Sony vaio athlon 2800+ started beeping,one long beep lights flash
My sony vaio athlon 2800+ has just started a long beep for approx 5 seconds and with this the vaio symbol starts to flash and the yellow light flashes rapidly. This goes on for about 5 times, what might this be.
  • 107 Answers
Listen carefully to the beeps
One Long Beep, One Short Beep= motherboard problems.
One Long Beep, 2 Short Beep= video problems.
One Long Beep, 3 Short Beep= video problems.
Repeated long beeps = memory failure
continious long and short beeps = Cpu overheating
hope this helps
Posted on Jan 25, 2009
Want to know what buttons to push on settings panel to reset the computer on my vz commadore after the service is due How to reset service warning light?
1. Turn Igniton off
2. With ignition 'OFF' press and hold both arrow buttons, turn ignition on.
3. Release buttons after 3 seconds - the reset reminder should be flashing.
4. Press and hold set button for approx 3 seconds or until beep.
5. If you need to reset oil service - Press and hold set button again for approx 3 seconds or until beep. 'Service Reset No Items' should show.
cheers
Jan 16, 2013 | Cars & Trucks
1 LONG BEEP 2 SHORT BEEPS
Does anything ever post to the screen when you press the power button? if not, it's your video card. The links below are for 1 long and 2 short and they say it's the video card. I've heard that Sony extended the warranty on some models so you might want to go to their website and check yours or in a google search type: Sony GPU Extended Warranty. I did and I see they extended it from one to three years. They have the faulty Nvidia Graphics Card which was a major problem for many manufacturers.
Beep Code Links Below:
http://www.biosbeeps.com/sony-vaio-bios-beep-codes.html
http://www.techsupportforum.com/forums/f108/sony-vaio-vgn-ar51-beep-codes-614124.html
Extended 3 Year Warranty for Defective Nvidia Graphics Card links below:
http://apcmag.com/sony-vaio-notebooks-suffer-from-faulty-nvidia-gpus.htm
http://www.slipperybrick.com/2009/08/sony-warns-laptop-owners-of-defective-nvidia-gpus/
May 16, 2012 | Sony Computers & Internet
My Vaio VGN CR120E laptop has been beeping quite obnoxiously every time I start it up for awhile now, and has also started doing it every now and then while I'm using it. The beeps last about 1-2 seconds...
in 99% of cases its detected bad ram connection take out all the ram cards clean the copper pins with a hot damp rung out rag and re insert ram should fix it
Nov 27, 2010 | Sony VAIO® VGN-CR120E PC Notebook
Hi.when i turn on my ps3 it freezes at the main screen.please say i dont have to buy a new 1,i dont have the money. :(
Ok, if it is simply the image that is freezing and it is still staying on then there is hope for the PS3.
If however it is turning off with 3 beeps and flashing the red light then that is serious.
Please try the following if it is just the display freezing :
Turn the PS3 off into standby (red light on)
Press and hold the power button. It will beep when you first press it, beep again 5 seconds later and then beep one more time and turn off into standby mode (red light on)
Release the power button
Press and hold the power button again. It will beep when you first press it, beep again 5 seconds later and this time there will be 2 quick beeps together. Release the power button when you hear these 2 quick beeps.
The PS3 will start up asking you to connect the controller via USB and press the PS button. Do this and then continue.
After doing the above a menu will load with 6 options. Choose option 3 "Restore File System". This will re-install the PS3 software if it has become corrupt. Ignore any messages about corrupt hard drive, this is normal. If this step does not work try the above again but select option 4, then 5 if that doesn't work.
One of these options should get your PS3 up and running again.
Nov 07, 2010 | Sony Playstation 3 (PS3) Console
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    My Sony Vaio RX624's power buttone flashes orange
    Is your pc not giving display? What are the number of beeps?
    Jun 24, 2009 | Sony VAIO PCV-RX624 PC Desktop
    BLACK SCREEN AND A BEEPING NOISE FOR AT LEAST 5
    Take out the memory and then put it back into its slot. If you have more then one stick of memory then try one stick of memory in each slot one at a time until the beeping goes away. If the beeping doesn't go away then that means either your memory is bad or the motherboad is bad. If you can then try another stick of known good working memory and if you still can't get the beeping to go away then you know that at that point the motherboard is bad cause its not detecting the memory.
    Jun 06, 2009 | Sony VAIO PCV-V100G (PCVV100GKIT1) PC...
    5 series' of 5 beeps in a row on start up
    Check the Air Bag Indicator Light. When you turn the car on it should stay on for 6 seconds and then turn itself off. If a fault is detected in the system operation check, the indicator light will either fail to light, stay on continuously or flash. The flashing may not start until up to 30 seconds after the initial systems check.
    If there is a fault in the system AND the air bag indicator light fails to light then an audible tone will alert you- it will be a set of 5 chimes (bells/beeps) five times in a row.
    Have the Air Bag serviced and the indicator light bulb changed. Since the dash will be off in order to change the bulb, I would have all of the other dash lights changed at the same time. If one goes out, others will surely follow.
    Corri R. / Service Writer
    Jan 26, 2009 | 2002 Mazda Tribute
    It doesn't start up, only beeps and red light flashes
    pls try to use another compatible memory stick.
    then confirm the status of your micro processor
    Apr 21, 2008 | HP Compaq dc7100 Ultra-slim PC Desktop
    Blank screen & a beeping noise
    The memory ram have buggered up if you have two of them pull one out and try one at ta time.
    Oct 14, 2007 | Sony VAIO PCV-V100G (PCVV100GKIT1) PC...
    Computers & Internet Logo
    880 people viewed this question
    David Payne
    David Payne
