Question about HP LaserJet 2200dn Printer
Hp PSC 1410v All-in-one will not pick up the paper
The printer suddenly will not pick up the paper. I cleaned the rollers in the back.
    Genius:
  • 2,120 Answers
Remove the paper cassette and the toner cartridge then turn the machine upside down and look at the rubber roller. It SHOULD NOT spin freely.
Roller drive tabs will sometimes break
Posted on Jan 25, 2009
A sheet of paper had remain in the cylinder
  1. Remove the rear cleanout from the printer.
  2. Gently remove any jammed paper or bits of paper.
  3. Close the HP Paper Feed Cleaning Kit software on the computer.
  4. Load plain paper in the printer paper tray.
  5. Press the Power button to turn the printer off.
  6. Press the Power button to turn the printer on.
  7. Try printing again. If the printer still does not pick up paper or if a paper jam occurs again, service the printer.
Other solutions customers found helpful » HP Paper Feed Cleaning Kit -- Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000 » HP Deskjet, Photosmart, and PSC All-in-Ones -- 'Out of Paper' Error Message and the Printer Does Not Pick Up or Feed Paper » HP PSC 1600 and 2350 All-in-One Series Printers -- 'Paper jam: Press OK to continue' Message Displays on the All-in-One
Dec 15, 2010 | HP PSC 1610 All-In-One InkJet Printer
I have a HP psc 2355 all inone printer. It says it is out of paper but there is paper in the printer. Is there anyting else I should do to make the printer work?
Usually the pick up rollers slip causing no feed and the printer then expects it. Popping up a jam , you need to clean the pick / feed rollers which are inside where the front edge of the paper goes. The 2 on the right are the most important, use a damp cloth and rub the wheel horizontally
Nov 25, 2010 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 500 makes loud noise and says paper jam, but theres no paper jam!!!!
The carrier shaft is probably dry. Use sewing machine oil or 3 in 1 oil and put a couple drops on either side of the carrier, move is back and forth a couple times then power on. While in there, clean the pick roller with a damp cloth and rub the rollers horizontally
Nov 25, 2010 | HP PSC 500 All-In-One Printer
My printer says it is out of paper when there is paper in it & the is an E where it says copies.
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water. NOTE: Distilled, filtered, or bottled water is recommended for cleaning the rollers. Tap water might contain contaminants that can damage the rollers.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Nov 19, 2010 | HP PSC 1410v All-in-One Printer
Where is the paper loaded on a hp psc 1410 printer?
On the back of the printer.
There's a panel that opens partway to reveal the normal adjustable-width paper guides, and the paper is then gravity-fed in to the printer.
Jun 28, 2010 | HP PSC 1410v All-in-One Printer
HP PSC 1410v all in one printer won't load paper! Help!
The problem is most likely with the sensor in the paper tray. I would use a can of air and clean out the machine and use a slightly damp rag for the rollers. I would also install the latest driver as well. Another trick I have used is to unplug the power source for 5 seconds and plug it back it in to reset the printer. HP printers are great, but can be very fussy sometimes. Hope this helps!
If this has been helpful to you, will you please rate this solution? Thanks!
Aug 08, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP PSC 1315 Paper Feed Problem
Remove the back panel or the duplexer if you have one attached (no tools required). Then locate the pinch wheel which is on the left hand side, about 4-5 cm in and from the left (looking from the back). With a cotton bud reach in and wipe the roller. push your little finger in to gently rotate the roller bit by bit so that you clean the whole roller. Only touch the side of the roller with your finger, so that you don't leave residues.
HP recommends that you use a little distilled, sterile or bottled water on the bud, but not tap water. I found that just using a dry bud worked to remove the build up of dust from the roller.
This succesfully got my PSC 1317 picking up paper again. I think it will apply to other printers in the PSC 1300 series.
Jun 25, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1410
hi mecs
have a look at this solve a problem HP PSC 1410v All-in-One Printer/Scanner/Copier
this might help you .
riz.
Jun 17, 2008 | HP PSC 1410v All-in-One Printer
Paper feed
Keith,
You are going to need to change or try and clean the pick up roller and seperation pad.
Feb 15, 2008 | HP PSC 950 All-In-One InkJet Printer
HP LaserJet 2200dn Printer Logo
187 people viewed this question
Ben Johnson
