Question about Microwave Ovens
Micro wave oven light works as a work light but when you hit the button for the night light to come on it doesn't come on hit the button again and it's off
Magic chef under the cabinet microwave
  • Microwave Ovens Master
  • 9,085 Answers
The problem is on the control panel, which can be repaired economically.
There is a a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Posted on Jan 17, 2013
  • 82 Answers
SOURCE: Magic Chef won't work - clock works
Does the fan run?
If not, it's a control board fault.
If it does run, it's probably a high voltage problem.
Posted on Mar 16, 2009
MicrowaveSvc
  • 9085 Answers
SOURCE: I purchased a Magic Chef under cabinet microwave
Since it's a clearance item, it may not have a warranty.
But you should check with Home Depot on that if you haven't already.
Otherwise, you'd have to have it repaired yourself.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Oct 11, 2009
  • 72 Answers
SOURCE: magic chef microwave which also has oven model
magnetron or door switch issue
Posted on Feb 04, 2010
  • 949 Answers
SOURCE: micro wave not working jen air
The Transformer is part number 56001221. I have run a search for the part and I am coming up with the same results, the pat is discontinued and no longer available.
Sorry
Posted on Apr 24, 2010
  • 8909 Answers
SOURCE: i have a magic chef
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Posted on Dec 29, 2010
My microwave doesn't work, but display works
I would strongly consider replacing the microwave oven, prices have dropped considerably. The problem you are describing is in the keypad controller board.
Apr 01, 2012 | Samsung Microwave Ovens
Where is the reset button located on spacesaver micro wave oven
  • locate the microwave's power supply cord.Remove the power supply cord from the wall outlet.Wait one to two minutes.Re-insert the power supply cord into the wall outlet. The microwave is now reset.
  • Mar 24, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
    Try2910227 serial ywmh2205xvb-0 model arcing on the back corner were the rack sits.Is there a way to repair this seen is the unit was purchaced in June of 2011.
    Yes, take the rack out and recycle it. I do not know why these micro-wave company put racks in the micro wave ovens. You get some insulation on the inside the micro flaking off next the rack.
    The mega-tron tube is a very high energy transmitter. The energy will come out of the top inside the micro wave oven in a wave guide. Micro wave energy that generation by the tube is high frequency into Gega Hertz. You have a metal tray in side the micro wave acts like a big capacitor it stores energy in form of heat the next you know it look like Marconi is putting on a lighting display.
    Leave the wire tie on a loft of bread and put in you micro wave oven to defrost. The next thing you might see is a load bread burning, instant toast. ----The use of micro wave were invented by the British before WWII. The mega tron tube generation very high frequency radio wave and these wave struck an object 100 miles away some of this beam energy would balance back to a receiver-----You have Radar.... I wish you and your family well being and be careful of micro wave ovens it can burn from inside out. GB you...stewbison
    Aug 22, 2011 | Microwave Ovens
    When power went off and then came back on, screen on micro wave continually shows demo and I cannot set time
    The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
    If that doesn't work, leave it unplugged for about 5 minutes and try again.
    If it still won't work, then you may have a bad membrane keypad / DP circuit.
    If your model is NN-P295SF, the service is here.
    Parts can be ordered from Encompass here.
    Aug 19, 2011 | Panasonic NN-P295SF Microwave Oven
    Micro wave oven stopped working
    Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
    Microwave Oven Basic Troubleshooting Tips
    heatman101 ';
    Aug 09, 2011 | GE JVM1640 Microwave Oven
    My microwave suddenly stopped working the panel light does not come on
    Those are full Of ********...You Dont Have to Buy A new Micro Wave Oven...Ovens's are stopped working Because of over heat consumstion in its chember..So because of feddback..it shutdown automatically..Just let it be cool..It will again Work prorerlly.. :)
    Answer:Tanmay Guha Neogi..
    May 14, 2010 | Sanyo Microwave Microwave Oven
    Will not start
    I have the same problem, diagnosed as bad touch screen panel.
    Apr 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
    I'm getting a flash inside the oven and the plastic on the inside roof has a burn mark. I removed the plastic cover over the micro wave generator and it did not spark. is the oven dying? It is a 1983 0ver...
    It looks like the metal part inside the oven is exposed to the high frequency rf waves. this may sound strange but try coating the metal part with fresh paint. remember no metal inside the oven will stand the waves created inside the oven the spark u see is the waves hitting the exposed metal part inside the oven
    Oct 13, 2009 | Magic Chef MCD1311ST Microwave Oven
    No Power
    HI, there is a inline fuse located inside the microwave ion the power supply board. check for continuity. replace the fuse if necessary. if the fuse is OK, replace the power supply board.
    Jun 01, 2009 | Kenmore 62702 Microwave Oven
    Microwave Ovens Logo
    41 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
