Drivers frontier FRNP512 - Computers & Internet
Location of crankshaft sensor 2003 nissan frontier 3.3
Here if you have the 3.3 supercharged motor and looking for the->! CRANKPOSITOIN SENSOR!<- and none of these answers have lead u towards the right direction this one will. 1.Jack it up on the drivers side. 2.put jackstands under the frame by deivers door and front crossmember to aupport the vehicle. 3.Take off the tire on the drivers side. 4 remove false rubber fender. 5. Look straight ahead just over the exhaust then vwalla itll be staring straight at you:)
Nov 19, 2013 | 2003 Nissan Frontier Crew Cab
Where is and how to change the cranck sensor on 2000 nissan frontier 3.3 4X4.
Hello shalom570,
The crank position sensor is on the rear left-hand side(drivers side) of the engine. See image below.
To replace follow steps outlined below.
1. Disconnect crank position sensor harness.
2. Loosen and remove the bolt securing the sensor.
3. Remove the sensor.
To install revers process.
Regards,
Jerry
Aug 20, 2011 | 2000 Nissan Frontier
Where is the fuel pump relay located on a 2007 nissan frontier
  • The fuel pump relay is about the center of your dash (underneath). There is also a fuse in the fuse panel, under the dash, drivers side. Should be 15Amp.
Regards, Tony
May 03, 2011 | 2007 Nissan Frontier SE Crew Cab
1998 frontier power doorlock solenoids (both sides) continuosly clicking in and out.
curcuit is connected, check drivers door panel switch (basically from rain causes switch problems) unplug switch and see if it still does it, if so check passenger side - odds are you will find it there.
Jul 09, 2010 | 1998 Nissan Frontier
Location of Crankshaft Position Sensor 2002
in the rear of the engine on the drivers side at the top of the transmission bell housing
Jul 08, 2010 | 2002 Nissan Frontier Crew Cab
Ihave a 98 frontier with frame damage. The truck
frames certainly can be straightened, but must be evaluated on a case my case basis at a frame straightening / body shop.
Mar 24, 2010 | 1998 Nissan Frontier
I Dont Have Windows XP Drivers
The following link takes you to Frontier designs Download page
http://www.frontierdesign.com/Support/Downloads/Dakota
It contains the drivers you seek as well as documentation for the unit. If you need it.
Thanks
Dave
Nov 20, 2008 | Intel Frontier Design Dakota 24-Bit PCI...
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
