Question about GE Microwave Ovens
Ge jvm1490sh 01 - GE Microwave Ovens
I have a Siemens Microwave Model # HF36V305/01 and the fan will not shut off? Any ideas as to how to fix this problem?
Microwave Automatic Vent Fan Operation - YouTube
? 2:07
https://www.youtube.com/watch?v=6LoK1geGXbQ
Aug 1, 2011 - Uploaded by GE Appliances
This video explains the operation of the automatic vent fan feature on over the ... We have a Hotpoint Counter ...Missing: siemens ‎hf36v305 ‎01
Microwave vent fan won't turn off - Appliance Repair Forum
Nov 26, 2015 | Siemens Microwave Ovens
How do I replace jvm1490sd broken handle?
Disconnect, open door, remove screws from rear of door, dismantle door. Here's a diagram showing how it fits together.
01 Control Panel Door Grille Case Parts for GE JVM1490SD003
The part you need is #1801 on diagram
Microwave Door Handle
Color: Black. For white order WB15X10070. For bisque order WB15X10071. For the screws order WB01X10305.
by GE
Part Number AP3184331
May 19, 2014 | Microwave Ovens
Bought house with GE Profile Convection Oven. Do not know proper cooking directions, nor how to work many of the features. Also no light bulb in it & would like to know which one to buy. Need manual t
GE has the manuals for most of their appliances on their site: http://www.geappliances.com/service_and_support/literature/ . Just enter the model number and click Submit.
The direct link to the manual for the JVM1790 Over-the-Range Convection/Microwave oven is here: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40480-1.pdf . GE only lists the JVM1790CK, JVM1790BK, JVM1790WK and JVM1790SK.
I hope this helps.
Nov 10, 2011 | GE JVM1790 Convection / Microwave Oven
How do i change the interior light on model JBM17905K-01
You can download GE owner's manuals and installation instructions here. The owner's manual covers it if it's user changeable.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 31, 2010 | GE Microwave Ovens
Interior light on JVM1490sh went out. How do I replace it?
It looks like this one was not designed to be replaced by the consumer, so you would have to remove the oven from the wall, take the outer cover off, then replace the "holder assembly" which is a lamp holder, lamp, and lead wires.
It is HOLDER ASM part number WB36X102 drawing "INTERIOR PARTS (2)" reference number 1207.
To remove the oven from the wall, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you misplaced yours, you can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts here.
May 15, 2010 | GE JVM1490 Convection/Microwave Oven
Model JVM1790SK 01 Where/how do you change the
This is a pretty bad design, sometimes you can just remove the upper grill and access the light assy. If the panel is to tight to work in to change the light,you get to take the whole micowave down and remove the outer wrapper to change the light bulb. This is also not a standard bulb (part #WB25X10019). You may be able to get one from Lowes or Home Depot actually Sears would be a better bet, otherwise you will need to order one from an appliance parts outlet. Hope this helps and sorry I didn't design the thing I just fix them.
Jan 24, 2010 | GE Advantium 120 Convection/Microwave Oven
Glass Tray replacement needed
Those model numbers are not correct. That's likely why you're having trouble.
For model number JVM1790SK01, the part number is WB49X10114.
That's available here.
Mar 04, 2009 | GE JVM1790 1000 Watts Convection /...
GE MICROWAVE
Dear Carluc
Right for this one, it is essential that you unplug the oven from the mains and leave it to dissipate any electrical current certainly for 6 hours. Once you have done this, you wil to get yourself a phillips head 6mm screwdiver and unfasten the screws on the back that hold the casing cover to the chassis. This will expose the enternal components, then all you simply need to do, is find the lightbulb, unclip this from the holder and then replace it with one of the same make and model. Fitting and re-assembly is as straightforward as it is taking the unit to bits.
go to http://www.google.com and type in GE Microwave lightbulb........this will get you the details about the bulb, and use the same google search to get your service sheet/ disassembly guide. Easy as 1,2,3.
Hope this works for you and please contact me here if you need further assistance in this or any other matter that is of a technical nature.
Yours sincerely
Oz
Apr 11, 2008 | Microwave Ovens
Microwave Ovens Logo
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
