Question about AOC 19" LED Monitor e950Swn Black
Monitor too bright
How to darken monitor its way to bright
Screen stays black, you can still hear it snapping pics
Manaual says:
Standby mode for saving power: press the shutter-release button halfway.
Camera and computer are connected via the USB cable.
Camera and TV are connected via audio/video cable or HDMI cable.
Adjust monitor brightness.
When the internal temperature of the camera is high, the monitor darkens to reduce heat generation. When internal temperature cools, the monitor brightens again.
When the power-on lamp is covered after the camera has automatically increased monitor brightness, the monitor may darken.
If you did not drop teh camera, or cracked it in your backpocket, perhaps you also chould check the battery. If it is charged, and still has enough capacity.
Nov 05, 2013 | Nikon Coolpix S100 16.0 Megapixel, 5x...
The screen occasionally darkens significantly,
Have you tried using a different VGA cable? Or replacing the cable with a new one?
Dec 07, 2012 | ViewSonic Va2431wm LCD Monitor
Screen is too light, how do I darken
Press the 'OSD' (On Screen Display) button on the front/bottom of the LCD, to show a bunch of menu items. Choose "brightness", and adjust it to a darker value.
Jul 20, 2010 | Acer 22" X223w LCD Monitor
Monitor darkens significantly when viewing some
The monitor might be on 'dynamic contrast'. Press menu on the remote control and does it say that 'magic bright' is on dynamic contrast?
If so, change it to something else and this may solve your problem.
Hope this helps!
Jul 16, 2009 | Computers & Internet
The auto-darken feature(monitor goes dark on dark
In your monitor panel you'll find 4 buttons. Press the menu button and get into Magic Bright. There you can choose the one that best suits you. You can even set to Dynamic contract where the monitor adjusts the brightness according to the elements on the screen
Jun 20, 2009 | Computers & Internet
The screen is to bright and wont darken enough
It is likely the video card on the actual unit. If it is under warranty they will likely have you ship it back to them for either 1) repair or 2)replacement
Edwards-Walnut
381 Brea Canyon Road
Walnut, CA 91789
Apr 05, 2009 | ViewSonic VA903B Monitor
Brightness/Contrast Adjustment
try going to the setup screen button left of adjustments
try going to the set up menu on the left of the buttons come down to the slider control just above the information icon then go across to color reset hope this helps regards Jim
Mar 12, 2009 | Samsung SyncMaster 2253BW LCD Monitor
Pelco monitor display is darkening
There is another brightness adjust on the back of the monitor.
Feb 19, 2009 | Pelco Pel Monitor 12" B/W
AOC 19" LED Monitor e950Swn Black Logo
29 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
