Question about Altec Lansing MX5021 System
I was listening throgh headphone sudden there is no sound.no out put speakers are silent.
Suddenly no sound from speakers
First, we must determine if the problem is with the speakers themselves, or with hardware or software of the computer. Try plugging a set of headphones into the audio out jack of your system (often times, this will be a green colored jack). Play sound on the computer while listening to the headphones, can you hear the sound? If so, the problem is with the speakers, otherwise, you need to troubleshoot software/hardware of the system. Another method would be to try plugging these speakers into the headphone jack on an mp3 player, mobile cd player, stereo, or similar device. Aside from the system not putting out sound, the speakers could be plugged into the incorrect jack on the system (not audio out, OR not audio out on the correct device), or turned all the way down.
Sep 18, 2011 | Dell A215 Computer Speakers
Why did my left earbud become silent?
you can make both of the earbuds work. You can open the earbud where the speaker is that you use to hear the musik. Use a soldering iron and a lead. check if the wire inside has removed, fix it back and you will hear sound on both earbuds.
Take care.
Jun 01, 2010 | Sony EX33LPS Headphones
My speakers wont work suddenly unless I am using my headphones
Make sure in the volume mixer that it is using the right sound device. You most likely have it set to the wrong device output. When you plugged in the headphones in kinda automatically switches, but to use the speakers again you have to do it manually. Just hook up a cheap av receiver to your computer and use this headphone input instead. a 100$ 5.1 av receiver beats any pc speaker system.
Aug 01, 2009 | Toshiba (4CH-VOUT) Sound Card
My laptops speakers stopped working
Have you tried a pair of headphones to see if they work?
Is the sound ouput muted? (a lot of laptops have a physical button to
do this...
check to see if the laptop is muted. Also, check the
volume control to see if everything is up where it should be, including
Speaker Out.
If I've got this all straight, the only thing that it can be is an
issue with the plug on the speakers and the jack on the laptop.
Obviously the computer is putting out sound to the headphone jack as
evidenced by your ability to listen through headphones. The speakers
work on another computer. So, it has to be something specific about
the Speakers on this laptop. Plug/Jack problem is the only thing that
comes to mind.
Jun 24, 2009 | HP Compaq Presario 2500LA Notebook
Toshiba Satellite Laptop - No sound when connected to earphone
possible solution: go and check your audio properties. the line-out might have been disabled, muted or simply turned down.
May 25, 2009 | Toshiba (4CH-VOUT) Sound Card
Sony DAVS300 DVD system
The amp is still alive and well if you can listen via headphones! If inserting a headphone plug used to switch off the speakers, the cause will be the headphone socket not connecting correctly and cutting off the speakers. If you could listen to both headphones and speakers at the same time and there was a switch to switch off the speakers than the switch is faulty.
Aug 09, 2017 | Audio Players & Recorders
I have my garmin nuvi 350 on max volume control and still have difficulty hearing prompts is there a secret way i can override and increase the volume even more?
Maybe you speaker is defective. have you tried plugging in a set of headphones and listening if the audio is louf throgh the headphones?
There is ano secret way to do what you are asking. While there is a way to change the volume for the voice within the voice file, you need a hex editor do this and it's beyond the scope of this forum.
- Jim
Dec 12, 2008 | Garmin nuvi 350 GPS Receiver
Garmin GPS - suddenly has no sound - it just cut out
1. Are you sure the volume setting is all the way up?
2. Are you sure the sound isn't muted?
3. Have you tried a pair of headphones in the headphone jack? If the headphones have sound, your internal speaker is bad. If you don't feel like sending it back for repair, you can purchase a FM transmitter like those used on IPODs and CDplayers and plug into your GPS's headphone jack and play the audio through your car's FM stereo.
4. If you don't hear sound from the headphone jack, most likely the audio output section is defective and you'll need to send it back to Garmin to be repaired.
Please let me know if I can be of further assistance to you.
- Jim
Mar 17, 2008 | Garmin Nuvi 660 GPS Receiver
Altec Lansing MX5021 System Logo
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Umali
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
