Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Keyless Entry won't work when it's cold
The last couple of months I noticed that the keyless entry won't work when it's really cold. If the weather warms up it works again. I thought maybe it's the battery and changed it today but, it still doesn't work. Is the problem still there or do I have to re-program the keyless entry now?
Thanks,
Ute
I have the same problem....pretty sad...one week of cold weather and it will not work. Reprogrammed it but only worked for the reprogramming. I wonder if there is a way to cover the pad
Posted on Jan 04, 2013
    Problem Solver:
  • 11 Answers
I HAVE THE SAME PROBLEM, I BELEIVE IT IS THE WEATHER . THE ONLY WIIRELESS THAT DOES WORK IS THE CLICKER. I HAVE NOT HAD WITH THAT ONE.. U COULD TRY RE-PROGRAMING
Posted on Jan 25, 2009
Eclipse door locks
Sorry absolutly no idea without a play
Jun 05, 2013 | Cars & Trucks
Keyless entry wont unlock
TThere is probably a problem with the door unlock relay or the passenger door module. The passenger door modules on Jeep Cherokee have had a lot of problems and there are a couple of Technical Service bulletins published by the manufacturer as a result of these failures.
Jun 02, 2012 | 2001 Jeep Cherokee
My remote keyless entry won't work. It does work if my car door is open. Very strange. Any suggestions?
on this model you can go through the onboard computer where it tells the tire pressure oil life ect. and change options on your impala keyless system. make sure the keyless entry is turned on. i hope this helps any other questions post back to me.
Aug 25, 2011 | 2007 Chevrolet Impala LS Sedan New Cars
Keyless remotes not working
Try reprogramming the remotes. Here are the instructions for the procedure. Hope it helps. Cobra!
Programming NOTE: All keyless entry remote transmitters (15K601) must be programmed at the same time.
NOTE: To program (or reprogram) the keyless entry remote transmitters into the RAP module, perform the following steps:
  1. Make sure that the anti-theft system is not armed or triggered.
  1. Turn the ignition switch (11572) from OFF to RUN eight times within ten seconds, ending in RUN. If the RAP module has successfully entered program mode, it will lock and then unlock all doors.
  1. Within 20 seconds, press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed. Repeat this step for each transmitter.
  1. If the door locks do not respond for any keyless entry remote transmitter, wait several seconds and press the button again. If the door locks still fail to respond, refer to Inspection and Verification.
  1. Turn the ignition switch to the OFF position, or wait up to 20 seconds after step 2, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the RAP module will lock and unlock all doors one last time to confirm.
Jun 06, 2010 | 1998 Ford F150 Regular Cab
2001 Chevy cavalier Z24 keyless entry not working.
You should have it scaned to see if you have any codes. It has a RCDLR (remote control door lock reciever) this is the module that recieves the signal from the fobs. If it has a problem then the system will not work. If it has to be replaced then a dealer will have to program it for you. Good Luck
May 25, 2009 | 2001 Chevrolet Cavalier
94 nissan altima GXE keyless option
Any vehicle can have keyless entry installed as long as the car has power door locks.I would recommend the viper aftermarket keyless entry. It works very well.
May 14, 2009 | DEI Python 1400XP Remote Start/Keyless...
Keyless entry on honda civic 2006 not working
The keyless entry is designed to work with the doors closed (closed - not locked). If the door ajar sensor thinks the door is open the keyless entry is disabled. When you manually lock the door it might tighten the door just enough to activate the keyless entry. I would try slamming all the doors closed and then see if the keyless entry works. If it still wont work have the wiring checked on the front door lock.
May 12, 2009 | 2006 Honda Civic Hybrid
Keyless entry
My keyless entry did the same thing on my cobalt. There are two tongs that get displaced. Atleast that's how it is in mine. I find if i hit the clicker off my hand a couple times it works. Sounds funny i know but that's the only thing i've found to work
Jun 27, 2008 | 2005 Chevrolet Cobalt
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
854 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
