Question about Canon Ir 2830 Digital Copier
Print light dark problem in ir 2830 - Canon Ir 2830 Digital Copier
2 Suggested Answers
canontech
  • 1219 Answers
SOURCE: copy darkness problem canon image runner 2830
Did you try to clean beneath the copy glass?
On digital machines, when the copy glass or optics are dirty, copy becomes verry light.
How many copies do you have? pres 123 button.
It also could be that you need to change the toner station, by the book it goes 300000 copies.
But I bet on dirty copy glass and dirty scanner assy.Clean the glass with glass cleaner and polish it with dry cloth.
Posted on Jul 25, 2010
Testimonial: "so thanks"
Canon ir 3300 printer has dark part in page not apper in print what is problem
dear
If the dark portion of the page is out side of the image scanned, then there may be chance of light passing to the scanner through platen glass.Pl. check the top cover and whiteness of the flap.
If the scanning through the PC has the same problem then the SHADING adjust to be done.
Thanks
Feb 21, 2015 | Canon Ir 3300 B/w Copier image Runner...
Error code 0001-0002 canon 2830
Error code 0001 0002 ane par kya kare
Oct 09, 2014 | Canon Ir 2830 Digital Copier
How can i fix the dark line in ir 3300 appearing on paper when printing?
If you have pulled the paper while printing, you might need to re-calibrate the drum. Go to your printer settings and re-calibrate it.
Aug 04, 2014 | Canon IR 3300 Digital Copier
Canon ir 2830 coding out to E000007-0000 - what can correct this can I do it myself
CANON IR 2830 ERROR CODE e0007-0000 SIR PLEASE SOLUTION MY ERROR CODE
MOB.9636327398
EMAIL-M.KCOMPUTER31@GMAIL.COM
Mar 14, 2011 | Office Equipment & Supplies
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
Canon ir 2830 error code e 490
SIR CONON IR 2830 COMPUTER SE ATTACH HO SAKATI HE
Sep 03, 2010 | Canon IMAGERUNNER 3530 Copier
Copy darkness problem canon image runner 2830
Jul 25, 2010 | Canon imageRUNNER 2870 Copier
Canon IR 2830 how do I install drum assy? How do I put in a drum unit for the IR 2830.
A.Removing thr drum unit.
Opem the front cover,shift down the developing assembly lockimg lever to unlock the developing assy.Slide out the left cover,holding the grips,pull out the drum unit.When removing the drum unit be sure to hold the two grips and take care not to scratch or soil it.
B.Cleaning the photosensitive drum.
If the surface of OPC drum is soiled wipe it with a flannel cloth coated with toner.Do not use paper,lintfree or otherwise.
Nov 22, 2009 | Office Equipment & Supplies
Pls. help..Canon IR 3300 has some problem in printing. Its print out are stripes like zebra. 2inches light, 2 inches dark, 2 inches light and and another inch dark.. solution pls.
Usually this is a drum issue, where the drum cleaning blade is bent in the wrong direction. It would help to know the last time this was changed. They only yield 60K.
Aug 17, 2009 | Office Equipment & Supplies
Canon Ir 2830 Digital Copier Logo
35 people viewed this question
old marine
old marine
