Question about Konica Minolta bizhub 350 All-In-One Laser Printer
C-8102 ADF not available on bizhub 221 - Konica Minolta bizhub 350 All-In-One Laser Printer
ON STARTING ON MY BIZHUB C452 IT READS THE ERRO CODE 8102 IF I COMMAND CONTINUE IT ASK TO TURN OFF THEN ON . IF I DO SO IT WORKS NORMALY
one of the following is bad M-5, PS7 or REYB or DFCB (last to are circuit boards M-5 is motor PS7 a senor Check the sensor and sensor acturator get a tech out to look at it
Nov 18, 2017 | Konica Minolta bizhub Office Equipment &...
Error solve ?
MFP board (MFPB) not receiving SIO receiving port...ADF ADF (Document feeder) not talking to main board.have tech come out might need to be re-flashed worse case both board need to be replaced
Sep 23, 2016 | Konica Minolta Bizhub C360 Color Copier...
C-F907 bizhub C360 -
sir, MFP board (MFPB) not receiving SIO receiving port...ADF ADF (Document feeder) not talking to main board.have tech come out might need to be re-flashed worse case both board need to be replaced
Sep 22, 2016 | Konica Minolta Bizhub C360
Adf konica minolta bizhub 350. theres adf working good but no printout. a few minute machine says jam paper at adf. actualy original it was throw out.. help me please...
Konica Questions answered here ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - Am working on a Magicolor 2300 DL that sometimes fails to lift the paper tray ... good afternoon I have a konica minolta bizhub c550 when I open the ... I'm no printer tech, but in most other lasers (HPs, etc) the paper tray lifts, .... It seemsthere is a "waste toner sensor" which only lets the printer print out a few ...
Konica Minolta paper jam adf scanner Questions & Answers ...
www.fixya.com > Forum > Tags > paper jam adf scanner
Question about bizhub 350 All-In-One Laser Printer ... Konica Minolta bizhub 250 jammed but no paper ... Good luck. ... ...paper is there if the switch is working the adfboard is fualty or the cable between the machine and adf broke from all the ...
Konica Minolta bizhub document feeder not working ...
Jan 23, 2016 | Konica Minolta Office Equipment & Supplies
Konica Minolta bizhubc552 error c8102
Here is the error code definition: C8102 Turn around pressure welding alienation trouble
•During a pressure motion being performed, the reverse roller sensor (PS7) output does not change from H to L. •During a retraction motion being performed, the reverse roller sensor (PS7) output does not change from L to H. Further research yields this possible fix, since this model is in the same family as yours: http://www.copytechnet.com/forums/konica-minolta/89213-konica-minolta-bizhub-452-error-code-c-8102-a.html
Apr 06, 2015 | Konica Minolta Office Equipment & Supplies
The copier reads, "The ADF is currently not available." How do I fix this?
This is going to be a two step process:
With the machine on go to service mode. Select System 1, Problem Unit Isolation, Find ADF, Select Unset, (This next step ensure you wait ten 10 seconds between) Power off the machine, 10 seconds later turn it on.
Once ready to copy. Conduct the same procedure again this time select ADF select SET this time. Power off a ten seconds later Power on. If the problem keeps coming back have a tech come out.
Mar 24, 2014 | Konica Minolta Bizhub C220 Color...
Bizhub c300
microsoft wiondows xp professional version 2002 servicepack 3 software needed for model no M1005 LASERJET SCANNER PRINTER
Jul 02, 2013 | Office Equipment & Supplies
Konica bizhub C351 copier with BLACK area in center of the copy
u have to run the setup for machine if u like i can send u the step guide how to setup the machine
Aug 05, 2009 | Konica Minolta bizhub C351 All-In-One...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
29 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
