Question about Canon Mp25diii
Need part that you feed paper thru and holds in place so you can tear off paper. Don't know what it is called but is needed to use
4 Suggested Answers
  • 183 Answers
SOURCE: URGENT .. really need help
From your description,it seems that other material present inside your printer and blocking the paper path. Sometimes,broken paper feeder indicates the same way. I recommend you to bring your printer to the nearest service center unless you are quit familiar with assembly and reassembly of this printer.
Source:
Printer Clinic
Download Instant Manual
Posted on Feb 19, 2011
  • 10406 Answers
SOURCE: paper feed problem - tilts
The mechanism that "pulls" the paper into the printer is not pulling the left edge of the sheet of paper at the same speed that it is pulling the right edge. So, the paper "slews".
Check those mechanisms, and/or take the printer to a qualified technician, for professional repair.
Posted on Jun 11, 2011
  • 104 Answers
SOURCE: my printer don't feed the paper in order to print
Could be a number of things but I'll narrow down do you have the pictured printer? or a laser printer? Cleaning the pick up roller and check for "separation" pad appearing to be hard plastic somewhere in line or near where the blank paper hit the go flag
Check for 8 1/2" 20# to 24# paper.
If all checks out try looking for an individual staple, nail or wire that might have fallen in the rollers. Most likely something is jammed in there like a paper clip, or the day time passers by just are going about their business
Posted on Nov 25, 2011
How do i load new paper?
open door, place paper in cradle and pull a tail of paper from the roll with this portion facing down, then close the door, no need to feed it though any rollers etc.
pulls the paper from the bottom so the side that is loose goes towards bottom.
if you hold it in hand, the paper that comes from bottom of roll goes in cradle pulling 3 inch paper out of roll and closing door on the paper. tear off
Mar 12, 2014 | VeriFone VX510
Epson Photo RX510
Hi when you switch it on have you tried holding down the on off button for about 10 seconds as this often resets most printers.
Also when you sya thier is no paper jammed in printer are you absolutely sure their is not even i tiny bit of paper still stuck as it only takes a tiny bit of paper to make this message appear.
If you are confident in removing the paper feed witch is difficult to do as you need to make sure it goes back perfect as if it isnt the paper wont feed.
Alot of people say their is no paper jammedand they call somebody out to repair the printer and they get charged a fortune for removing a tiny bit of paper.
If holding the button down dont work then try switching the plug on whilst holding down the on off button let me know how you get on ok
Dec 10, 2007 | Epson RX620 All-In-One InkJet Photo...
How do I feed new paper
no need to feed paper simply pull about 3 inches of extra paper from roll, after placing paper in cradle, close the door on the extra paper and tear, this is all no feeding needed
Mar 07, 2014 | VeriFone Retail Supplies
How do I calibrate the Kroy K4350 printer
Place the label material in the printe, making sure that it is fed below the tiny green circuit board that you will see down in the throat of the printer carriage.
Power off. Firmly hold down the Pause Button.
When the label material starts to feed, Release the Pause button.
When the material stops feeding, you should see two green lights.
If you are seeing a red light instead, you have either been feeding labels with a black mark on the reverse of the liner paper, or there may be some other problem, and you need more help. We're Hanover Technical Sales, Inc. We sell Kroy Label and Wire Marker supplies, and help people thru the little idiosyncracies that they encounter from time to time. Phone 757-357-2677 and ask for Don.
Aug 11, 2011 | Kroy K 4350 Printer
My printer's feeding mechanism or something is having problems. It keeps feeding more than one paper in at a time. Do I need to replace something? What are the parts that may be causing this problem or how...
I think that is not problem with your printer,
that is cause paper was moist. and sticky.
solution make the paper became warm (put on the warm place or don't use air conditioner in this room)
Apr 18, 2011 | Canon MF6530 Black and White Copier
Printer begins to randomly feed paper and will sometimes feed two feet or more of paper without any transaction. If you tear off the paper, the VeriFone will continue feeding paper without stopping. We...
It's because of power issue You have to disconnect all the cables and clean make sure no dirt Connect the printer first and power up the register If still the problem persists you need to replace some files by doing a dialin
Mar 17, 2011 | VeriFone 900 Printer
I am trying to print my guest receipts and it is only printing out a quarter of the sheet with no ink.
hello, lets see if we can seperate problem with computer and printer, try running printers self test, i am curios if the machine will print properly, turn printer off, then hold paper feed button and turn machine on, paper will feed and print, once the first test pass, if you want to print the rest, press paper feed button, and machine will print and cut paper, this test is rather a little long, but it will give you info regarding paper feed, and cutting as well as impressions. if paper is dragging, check to see if the paper in machine is in correctly, you might want to check this out first, if the paper is in correctly, then problem is feeding, this is a little hard to clean, but you might want to try some isoproply alcohol and put some on the lead in paper, just enough to get paper wet, and try to allow machine to feed in, or maybe, if paper is already feeding in wet some area before going into machine with alcohol, and press feed button, and allow the paper to feed thru. tear off paper and try the printer test again. if still fails then machine has a problem and will need service.
Oct 08, 2010 | Epson TM-U220 Matrix Printer
I need to order a part for my euro-pro sewing maching model 50-1262d. this part hold the bobing in place. but I'm not sure of the part name.
Need feed and needle plate for Euro Pro 50-1262D. Don't know what part # to order or where to buy them?
Aug 05, 2010 | Euro-Pro Sewing Machines
Paper jam?
Jam's are usaually paper caused unless the printer has seen a lot of use.
The paper needs to be good quality , usually 22lb bond or better. You don;t want cheap thin stuff that will leave a lot of dust or tears easily. It also tends to absorb moisture out of the air. Once you have good paper fan it, this is just grabbing a few sheets holding it at one end and fanning it in the air to make sure the pages are seperate. Don't overload the paper tray.
The printer can have problems if you have sued it a lot or used cheap paper. The paper and clay dust in the paper comes off and polishes the rubber rollers. When this happens they slip and cannot feed the paper properlly. Take some iso-propyl alcohol and a paper towel and rub them . They will go from shiney to dull when you have them cleaned. The dust can also get into other places and you may need to blwo ro vacuum out the printer.
Most problems are from the thin cheap paper, the polished rubber rollers, or a damaged paper tray.
Jun 04, 2010 | Brother DCP 165C Compact Color Inkjet...
Register tape
Assuming that you know where the paper gets feed in, I usually use this trick to start a new roll of paper.
First, tear off the end of the new roll so that there isn't any glue stuck on the paper.
Then, fold the tip of the paper like an arrow. (Fold one side to the middle and the other side to the middle so both sides meet in the middle. Looks like >
Then, place the paper into the slot where the paper feeds into in the back. (Paper will get fed under the printer assembly) and then hit the PAPER FEED/ADVANCE button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
Hope this helps.
Have a good day.
M =)
Feb 13, 2008 | Sharp EL-2192Rll Calculator
Canon Mp25diii Logo
20 people viewed this question
old marine
old marine
