Question about Talon Rotary Lawn Mower
How to reassemble throttle parts?
I removed the top piece to unjam the pull cord. Got that fixed. But as I was doing this I dislodged a spring from the throttle mechanism. Do you have a diagram that shows how this is supposed to look, especially, where the spring is supposed to go? Thanks, Phil
The start pull handle is out , how to fix it
The pull start cover rope & spring will need to be removed. it may be bolted on or riveted on if rivets drill them out when off you'll see the problem spring dislodged or broken rope broke repair & reassemble. watch as spring is tricky to wind up..
Apr 08, 2011 | Champion 2.4 HP Gasoline Generator
How do you remove the outside piece so that you can replace the recoil starter?
There should be 4 screws, 2 back by the throttle end and 2 near the muffler end. Some models will require removing the top cover to access the top screws and/or remove the recoil. Either way the top cover will coe off with either 2 or 3 screws on th corners of the cover.
When removing the recoil be careful that the spring doesn't fall out of the assembly. This can make for a very difficult reassembly.
Sep 22, 2010 | Garden
I need to clean carburetor on 340gx honda pressure washer. How would I do this?
pour large amounts of liquid carb cleaner into the gas tank
Let it run for a couple of minutes then shut it off and let it sit for a couple of days.
Aug 16, 2010 | Honda Garden
I need to rewind the spring and starter pull cord. I need to understand how all the parts fit together
I had the same problem. I had to take it apart and rewind it manually. To do this:
Step 1:
There are 4-bolts to remove on the orange plastic section the screw into the motor housing (one of them is hidden inside the orange plastic housing, you'll see an opening for it). There are also 3 screws in the black plastic exhaust housing that screw into the orange plastic housing, find those and remove.
Step 2:
Carefully remove the engine from the plastic housing. I didn't disconnect the throttle cable or the electric wires (points) just kind of worked around them.
Step 3:
The mechanism is kind of crappy. There are two black pieces with a spring in the middle, and a metal disc on the bottom with a ribbon coil on the underside of it. The top plastic piece is what turns the flywheel when you pull the cord. The spring in between connects the two plastic piece. This is probably what popped out. There is a piece sticking up on one end, which inserts into the hole in the top black plastic piece. If you remove the little guardrail things you can probably remove just that piece. KEEP TENSIONS ON THE PULL CORD. Once you remove that top black piece, it should start to recoil.
Step 4:
If it did recoil, put the spring back in the top plastic piece, and then put the plastic/spring combo back into the the bottom plastic piece, there is a little groove for the bottom of the spring to slide into. Then put the little guardrail screws back on. Make sure the big metal wire thing hasn't slipped down into the shaft of the weed whacker. That needs to go back into the motor, as it is what gets spun and in turn spins the strings. As you start to put the motor back in, you may have to pull on the pull cord a few times to get the flywheel and plastic piece to line up. Once you hear the motor start to catch, then you should be able to wiggle it back into place and put back all of the screws. Then give it a shot. If it pulls out again, you may have to drill a new hole into the top black plastic piece for that spring to slide into (this is the crappy design part).
Step 5:
If the pull cord didn't retract, you need to remove the other two pieces (lower black plastic piece and metal disc with ribbon). The metal ribbon has a nub on the outside that hooks onto a plastic piece in the bottom of the orange plastic housing. You'll need to wind it around once or twice to "charge" the ribbon, then wind the string back on the black plastic piece. The black piece should slide into the center of the metal disc and catch the inside of the ribbon. Once you get these two together, again, make sure the metal ribbon piece is wound once past normal and then you have to slide both parts together down into the housing catching the metal ribbon loop over the orange plastic nub. It's tricky, it took me a few tries. Once you get that you can try and test the pull cord, you'll see it pull out and feel it retract due to that metal ribbon. Then go back and do step 4, where you put the upper black plastic piece with spring back into place and replace the little metal guardrails.
This whole thing took a few tries, and the pull cord still gets stuck out. It's a major pain to say the least, but after the 5th time fixing it, you'll be a real pro.
Aug 16, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Trimmer Pull Start Cord
The part no. for the Spring and container is A98773A. You can Google the PN and find many sources. Expect to pay between $10.00 to $15.00. I like m-and-d.com If they have it in stock you will normally get it in 3 to 4 days.
Mar 25, 2009 | Homelite Mighty Lite Lawn Trimmer
S3765
Returned the sweeper to Costco for a full refund and bought another.
Sep 08, 2008 | Hoover S3765-040 WindTunnel Bagless...
