Question about WellMate WM6 Captive Air Well Tank
Pump will not come on .if i shake tank it will kick on.there is water in tank when i shake it
  • rchaymon15
    rchaymon15 Jan 17, 2013
    after shaking it kicks on and will run for day or so
  • rchaymon15
    rchaymon15 Jan 20, 2013
    CUT OUT 50 PSI CUT IN AT 30PSI SOMETIMES AND THEN SOMETIMES DONT KICK IN YOU HAVE TO SHAKE TANK AND THEN IT WILL KICK ON
Needs new pressure switch and riser nipple
Posted on Aug 04, 2013
I just installed new water pressure tank,it builds pressure to max then water runs low on pressure till pump kicks back on.whats wrong
Have to set the pressure switch
(instructions are under the cover)
65 # cut off
42 # cut in
Should install a new switch every ten years
& a new check valve before the tank & manifold
assy every 20 years
Oct 25, 2014 | Water Worker 44 Gallon Vertical Stand...
With no water on at all my pressure tank kicks on about every three min.runs for twenty sec. then shuts off.
Hi David,
The first thing I would check would be water level in all the toilet tanks on this system. If the level is too high in any one of them you may be getting a very slight amount of water overflowing into your toilet which could cause the pump to kick in as described.
If the water level is clearly below the the top of the overflow tube. If that is not the problem I would then check to see that you have the correct adjustment on the high/low pessure setting screws. It is important that there is sufficent pressure differences between the two or it will behave as described. Another possibility is the air pressure level in your pressure tank. Make sure it has adequate pressure as per manufacturers instructions. Finally if none of the above were the problem I would invest in a LINEAR one way valve (about $25.00) and install that between the pump and your pressure tank.
If your problem is still un-resolved then you do have a leak somewhere and will have to track it down... hot water tank, dish washer, clothes washer....
Good Luck
Alan
Oct 22, 2014 | Goulds Pumps HydroPro Water System...
Working pressure
Putting 60 lbs. of pressure in the pressure tank is not the answer.
First determine that the pump is working correctly, Open the drain valve and see if you get a good flow of water. If you do then OK, the pump is working. If you are not getting a good water flow from the drain valve, then the pump is not operating correctly - maybe a bad foot valve. Next open the drain valve and watch the water pressure gauge, and note at what pressure the pump kicks on ( that's the cut-in pressure), and when it kicks off ( that's the cut-out pressure). Most pumps are set to operate at 20-40 psi, or 30-50 psi. The cut-in and cut-out pressure is set by the water pressure switch.The pressure in the water tank has to be set 2 psi BELOW the cut-in pressure of the pump. That is, if the pump has a 20-40 psi differential, then the tank has to be pre-charged to 18 psi.
To pre- charge the pressure tank , the pump has to be shut off. The Tank needs to be emptied (drained ) of water. The air pressure is then set to 2 psi BELOW the cut-in pressure. If water escapes from the air valve, the bladder in the tank is ruptured, and a new tank needs to be installed.
So, first make sure the pump is working.
I WOULD RELIEVE MOST OF THE PRESSURE IN THE PRESSURE TANK TO ABOUT 20 PSI BEFORE CHECKING THE PUMP, AND PRCEEDING WITH THE PRE-CHARGE OF THE TANK.
May 24, 2014 | Plumbing
Pump is running/humming, but not grinding
The pump may have become plugged again immediately
May 28, 2013 | Star Water Systems PowerFlush Sewage...
My neighbours saniflow toilet is drivng me mad. The motor keeps whirring every 5 mins. Whats the problem, please!
Water pressure is what makes the unit kick on and off. If its kicking on by itself most likely water is somehow draining back into the pump. Start by checking the flapper in the flush valve inside the toilet tank, it may be leaking water into the bowl and from the bowl into the pump. Also inspect the check valve inside the 90 degree elbow where the waste is pump out from. The check valve may not be closing properly and is allowing waste water to drain back into the pump creating water pressure making the unit kick on and off by itself.
