Question about Sony for Sony VAIO VGN-S4HP VGN-S4M/S VGN-S4VP/B VGN-S4XP VG... (813507018672)
Noisy fan on sony vgn-s4hp/b
Noisy fan and overheating
  • 34 Answers
SOURCE: Sony VGN S480P
Hello
I would not suggest yo uto luricate the fan but if yo want to, you will have to take palmrest off, first of all you will to take keyboard off to do so there are two screws on each side of battery take those screws off and then in battery compartment you will see two black plastic Knotch push those back one by one and keyboard will come off now unplug two flex cables one for power board and one for mouse pad also unplug the speaker wires on left hand side now take all the screws on top of palmrest and then close the lid and flip laptop over and take all the screws of n bottom and your palrest will come off and you can see the fan.
Thankyou
Posted on Jul 28, 2008
SOURCE: noisy fan--sony vaio vgn-s460
This isn't the best solution. Sony Vaio's VGN-S series are very infamous for grinding fan noises. One should see about oiling it or replacing (which is very expensive).
Posted on Sep 30, 2008
  • 2386 Answers
SOURCE: sony vaio vgn-s460p cooling fan makes noise
it is puely a technical job, if you have some technical know how the you could chnage it by yourself. it needs to open all covers of note book to reach the fan on motherboard. you can find the fan at sony authorized service center.
i suggest, the job may be done technically by a authorized technician to avoid future complications.
Posted on Dec 19, 2008
  • 125 Answers
SOURCE: i want to complete change hard drive on a vgn
Do you still have the original hard drive and can you still boot into it? If you can still get back in, run VAIO Recovery TOOL > VAIO Recovery Utility. You will be able to make a set of recovery CDs thats built into the system.
Posted on May 07, 2009
  • 1027 Answers
SOURCE: my sony vaio VGN-CS11S is soo noisy
The fan's bearings are probably going bad, or there may be some object that was sucked in to cause the noise.
Posted on Sep 29, 2009
Noicy sound from fan - vgn-z440
Chances are the cooling fan needs to be replaced, dirt buildup can also be a factor in noise. I recommend that the computer be dismanled by a pro and the condition of the cooling fan be checked, plus real good cleaning.
Apr 27, 2012 | Sony VAIO VGN-SZ440 Notebook
Sony Vaio VGN-S5VP/B Noisy CPU Fan
Buy a can of compressed air, a can of fine mechanisms oil, take the bottom cover off the laptop (only a Phillips screwdriver is needed) and clean and oil the fan.
Aug 19, 2010 | Sony CPU FAN CPU Fan
I have the same problem for Sony VGN-S460 heatsink fan problem
I trust that you have purchased the entire fan assembly as they are inseparable from the heatsink. You must disassemble the entire laptop in order to remove the fan assembly. they are two screws that are below the motherboard that must be remove in order for the fan assembly to come apart.
If you cannot achieve this yourself, or lack confidence in your ability to rebuild the unit after, you can send the unit to us at www.cowetacomputerstore.com and we will accomplish the desired outcome. We have worked on this system resolving this very issue.
farewell
Oct 05, 2009 | Sony VAIO VGN-S460 Notebook
My sony vaio VGN-CS11S is soo noisy
Sep 28, 2009 | Sony CPU FAN CPU Fan
I want to complete change hard drive on a vgn s4hp/b but i dont have recovery cd.how can isolve this prpblem?
You definitely need to get a recovery CD (Windows XP or Vista). There's no way for you to reinstall windows if you don't have the CD.
May 07, 2009 | Sony Computers & Internet
My Sony Vaio seems to kick the cooling fan on quite a bit more than normal and even seems a bit noisy for a computer fan....is this the norm???
Fan on this model may start and stop spontaneously. This is normal. Although if VAIO is overheating this would be good idea to contact Vaio tech support.
Apr 17, 2009 | Sony VAIO VGN-CS110E/W NoteBook
Noisy fan--sony vaio vgn-s460
then if that is the problem to your pc then turn your pc upside down and dissassemled the screw at the back then your keyboard should be lift up slightly and if you can not do that on your own try to contact someone in that field to help you but just for you to tell the person that you know what is wrong w2ith the pc the person should try and check if there is anything too close to the fan that the fan is touching and if there is nothing the fan is touching and the noise continue then change the fan with a new one. bye any question again.
Aug 25, 2008 | Sony VAIO VGN-S460 Notebook
Ethernet drivers for sony vgn-fs115m
Hey MIDO Try This Tool
VAIO Launcher 1.4.11 Update Program
This program will update VAIO Launcher pre-installed on the VAIO model listed below.
VGN-S4HP/B
VGN-S4HRP/B
VGN-S4M/S
VGN-S4XRP/B
VGN-S4Z/S
VGC-V3S
VGC-V3M
VGN-FS285H
VGN-A497XP
VGN-A417M
VGN-A417S
VGN-FS295XP
VGN-FS215Z
VGN-FS215M
VGN-FS295VP
VGN-FS215B
VGN-FS215E
VGN-FS215SR
VGN-FS215MR
VGN-FS285M
VGN-FS285B
VGN-FS285E
VGN-FS215S
VGN-B3XP
VGN-B3VP
VGN-S4XP/B
VGN-S4VP/B
PCG-K415S
PCG-K415B
VGN-FS195XP
VGN-FS195VP
VGN-FS115S
VGN-FS115Z
VGN-FS115M
VGN-FS115E
VGN-FS115B
VGN-FS115ZR
VGN-FS115M -- ( Thats Ur MODEL)
VGN-A397XP
VGN-A317S
VGN-A317M
VGN-S3XP
VGN-T2XP/L
VGN-T2XP/S
VGN-T2XRP/S
VGN-S3VP
VGN-S3HP
VGC-RA304
VGC-RA204
PCV-RS704
PCV-RS702
VGC-M1
VGC-V2S
VGC-V2M
VGN-T1XP/L
VGN-T1XP/T
VGN-B1XP
VGN-B1VP
VGN-S2XP
VGN-S2VP
VGN-S2HP
VGN-S2XRP
VGN-S2HRP
VGN-A297XP
VGN-A295HP
VGN-A217S
VGN-A217M
VGN-A215M
VGN-A215Z
PCG-K315Z
PCG-K315S
PCG-K315B
PCG-K315M
This update resolves the problem of registered applications not launching from the VAIO Launcher toolbar.
Note: This program requires VAIO Zone 1.2.05 or later. If your VAIO model comes with VAIO Zone 1.2.02, you must first update VAIO Zone before running this program.
Download and installation
1. Download the file SOAVZN-01028300-UN.exe and save it to a download directory
2. Close all running applications
3. Go to the download directory and double-click SOAVZN-01028300-UN.exe
4. The InstallShield wizard starts
5. Click Next and wait while setup is installing the new software
6. Click Finish when the installation is complete
HERE
Apr 15, 2008 | Sony VAIO FR130 Notebook
Sony for Sony VAIO VGN-S4HP VGN-S4M/S VGN-S4VP/B VGN-S4XP VG... (813507018672) Logo
67 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
