Question about youtube.com
Korg pa80 the screen showing opreting system please wait
And going blank screen
HOW CAN I RELOAD THE SYSTEM MY KORG D 3200 WITHOUT THE START UP DISK
Here's a link to to the korg site to download the manual and there is a link on the page to reset: http://i.korg.com/SupportPage.aspx?productid=223
Jun 10, 2014 | Korg D3200 Digital Studio
I have a korg pa 80 it have not sound
Initialization: N/A
Preload: Disk Load (6 Disk set available from korgpa.com)
ROM Check: Given on power up.
http://www.sweetwater.com/sweetcare/articles/initialize-reset-preload-korg-pa80-60
Apr 10, 2014 | Korg 37 MINI-KEY 8-VOICE...
My korg x5d doensn't show bank A anymore. Instead of A01 - pipedreams lcd screen shows blinking A01 and InitProg01???
You can try this.
STEP 1:
Set Program protect and Combi Protect to OFF.
- GLOBAL
- Using PAGE+ or PAGE-,
find untill the display show "3A-MEMORY PROTECT".
Set the parameter to OFF by using YES or NO button.
STEP 2:
Data Load.
- GLOBAL.
find untill the display show "05A-PRESET DATA".
Change ALL to PRG (your case).
Use Left/Right Arrow button to moving cursor.
Choose "PRE-a" (your case).
Move cursor to "OK?".
Press YES when "OK" blinking for confirm.
Exit (Go to PROG button).
Feb 26, 2013 | Korg X5d
My lap top model is tecra m3 and it takes 2 houres to boot opreting system until it boootes it showes tosheba on the screen
Go to www.download.com Type ccleaner and install and run the program, next install malwarebytes anti- malware and do a full scan after definitions have been updated, finally run defrag to improve performance.
Jul 07, 2012 | HEWLETT-PACKARD ProBook 4420s Notebook
I can`t load the OS in my KORG PA 80. No way to make it work. I think than the problem is the mother board.
Have you tried it with batteries? Are you sure the power supply is working correctly? It should not need the OS to operate as a keyboard disconnected from the computer.
The cable connection is just a MIDI cable that uses opto-isolators so the 2 items are electrically isolated from each other. The software driver for the Korg should load without problem. The Korg program itself may be looking for inputs that are not there when the keyboard is off and the program itself reaches a stop command.
If the PA80 will not work on just the power supply- the power supply can be the fault- it has an internal fuse. Finding a similar supply with the same coaxial plug wired the same polarity is the way to test it if the battery option is not available.
Mar 29, 2012 | Music
When i switch on my Korg PA800, the screen just show's blank. The screen light gets on but just blank blue. What could be the problem?
Hi, Provided your Korg works as normal, besides the display being blank and lit, I may have the answer. It sounds like the contacts connecting the display have somehow become dirty. This could have happened from something getting spilled on the display. To fix is easy enough if you have a little mechanical aptitude. unplug unit/take batteries out,and disassemble unit to gain access to the main circuit board where screen is located, the screen may be held in place with a tin casing either soldered to board or with prong set though the circuit board and twised on the reverse side to hold in place. After removing this there should be a little rubber strip between the screen and circuit board-this is the contact strip that you need to clean with rubbing alcohol. Clean the screen where the contact strip meets the screen. do the same on the circuit board, reassemble and you should be back in business. I hope this was useful, thanks for asking FixYa, and good luck, Prodzilla.
Apr 22, 2011 | Korg Pa800 Synthesizer
Display properties
Download this, run it, and click Yes when it asks if you want to "add this information to the registry."
http://www.kellys-korner-xp.com/reg...
Let me know how you made out, and please rate my answer.
Jan 17, 2009 | Dell Dimension 4600 PC Desktop
Korg triton Touchview screen not working properly
The Korg Triton touchscreen has two main parts - The LCD screen and the touch overlay. Between the two is a type of gasket. It is really just an adhesive, but it does help keep out moisture and dust. If you were to remove the screen, you could separate the two parts, clean it and use double-face tape or glue to reattach. You can also get a replacement LCD screen, touch overlay or touch-LCD assembly from a number of places on the internet. They are not cheap, unless you purchase a generic touch overlay or LCD and retrofit.
As for repair in your area... try contacting Korg at http://www.korg.com and look for authorized repair centers.
Jun 23, 2008 | Korg Legacy Collection
youtube.com Logo
Top youtube.com Computers & Internet Experts
Mike
Are you a youtube.com Computer and Internet Expert? Answer questions, earn points and help others
