair service like mine can slave your hard drive to another system and recover all your data (not applications), provided the hard drive has not electronically or mechanically malfunctioned. Again, a reputable repair person can tell you the status of the hard drive.
Thanks
Posted on Jan 07, 2010
System recovery
Try holding alt + F10 at boot. See if this starts the factory restore process.
Jun 14, 2013 | Sony VAIO VGN-NS190J/L 15.4-Inch Notebook...
Stop error on sony vaio vgn-nw235f
There are multiple possible reasons for your problem:
1. virus
2. hard-drive malfunctions
3. OS malfunctions
4. memory failure
Try to install an antivirus and do a deep scan. You should pay attention to a boot sector virus.
If this doesn't help, do a back-up of your data, format your hard disk and re-install a fresh OS.
If this doesn't help either, try changing the RAM memory.
If that doesn't help either, it means your hard disk's boot sector is damaged. There are solutions for this too, but I think there is a big chance you won't get to this point.
Aug 07, 2012 | Sony NW Series VAIO VGN-NW235F PC Notebook
Error 58 unable to write to boot sector
Run CHKDSK, if you see a message "The drive contains one or more unrecoverable problems", you need a new hard drive.
If you cant get on to Windows try a fresh install. If that fails buy a new HDD should fix it.
Nov 26, 2011 | Sony VAIO VGN-A230P PC Notebook
Sony VAIO VGN-CS110E won't boot
yes it is the problem you need remplace the mothersboard because lucks like your motherboard is damage
Nov 25, 2011 | Sony VAIO VGN-CS110E/Q PC Notebook
Hello, I was working with my sony vgn-ns110e for 5 hours and all of the sudden the laptop shutdown. It does not turn on anymore and there's no light either in the power, batt or hd.
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The power button could be bad
5. The motherboard could be defective & needs to be replaced
Sep 17, 2010 | Sony VAIO VGN-NS110E/W Notebook
Hi I have a VAIO VGN-T350P laptop. The windows crashes and won't boot up and give me to insert the original Windows CD. But unfortunately I have lost the cd and I should use the recovery disk. Also I...
Go Into The Bios Change The Boot Status To Either Cd Or Usb Try To Boot up On That (Sounds like You Need a Copy Of operating System)What version need more Info !! Im here To Help Donald Deane MCSE,ASE,CPO
Jul 26, 2017 | Sony VAIO VGN-T350 Notebook
Screen/graphics problem, distortions & low res issues
It is not a driver failure but it is a hardware failure. I have my own fz340e and have the same problem as yours. Now, my fz340e works fine.
Apr 02, 2010 | Sony VAIO VGN-FZ340E/B 15.4" Notebook PC...
Can't restore factory intallations and settings: Vaio VGN-FE880E
Are you doing DESTRUCTIVE recoveries or are you doing NONDESTRUCTIVE recoveries? Try another hard drive in the machine and recover to that. Nondestructive recoveries replace the operating system without destroying the personal data. Its possible the original problem is propagating over to the recovered systems. Do a destructive recovery. Understand any data not backed up will be destroyed. Possible the original problem was a trojan virus.
Mar 23, 2009 | Sony VAIO VGN-FE880E/H Notebook
Sony VAIO® CR VGN-CR220E system crashed can Vista be re-installed
Yes there is, but you must know the correct combination of keys to press on boot up.
Mar 10, 2009 | Sony VAIO VGN-CR220E/P Notebook
VAIO Notebook VGN-FS742/W is not booting
sorry to let you know sounds like hard drive is shot.........
Jan 05, 2009 | Sony VAIO VGN-FS742/W Notebook
Computers & Internet Logo
David Payne
David Payne
