Question about Welch Allyn PROXENON 350 CL1681 Light Bulb Lamp 300 Watts XENON LIGHT BULB LAMP
Want service manual for Pro Xenon 350
I need to find/replace micro switch at lamp door
I have a 2004 chev Express box van and my tail lights wont work every blinker works just not the lights both sides replaced bulbs still nothing
Fuse Usage 1 Climate Control 2 (HVAC) 2 Compass 3 Ignition Switch, Theft Deterrent System Module (PK3) 4 Upfitter Courtesy Lamps 5 Climate Control 1 (HVAC) 6 Empty 7 Instrument Panel Cluster 8 Audio System, Chime 9 Auxiliary Park Lamp 10 Auxiliary Trailer Back-up Lamps 11 Remote Function Actuator, Tire Pressure Monitor (TPM) 12 Climate Control (HVAC) Controls 13 Trailer Park Lamps 14 Front Park Lamps 15 Taillamps, Back-up Lamps 16 Empty 17 Steering Wheel Sensor 18 Outside Rearview Mirror Switch 19 Empty 20 Empty 21 Rear Defogger 22 Outside Rearview Mirror Heater 23 Empty 24 Empty 25 Cargo Door Unlock 26 Rear Door Lock 27 Front Door Lock 28 Rear Passenger Door Unlock 29 Upfitter Park Lamps 30 Front Passenger Door Unlock 31 Driver Door Unlock 32 Airbag System, Automatic Occupant Sensing (AOS) System 33 Right Rear Park Lamp 34 Left Rear Park Lamp 35 Upfitter Auxiliary 2 (J-Case) 36 Upfitter Auxiliary 1 (J-Case) 37 Rear Blower (J-Case) 38 Empty (J-Case) 39 Run (High Current Micro) 40 Park Lamps (High Current Micro) 41 Empty (Mini Micro) 42 Upfitter Auxiliary 2 (High Current ISO Relay) 43 Retained Accessory Power (RAP) (High Current Micro) 44 Rear Defogger (High Current Micro) chevrolet-express-fuse-box-floor-console-fuse-block-247x300-3m55w415sdhfmumhyuzqkab2-3-0.jpg
Jul 27, 2017 | Cars & Trucks
I replaced the projection lamp and the light flashed red 3 times after researching i found it was the projection door now the light just flashes red non stop
There are usually several micro switches (little metal levers) inside the projection tv - most commonly by the lamp assembly and behind the lamp door.
It's possible either:
a) the lamp is not fully seated into position - ensure the lamp assembly is locked into position and that all screws have been secured, which will correctly close the micro switch.
b) the lamp door is slightly misaligned - ensure the door is aligned properly (do not force it) and all screws MUST be secured into place, which will correctly close the micro switch.
If the above items are in their correct positions, then you may need to test the 'continuity' of the switches (open & closed) using a multimeter, to determine whether you many have a faulty micro switch.
Hope this helps..
Oct 31, 2011 | Sony KDF-50E2000 50" HDTV
What I need to do service D on my ML 350 2008 mercedes?
SERVICE B REPLACE CLEANER FILTER, INSPECT SERVICE BRAKE SYSTEM, REPLACE CABIN AIR FILTER, LUBRICATE DOOR HINGES AND LATCHES,REPLACE ENGINE OIL AND FILTER,INSPECT SERVICE EXTERIOR LAMPS, READ CLEAR FAULT CODES, TOP OFF FLUID LEVELS,LUBRICATE HOOD LOCKS, INSPECT SERVICE INTERIOR SWITCHES,INSPECT ADJUST PARKING BRAKE,RESET SERVICE INDICATOR LIGHT,INSPECT SERVICE STEERING AND SUSPENSION, LUBRICATE SUNROOF GLIDES,INSPECT ADJUST TIRES AIR PRESSURE,ADJUST LUBRICATE THROTTLE LINKAGE,REPLACE WINDSHIELD WIPERS.NOW 60000 MILES INTERVALS YOU NEED FLUSH BRAKE FLUID,FLUSH COOLANT,REPLACE FUEL FILTER,REPLACE POWER STEERING FLUID,REPLACE SPARK PLUGS,REPLACE TRANSMISSION FLUID AND FILTER.