Oct 07, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
Problem with Convertible Jet Pump 3/4HP RedLion - drawing water 300' from lake to cabin - when the pump is on it holds 50# pressure by itself but when tap is turned on the pressure drops to 30# then you...
If I understand you correctly this is what you have:
- A pump that draws water from a lake 300 feet from lake to your cabin (I assume the pump is at the cabin)
- The pump kicks on to maintain pressure in a tank that distributes water to faucets in the cabin. The pump only turns on to pressurize the tank when water is being used (I am assuming).
- When you turn on tap, pressure in the pressure tank drops to 30 psi, then you hear water sucking from the tank to tap and flow stops at tap. Then the pump finally kicks back on and pressures tank to 23 psi.
- The pump is not used regularly.
If water flow stops when the pressure tank is reading 25 psi, then likely the real pressure is 0 psi and pressure gauge is reading wrong. If this gauge is tied into a switch that starts and stops the pump, then this is probably your problem. You may have partial blockage in your pressure gauge/switch that is causing gauge to move too slowly to keep up with the actual pressure changes when water is being used. Ore the pressure gauge/switch may be broken. Pressure gauges are notorious for reading pressure when there is none. If you can unplug the pump and disconnect the pressure gauge/switch and check for blockage in the ports you should start there. You mentioned that this worked good for the last two summers, if if sits unused for long periods, it could promote bio-growth, rust and/or sediment in the connection to the pressure gauge. If you find blockage, remove it and flush it out. Reinstall the pressure gauge/switch and try it again.
One other possibility is clogged strainer(s) / filter(s) in the water lines. It would not hurt to pull and check/clean any strainers / filters in the system including before the pump. I would even check at the lake for a strainer where the water enters the suction line to the cabin.
I would not assume that the pump is the problem yet.
Hope this helps.
May 01, 2010 | Plumbing
Cannot fill gas tank on 2002 Kia sedona. Even when you only pump 1 gallon, the pump clicks off like it is full. We have taken off the hoses but did not see any blockage.
I have a Kia Sedona 2005 and I can't fill it up with gas without the pump kicking off and I have tried several gas stations. Sometimes I can get a few gallons in with no problem but then it kicks off again and I have to spend twenty minutes dripping fuel into it until I loose patience. Help me!
Feb 15, 2010 | 2002 Kia Sedona
Flotec 42 gallon water tank - short cycling and changing water stream...do I need a new tank or could it be another problem?
These holding tanks are pre charged with air which in turn pressurizes the water. The tank has a bladder and an air valve on top. The pre charge ,over time, loses pressure, and the tank has to be pressurized again.
  • The well pump needs to be turned off.
  • The water has to be drained from the tank
  • Air is put into the tank from the air valve on top of the tank, and is measured with a tire air gauge.
  • The pre charge pressure is set to two psi below the pump cut in pressure.
  • In other words if your pump kicks on at 30 psi, the pre charge pressure is set at 28 psi. If the pump kicks in at 20 psi, the pre charge is set at 18psi, etc.
  • After you pressurize the tank, turn water back on.
  • If water comes out of air valve on top of tank, then the bladder is ruptured and you need a new tank.
  • Hope this helps!
Jul 06, 2009 | Flotec Corrosion Resistant Shallow Well...
Truck wants to trun over but wont.
You mean it turns over but wont start? have you checked the fuel pump inertia switch? it is on the rt side kick panel i believe. will have a reset button sometimes can trip if it gets kicked. can also try beating on tank while spinning over and see if this shakes pump to get it working
Nov 14, 2008 | 1996 Ford F150 Regular Cab
WellMate WM6 Captive Air Well Tank Logo
79 people viewed this question
Top WellMate Plumbing Experts
Donni Steen
Tom Chichester
Are you a WellMate Plumbing Expert? Answer questions, earn points and help others
