Question about Euro-Pro 7500XH Mechanical Sewing Machine
Where in Toronto Canada can I get a bobbin case holder for Omega 7500 machine?
I need a bobbin holder for my Omega 7500 sewing machine. Where can I obtain one in Toronto, Canada?
SOURCE: user manual
if you go here: http://www.amazon.com/Euro-Pro-7500XH-Craft-NSew/dp/B000068U62
and then scroll down a little to the "product details" section, you'll see a link to download the pdf of the manual. good luck!
Posted on Jan 15, 2008
SOURCE: bobbin case problems with machine,
my bottom bobbom wont catch how do i fix the timeing or restart settings?
Posted on May 08, 2008
  • 14 Answers
SOURCE: euro-pro sewing machine repair
If you call the company, they will probably send you whatever you need. 1-800-361-4639
Posted on Mar 26, 2009
SOURCE: I lost the bobbin casing
Sew4Less,com has a bobbin case listed for $19.95. Go to www.Sew4Less.com. In the blue box on the home page, fill in the blanks. Step 1: bobbin case. Step 2: Euro-Pro Step 3: 9025 Step 4 click Find Products and you're there!
Posted on May 04, 2009
  • 3 Answers
SOURCE: Pinnock
I also have a pinnock sewmaster, here is a link to the instruction manual, hope this helps http://www.sewon.info/downloads8888/PINNOCK-FRIDOR-SEWMASTER.pdf
Regards
Posted on Aug 31, 2009
Why does The bobbin holder keeps 'crashing' with a metal 'arm' on the left.
Hum, nothing should
"crash" into anything else while sewing. The Hook (place where bobbin case snaps into) might have a broken "keeper" (internal part that "keeps" the hook stationary when sewing.) Or your bobbin case may not be installed completely or correctly.
Cheers,
Kelly
May 03, 2014 | Janome Memory Craft 9000 Computerized...
I have a Necchi 4900 and the thread catches on the bobbin holder , moves the bobbin holder out of place , james , have taken it out cleaned everthing under the bobbin and takewn the underneath cover
try changing the needle to see if that helps
if it doesn't,, then I suggest that the sewing machine be checked
at a repair shop to see if the bobbin case needs to be replaced and
to see if the hook and the hook race need to be replaced
Nov 01, 2012 | Necchi Sewing Machines
I'm looking to get a manual for omega denim deluxe machine 7500 model
email these sites about a manual
sewingpartsonline.com
sewusa.com
sewvacdoctor.com
a1sewingmachines.com
Jun 01, 2012 | Sewing Machines
How do you load the bobbin properly?
Well you may please follow the steps below -
1. Remove the bobbin from the sewing machine. Note: whether you have a drop-in, front or side-loading bobbin on your sewing machine. A drop in bobbin will load from the top, may be via a removable bobbin case cover near the machine-fed dogs. A side or front loading bobbin needs to be loaded into a removable bobbin case under the machine.
2. Choose the right size bobbin for the sewing machine.
3. Wind thread onto your bobbin. Your sewing machine should have a standard thread spool to hold the thread and a short, squat post wide enough for a bobbin.
4. Put the thread and empty bobbin into position on your sewing machine. Wrap the thread around the bobbin to start it. On most machines, disengage the needle by turning the smaller hand-wheel on the machine toward you. Push the bobbin post into position, securing the bobbin into place. Press gently down. Thread should begin to wind neatly onto your bobbin.
5. Break the thread, push the bobbin post back into an inactive position and remove the bobbin. Tighten the hand-wheel. Thread your sewing machine again if necessary before loading the bobbin.
6. Remove the bobbin case cover and put the bobbin into position. The thread should slide through a catch on the bobbin case and up through the cover.
7. Access the bobbin case for a front or side mount bobbin. Lift the catch and remove the removable bobbin holder. Put the bobbin into the holder and run the thread through the holder, bringing it to the front. Lift the catch and slide the bobbin holder back into the case. Hold your needle thread gently forward with your left hand and turn the hand-wheel. The needle thread will pass down into the machine and catch a loop of the bobbin thread. Pull this loop up and slide both threads to the back before beginning to sew.
Good Luck!!
Thanks for using FixYa!!
Sep 22, 2010 | Euro-Pro Shark 60 - 384
I HAVE A HUSQVARNA 415 SEWING MACHINE. I AM LOOKING FOR THE NAME OF THE PART THAT YOU PUT THE BOBBIN INTO. I ORDERED A BOBBIN HOLDER, BUT THAT IS NOT IT.
The bobbin fits into a bobbin case (holder), the bobbin case is what you take out to put a new bobbin in. The bobbin case fits into the hook (it has a spindle in the center) which you do not take out of the machine unless you are doing maintenance. If you just ordered a bobbin holder, it could be for another machine. you must get a case made for the machine, a generic one will not work.
May 22, 2010 | Husqvarna Viking 1
Euro-Pro 7500XH Mechanical Sewing Machine Logo
16 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