Does not spin
there is a coupling between the motor and gearbox, that fails.
it is a simple repair, and well worth trying
remove cabinet
  • pop off edge trims from control console
  • remove screwss from under edge trim
  • slide console forward and up ~1inch
  • flip the console over the back of the washer, the hinges are plastic and a little fragile
  • remove brass clips holding cabint inplace remember how they fit
  • lift cabinet ~1inch and remove forward
repair coupling
  • motor gearboxpump is at front bottom center
  • remove lock screw from clip holding pump to motor
  • remove two spring clips
  • pull pump off motor and swing sideways on hoses, tie off to left with a string
  • remove lock screw from clip holding motor to gearbox
  • pull motor off rubber coupling
  • pull nylon spider off gearbox shaft
  • pull nylon spider off motor shaft
  • install new spiders to shafts. Use a hammer to strike a wooden dowel on the center of the spider, dont hit the legs of the spider they break off
    Note the new coupling spiders have metal centers to stop further breakage, common fault
  • turn gearbox spider 1 leg up two legs down
    turn motor spider , 2 leg up 1 leg down so the spiders will interlock
  • install new rubber coupling on gearbox spider, install motor on coupling.
reassemble all clips and screws in reverse order
reassemble case in reverse order
on reassemble ensure plastic level sensing hose is not dislodged from water level switch body
takes longer to type than to do the repair
at parts store "Kenmore gearbox coupling" will get the correct part
Sep 07, 2008 | Kenmore 23822 Top Load Washer
Door falls open
I have had this issue TWICE now on a three year old dishwasher, and Sears charges you $150.+ to fix it. It is quite simple to fix, there is a special part that has all the pieces attached to it, except for the spring. You will have to remove the screws that are holding your dishwasher under the counter. This could be behind the rubber on the sides. I had to remove a gray plastic circle piece on the inside to see the screw (it pops right out, don't loose it!). Pull out the machine enough to see the out side- side. You will see a (plastic) white roller, string(rope), and a piece that attaches to the dishwasher. There is a number on the white plastic piece that looks like a L (it just slides out). Thess pieces are called the Dishwasher Door Balance Link. You will need to order these pieces, they are all inclusive, and come for both sides of the door, at a whopping price of $15.00. VERY simple to install. Attach one end to the spring, line up in roller then attach to the dishwasher. It is easier to look at it and follow what is on the dishwasher than me clearly explaining it. I feel that paying $1000.00 dollars for a dishwasher would warrant using metal pieces instead of substandard plastic, for this application. These door are very Heavy and like I have said I have replaced them twice with a waiting time of three weeks for the repair man. Please try it, you can do it.
Dec 26, 2007 | Kenmore 24 in. 16492 / 16494 / 16499...
Retractable power cord
JUST LIFT OFF THE TOP HALF. CAREFULLY REACH IN FROM THE LEFT SIDE AND DISCONNECT THE CLEAR PLASTIC HOSE THAT IS ATTACHED TO THE "DIAL" ON TOP OF THE MACHINE. THEN LAY THE TOP HALF OF THE MACHINE TO THE RIGHT. DON'T DISCONNECT ANY WIRES. YOU'LL HAVE TO HAVE A NEW CORD WINDER (LOOK ON E-BAY). THE MOTOR AND CORD WINDER ARE ATTACHED TO EACH OTHER BY WIRES AND CAN BE LIFTED OUT OF THE CANISTER.EVERYTHING YOU DO JUST REMEMBER THAT ALL OF THESE PARTS ARE ATTACHED TO EACH OTHER BY WIRES. THE ONLY WIRES YOU'LL NEED TO DISCONNECT ARE THE ONES ATTACHED TO THE CORD WINDER ASSEMBLY. THEY JUST PULL OFF, NO TOOLS ARE NEEDED.
QUITE FRANKLY THIS IS A ROYAL PAIN AND YOU'LL PROBABLY WISH YOU TOOK IT TO A REPAIR (AERUS/ELECTROLUX) SHOP. IF YOU DECIDE TO DO IT YOUR SELF TAKE PICTURES OF EVERY STEP...'CAUSE YA GOTTA PUT IT ALL BACK TOGETHER.
GOOD LUCK!
Sep 08, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux Lux 7000 retractable power cord
The trim pieces along the sides just pull off seperating the two housings. The back portion where the retract drum is is held by two plastic tangs on top inside. use a screwdriver to pry the ring down to dislodge the tangs. the bottom part will lift off. remove the front part using two screws just below the hinge. the retract has a long coil spring wound around a free spinning hub. there are two "tangs" inside that engage a ratchet-pawl assembly. you'll need to rotate the drum to rewind the spring onto its hub.
Jun 06, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Talon Rotary Lawn Mower Logo
27 people viewed this question
Top Talon Garden Experts
Gil Shultz
ray gallant
Bill Boyd
Are you a Talon Garden Expert? Answer questions, earn points and help others
