Question about Kohler K-T12007-4s-BV Brushed Bronze Fairfax Single Handle RiteTemp Tub and
Kohler KT12007 Showerhead
Installed a Kohler Fairfax Single Control Bath & Shower Trim (K-T12007). When I turn on the water to fill the tub, cold water also comes out of the showerhead. Any thoughts on how to fix this?
  • 10,865 Answers
The device which directs the water up or down is called the diverter. Your diverter is not fully up or fully down. Rather forcefully push and pull the diverter a few times and your problem may be solved. good luck.
Posted on Jan 25, 2009
My showerhead leaks when I fill up the bath tub, do you have any suggestions as what will correct this?
Hi nanbooboo...
Sorry
Your problem shower control valve is ok, but the shower pull that turns on the shower is non-repairable.
Replace your shower controller with a new one if you want to solve this leakage problem.
Please take time to rate me
Mar 18, 2011 | Peerless Industries Peerless& Single...
When turning on the shower faucet there is no hot water.
Can you remove handle , behind handle there should be a dial to move to increase hot or cold supply.
Remember where you start and remove it and replace a 1/8 to 1/4 turn counter clockwise, just put handle on try it and see if it changes and adjust accordingly.
May 14, 2010 | Kohler K-T12007-4s-BV Brushed Bronze...
High pressure
Are you sure it's not just that the shower heads are getting dirty from calcium build up, thus reducing the diameter of the holes in the head, which will in turn cause spray to come out at higher pressure. ( same idea as holding your thumb over the end of a garden hose) Try removing and either replacing head, or soak it overnight in C.L.R (available at any hardware store.) and clean it good and try it again.
Apr 24, 2010 | Kohler K-T12007-4s-BV Brushed Bronze...
adjust ur anti scold the setting is set to low when single handle shower units are shipped they are set in cold mode for safety ur install/instructional paperwork explains such and also advises on how to adjust---remove handle and on shaft will see a blue and red plastic clips that are adjustable slide towards u and move red for more hot water test water continue till comfort level is reached for hot water
Mar 24, 2010 | Kohler K-T12007-4s-BV Brushed Bronze...
I I have a 3 way bath/shower/overhead shower mixer valve to fit and am not sure where the pipes should go, there is a hot and cold feed in, but only 2 feeds out, I need feeds for 1. bath filler, 2....
When installing a flexishower head, install it in front of the actual shower head with a diverter switch. If you try to operate two shower heads at once, you may suffer poor water pressure. There are handheld shower sets sold which are installed to existing shower assemblies with ease. Rememer to use plumber's tape and protect your stainless steel by wrapping you pliers teeth in electrical tape.
Jan 15, 2010 | Delta 3 Function Showerhead & Grail...
Kohler Fairfax shower faucet repair
You will need to buy the o-rings to fix it. You can buy at most hardware stores if you know how to turn off the water you can fix this with more instructions. Let me know if you need more help.
Sep 27, 2009 | Kohler Fairfax Single Control Lavatory...
Faucet issue
Sounds like it was installed upside down or the cartridge is installed improperly
May 06, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Water coming from showerhead and bath spout at same time
Have whoever installed the shower set come back and fix the diverter. It should be a relatively simple adjustment.
Mar 15, 2009 | Kohler Home
Kohler K-T12007-4s-BV Brushed Bronze Fairfax Single Handle RiteTemp Tub and Logo
308 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
