Question about Orion STV2763 27" TV
Play light continuos blinking
As of this morning my TVCR play light on the continuosly blinks on/off when I plug it in. However there is no tape in the VCR and now the VCR will not work/play but the TV still works fine. It will accept tapes in the front slot but wont play them. Thanx for any help/suggestions?
  • Brad Nelson Jul 11, 2007
    I' posted the above problem(hopper) but must have put this post on the wrong model.....I have the following model:TVCR0950B
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 242 Answers
Retime the gears
Posted on Jul 17, 2010
SOURCE:
Evolution 2 headphones won't turn off, play, or anything but the blue light continues to blink
Here is the absolute solution 4 evolution 2 headphones that won't turn off. Plug in the audio cable 2 the input jack of the headphone. You should notice that the blinking lights have stopped. I did play audio through the cable, but the issue was pretty much resolved.
Nov 17, 2017 | The Audio Players & Recorders
Mini DV Tapes Won't Play
Please give the model and the make
Apr 16, 2008 | Sony DSR-11 DV / Mini DV VCR
The timer light is continuosly blinking when i plugging in the tv (mitshubishi wd-5252) and won't reset?
Thats one of the famous capacitor issue most likely. Thats the V26 Chassis DLP and usually that symptom is caused by failed DM and Power Board capacitors. There is a repair kit that will work in alot of cases with that symptom. Its called The V26 Chassis DM / Power repair kit available at the following link with detailed instructions http://tvrepairworld.com/mitsubishi_repair_kits
Apr 03, 2013 | Mitsubishi WD-52525 52" Rear Projection...
In sleep mode power light blinks can i stop this?
Put a piece of tape over it
Regards,
joecoolvette
Mar 30, 2013 | E-Machines eMachines Desktop PC
Series of 3 blinking lights. manual says lamp door isnt fastened properly. it is. i tried unplugging tv, have opened and closed lamp door 3xl. still blinking.
After I unplug and then plug tv to reset I get a solid standby light,then when I push the power button I get a green light that blinks 6 times then it blinks red 6 times and then red 6 times continuosly with a slight delay between the 6 blinks of red.
Oct 11, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Seagate external hard drive green light blinking
that problem means that it is acsessing the files on it. it is not a worry for you.
Sep 14, 2009 | Computers & Internet
Screen has error message and won't play tape. What is wrong?
This message appears when the loading tape path become misaligned (mechanically unstable). Your camera just need mechanical adjustment from any expert and it will work fine again. Contact any service man for this.
Thanks for using fixya.
Jul 10, 2009 | Sony Handycam DCR-TRV350 Digital Camcorder
Sony wega kp51 turns on for 3 secs than off w/ blinking red light
The flashes are fault codes. It means your system is faulty. If it is intermittent then it is more than likely a dust issue. Buy an air duster, spray out the back and restart. Should be fine
If it continues to play up then it will be a repair job
Dec 08, 2008 | Sony KP-51WS520 51" Rear Projection...
Tape deck won't play
my machine not working problem is play, fd,rw, is not working all three led of rec,pause,play led is blinking
Nov 05, 2008 | Tascam Audio Players & Recorders
Orion STV2763 27" TV Logo
54 people viewed this question
Top Orion Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
