Question about Sony Handycam DCR-PC105 Mini DV Digital Camcorder
Power Zoom Lever Doesn't Work
I bought my Sony Handycam DCR-PC105 Mini DV Digital Camcorder several years ago and have been very pleased with it's quality, features and durability. I have never had a mechanical issue with this camera until last week. Last week, I noticed that the power zoom lever on the camera stopped working. I am still able to zoom in and out using the remote control. There is also another smaller issue which I noticed last week that I can live with, but I'm only mentioning in case it is related to the zoom issue. When I turn the camera on, I get a "CLOCK SET" message. If I set the clock, it will only stay in the camera's memory as long as the battery is attached. Once I change the battery, the message re-appears. I understand that there is an internal re-chargable battery which should keep this information while the camera battery is un-attached. It has worked for years, but now, at the same time the zoom has failed me, this problem arose. Are they related? I would love to keep using this camera, but can't find anyone to fix it at a reasonable cost. If anyone knows what the problem is and how I can fix it, I would really appreciate the advice.
  • 2 more comments
  • Steve Koenig Jul 16, 2007
    I have a few questions reguarding your solutions.
    - When trying to charge the (internal) backup battery, do suggested leaving the camera charging for more than 24 hours. Should the (external) camera battery be attached to the camera during this time?
    - As for trying the memory stick, I do not own one, so I ordered one from ebay and will have to wait a week to try it out. While I'm waiting, can you send a higher resolution image, or the link to the original? The image in this posting is hard to read, even when I blow it up in photoshop.
    Arpi,
    My email address is [email protected]
    Thanks,
    Steve
  • Steve Koenig Jul 18, 2007
    I just received the memory stick and tried it out. I am not experiencing any MS errors. Does this mean I should try changing the part you've suggested through your picture, or should I try something else?
    Steve
  • Steve Koenig Jul 23, 2007
    Hello Arpi,
    I've supplied my email address six days ago and have yet to receive the higher resolution image you offered. I also posted a question four days ago that you have not responded to. Can you please follow up on whether I should change the part you suggested, or try something else. My power zoom lever still doesn't work but the zoom works using the remote control. I tried using the memory stick but did not get any MS error. Since I did not see the MS error you predicted, does this mean your solution is still viable, or should I try something else. If you still suggest I follow the instructions described in your picture, can you please send me a higher resolution copy to my email so I can read it?
    Thank you,
    Steve
    Sergeant:
    Champion:
  • 326 Answers
Hello, please try to use the memory stick. If there is a message MS error, please look at this picture. Best regards, Arpi If you need more info please advice.
Posted on Jul 12, 2007
  • 1 more comment
  • Arpad Kothai
    Arpad Kothai Jul 12, 2007
    Here is the picture...
  • Arpad Kothai
    Hello again.
    The other problem is your (internal) backup batterry. In order to solve this please connect your camcorder to the mains using your AC adaptor and leave your camcorder with the power switch set to off (CHG) for more than 24 hours.
    Best regards,
    Arpi
  • Arpad Kothai
    Arpad Kothai Jul 16, 2007
    the (external) camcorder battery should be attached to the camcorder during the charge.
    In order to supply you with the picture in higher resolution please give me your email address.
    Best regards,
    Arpi
SOURCE:
Hello, I have a Sony Digital Handycam DCR PC105 and the Zoom button doesn't work. What can I do? Took it to a shop and they said it was hard to fix and would have to send it to Sony. Any suggestions,...
Well, there are one of two things wrong. It is either the connector for the zoom switch has worn down (most likely) or it is a software issue. Unfortunately, the PC105 is very old and you can not pair it with a remote. Personally, I would just send it to sony. It might actually cost more to fix than to get a new camera unless you have a warranty, so you might want to consider getting a newer camera.
Hope this helps.
Dec 08, 2013 | Sony Handycam DCR-TRV16E Mini DV Digital...
How to operate
You may download the manual and more from here.
Dec 12, 2012 | Sony Handycam DCR-PC105 Mini DV Digital...
DCR PC 105 was dropped. Now auto focus only works on a limited range of the zoom lens. Can't go wide or too close. Is there a way to fix/replace the lense or auto focus? Does the lens easily come out?
The most likely cause for this is a zoom or focus lens out of place and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Jan 27, 2011 | Sony Handycam DCR-PC105 Mini DV Digital...
Screen beeps and reads CL 1:20:00
The message (actually C:21:00) means humidity inside the camera. Leave it without batteries and the tape cover open. Wait several hours to try again. If it does't fix, try this link:
http://www.pechorin.com/m/2006/04/16/Error_Code_C2100_Sony_DCRTR7000E_PAL-259604.html
Nov 25, 2008 | Sony Handycam DCR-PC105 Mini DV Digital...
Driver for sony camera
I found the link to get the drive on the sony website in the United kingdom. http://support.sony-europe.com/dime/camcorders/dv/dv.aspx?l=en&m=DCR-HC17E
Hope this is helpful.
May 10, 2008 | Sony Handycam DCR-PC105 Mini DV Digital...
How to connect dv camcorder to pc?
Hello, please check this link: http://support.sony-europe.com/dime/camcorders/DV/DV.aspx?l=en&m=DCR-HC21E If you need more info please advice. Arpi
Jul 13, 2007 | Sony Handycam DCR-HC21 Mini DV Digital...
Zoom is stuck
Just check the DC power supply flowing to the Lens block control. Some times the SMD fuse blows off and power may not reach the lens block motor.
Dec 02, 2006 | Sony Handycam DCR-PC105 Mini DV Digital...
Sony Handycam DCR-PC105 Mini DV Digital Camcorder Logo
196 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
