My Viking DFUD041 just hums or continues swishing or running with the Pot symbol blinking. Now when I look up the symbol in troubleshooting guide it says a blocked drain. I took the hose off the trap and attached a shop vac to it to see and nothing. Even when turning off the main switch and unplugging when I plug back in the motor still runs. I took the screen off and it was clear. Could it be inside?
Comments:
Mar 12, 2009
- It wound up being the drain hose was split at the bottom. The vikings have a saftey pump. When water runs into the pan the pump keeps running. It does this so water doesnt flow all over the floor.
part way through the cycle it stops running and the "Heavy" and "Normal" lights...
(More)
part way through the cycle it stops running and the "Heavy" and "Normal" lights on the control panel start blinking together.
my dishwasher won't stop the draining cycle and the "heavy" button is blinking. The only...
(More)
my dishwasher won't stop the draining cycle and the "heavy" button is blinking. The only way to stop it was to unplug the machine. I plugged it back in a few hours later and the draining is still running. Help?
Can I change the door on this model to one that has a smaller handle? Thank you Cassandra...
(More)
Can I change the door on this model to one that has a smaller handle? Thank you Cassandra Sandraclarke@comcast.net
