Question about Minolta DiALTA DI2510F All-In-One Laser Printer
My printer di2510f shows multifunction error code c0500
  • Minolta Master
  • 6,161 Answers
First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. then the machine will continue to the code screen. press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. the machine will again go thru screens will see the "." again do nothing. should go Ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset with out a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day.
Posted on Feb 07, 2015
3 Suggested Answers
faeq8
  • 7 Answers
SOURCE: error code C0500
C0500: Warming-up Failure C0510: Abnormally Low Fusing Temperature C0520: Abnormally High Fusing Temperature Relevant Electrical Parts Fusing Roller Heater Lamp H1 Fusing Roller Thermistor TH1 Fusing Roller Thermostat TS1 Fusing Roller Heater Lamp Fuse TF1 Side Cover Interlock Switch 2 S3 Power Supply Unit 1 PU1 Master Board PWB-A
Step Check Item Result Action 1 Does H1 turn ON after the malfunction is reset? YES Check TH1 for contamination or installation. 2 Is there continuity across CN3-1 and 2 on the Fusing Unit end with CN3 (2P) disconnected? NO Check H1, TS1, and TF1 for continuity. 3 Is there continuity across 1A and 1B, and across 2A and 2B, of S3 when S3 is turned ON? NO Change S3. 4 Is the resistance of TH1 (across CN5-2 and 3 on the Fusing Unit end) infinity? YES Change TH1. 5 Is Fuse F2 on PU1 conducting? YES Change PU1 or PWB-A. NO Change the fuse. Step Check Item Result Action 1 Is TH1 installed properly? NO Install TH1 correctly. 2 Is TH1 dirty? YES Clean or change TH1. 3 Is the circuit across CN5-2 and 3 on the Fusing Unit end closed when CN5 (4P) is disconnected? YES Change
Posted on Dec 28, 2008
SOURCE: error code c0500
open back coever then press reset switch from mainboard
Posted on Oct 02, 2009
HOW TO SOLVE ERROR CODE C0500 FOR KONICA MINOLTA 211
Error code C0500 and C0501 means Fixing unit's temperature abnormality.
How to reset these codes?
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
http://servicekonicaminolta.blogspot.com/2012/03/error-code-c0500-and-c0501.html
Jun 14, 2017 | Konica Minolta Office Equipment & Supplies
Reset c0500
Aug 08, 2016 | Office Equipment & Supplies
C0500
May 01, 2014 | Minolta Di3510f Bizhub Copier
Error code c0960 on my Di2510f
Manual by pass tray lift the by pass tray is the step looking thing on the right side of the copier. check to make sure there is nothing stuck inside there. IF ok then mite want a tech come out and look at it
Jan 23, 2014 | Minolta DiALTA DI2510F All-In-One Laser...
ERORR C0500
Sep 26, 2013 | Konica Minolta Office Equipment & Supplies
C0500 code showing up
You have a problem with the fixing unit not heating up to the correct temputure.
Sep 19, 2012 | Minolta DiALTA DI2510F All-In-One Laser...
The machine di251f is saying contact your technician with code error c0500 please help
error code c0500, checked lamp and thermo fuses, checked thermistor ok. reset machine
Jun 17, 2011 | Minolta Di251 All-In-One Printer
C500 error message on a di2510f
Kerry,
First check the right side cover where the image unit is located. Check the two latches that latch the door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day
C0500 mean the fuser the hot part is not getting the 117VAC power to the lamp inside the upper fusing roller. people sometime get frustrated and slam the right side breaking one or both of those latches prevent the door to push a accurator into the machine to depress a switch to supply power to the fuser lamp
C0500
Jan 18, 2011 | Minolta DiALTA DI2510F All-In-One Laser...
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
Minolta di 2510 code c0500
lo ke pasa es ke mi copiadora ya no responde mas y me sale este error una averia "a sido detectada avice a su servisio tecnio y digalke el codigo c0500" ya no se ke hacer... ayuda por favor..
Jun 24, 2008 | Minolta Di2510 All-In-One Laser Printer
Minolta DiALTA DI2510F All-In-One Laser Printer Logo
29 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
