Question about Samsung 26.0 Cu. Ft. Side-by-Side Refrigerator, RS265LABP
Ice machine not working, rattling when door closes/light turns off
Same as above
    Novelist:
  • 159 Answers
From my experience on Samsung ice makers there was a redesigne on the ice maker due to the problem of it not producing any ice. They use a flex tray and the trays have been braking,and the sensor n the bottom may have loosend up. I would call samsung and find out if you are covered under a warrenty for your problem. Or if you purchased a service contract call them and they will take care of it.
Posted on Jul 12, 2007
My whirlpool fridge is beeping door open. About a year after buying it the ice machine stopped. Then it began to build up ice in the bottom of the freezer and leak on the floor. Now it is beeping door open...
It has a defrost problem.
as for the door open it and look carefully round the door and you will see the door switch press it down and see if the light will go off.
if it doesn't turn off the lights then u should have a bad switch.
but if yes then and the beep sound keep beeping then try turning the frige off for about 6hours with the doors all open and after the 6hours plug it back on.
Nov 12, 2017 | Whirlpool Refrigerators
In door ice dispenser runs without stopping.
The door switch for ice dispenser is stuck on and will need to be replaced.
Oct 02, 2009 | GE Monogram ZDI15C Automatic Icemaker
Ice machine does not make ice
No guide that I know of .
Open the freezer door and see if the laser light on the right side , flashes twice , then pause , repeatedly . Close the flap on the left side , and the laser should stop flashing . If this is what occures , then the optics ( cut off of the icemaker ) are ok . If you open the freezer and no laser on the right , check the position of the "rake" inside the icemaker . Close the freezer door for about 1 min , and then recheck the position of the rake . If it hasn't moved , then the icemaker is bad .
If the light flashes 2 times then pauses , pour about 2/3 cup of water into the icemaker , and check later , to see if the ice maker has dumped the cubes . If did not dump , replace the icemaker . If did dump , and did not fill with water , then the water valve behind the refrig is bad . Also check the black fill tube above the ice maker fill cup , to see if it is iced up , keeping the water from going into the fill cup . If it is frozen , then replace the water valve , due to seeping ( not closing completely ) , causing the slight drip , to freeze inside the tube .
This is the only guide I know of and it's called an experience guide .
Sep 27, 2009 | KitchenAid KSRG25FK Side by Side...
Ice maker is overflowing
Older icemakers have a bar that drops from above your ice bin; once the bin is full the bar is raised and trips turning the ice maker off so that it won't dump. If your's is this style, try manually pushing the free end of the bar upward so that it locks in the upward position. Newer ice makers with the ice bin in the door have a small panel that moves to the open position when the door opens and closes when the door closes. Mine also includes an optical sensor that is visible when this panel is in the closed position. Try placing a non-clear tape over the optical sensor (don't know if that will work or not but worth a shot). If effective in stopping the ice flow then call a repairman. If none of this works, turn off the water supply coming out of the wall to your freezer.
Sep 08, 2009 | Kenmore Freezers
Whirlpool Gs5shaxnb02 Ice maker
the most comon problem is the ice machine in the freezer actuates at low teperatures. actuation is when the unit goes into harvest the ice. if your freezer is not aciving low enough temperature the ice machine stops working ' check to ensure the condensor under the fridge is not pluged with dust .Also make shure there is adiquit air flow around the ice machine. hope this helped someone .
http://www.whirlpool.com/custserv/index.jsp
Jul 29, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice dispenser comes on by itself.
you need to replace the dispenser selector board.
Sep 03, 2007 | Frigidaire FSC23F7D Side by Side...
My ice maker tray is not filling with water everything else works, water in the door etc.
Jul 11, 2007 | Samsung 26.0 Cu. Ft. Side-by-Side...
Refrigerators Logo
116 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