May 25, 2011 | Mercedes-Benz ML350 Cars & Trucks
My projector blew a bulb after installation what the problem generic bulb
Hello :
Check out the Power supply to the lamp . It must not be high . . Check if the voltages are correct to the lamp's unit and it's PCB [printed circuit board]. I recommend using a service manual .
Check for manual here please :
Sharp DT-100 Multimedia Projector manual .
Here is how to replace a projector's bulb correctly :
1:Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
It is also wise to unplug any other cables and label them in order to restore them in the right way once the lamp is replaced.
2:In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
3:Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
Please note that in some projectors a small inside filter should also be replaced.
4:Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
Touching the lamp will deposit skin oil that will likely damage any new lamp during use.
5:Reassemble the access panel, repluge the cables and power up the projector.
Things You'll Need:
new projector lamp
screwdriver
micro fiber duster
Warning:
avoid touching the bare projector lamp
I hope this will help .
rate please !
Mar 21, 2010 | Sharp DT-100 Multimedia Projector
Map light fuse on 2008 f 350????
The interior map lamps are powered buy the battery saver relay ( non serviceable relay ) Which is powered by Fuse #25 ( cab fuse panel ).
This is for the engine compartment and illuminated vanity lamps, as well as the map lights.
The FET ( Field-Effect Transistor ) shows the fuse #9 also on it. ( marked interior lighting ), which power the interior lamps ( door / switch ).
Could be a few things if both those fuses are OK.
1. The map / interior lamp combos are usually dual element bulbs, which means if the interior lamps ( door or dimer switch on headlamp panel ) are OK, it could still be a burn out bulb.
2. The FET is having an issue from a dead short ( blown bulb or dead short to ground ). Until the short is correct, the FET will not turn back on.
Start with checking Fuse #9 ( marked as Fuse #8 in the diagram, but that shows headlamp ), which is to the interior lamps, and drives 1 side of the FET.
Jan 07, 2010 | 2004 Ford F150
'03 Mini Cooper Xenon Replacement
If it's oem xenon than it should be 2 lamps. Because they had only xenon on the low beam (d2r type), however begin with changing the high beam. That one is inexpensive, so you could check if there are no other problems (like wiring).
Just open your hood and it should be clear how to open the cover for your high beam.
Dec 14, 2009 | 2003 Mini Cooper
It keeps shutting off. Anywhere from 2 or 3 times
Could be several things. First replace lamp.Remove lamp door and put it back on making sure tab on door presses door switch downward when closed. Can you heard spinning noise from front. Bad color wheel will cause shutdown. Look at big cap on ballast . iff swollen replace lamp, ballast and power board. Is voltage to ballast from power board below 350 volts if so replace power board. hope this helps. Most common are lamp and door switch in up position rather than downward .
Nov 24, 2009 | Samsung HL-S5087W DLP TV
Tv turns on and off intermittently
Be sure the tab on the lamp door pushes the switch downward. Has the lamp been changed. Bad lamp commonly causes this set to shut down. Also is voltage to ballast below 350 v replace power board. I have nevr heard of a computer board in this set.
Sep 28, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
Sony wega 50 " lcd rear projection
The 3 blinks on this model TV means you have a lamp cover error. When you install the cover look at the tab on the cover and make sure it is making contact with the micro switch inside the lamp housing.
Oct 17, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Welch Allyn PROXENON 350 CL1681 Light Bulb Lamp 300 Watts XENON LIGHT BULB LAMP Logo
52 people viewed this question
Top Welch Allyn Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Welch Allyn Office Equipment and Supply Expert? Answer questions, earn points and help others
