Question about Dell OptiPlex Computers & Internet
How do you wipe a Dell Optiplex GX520 clean from "Boot"?
I need a utility boot program that will wipe from the boot.
  • Dell Master
  • 32,281 Answers
Download and use this program
Wipe hard disks to prevent data recovery http://www.killdisk.com/
Posted on Jan 17, 2013
  • 326 Answers
SOURCE: Dell optiplex won't Boot-up.. Orange light on motherboard
its going to rather your power supply or your motherboard has died, id try a different power supply first
Posted on Aug 11, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Dell Optiplex GX280 boot problem
I just repaired two Gateway systems with similar behavior (turn on power, fan runs at full speed, no boot), and both needed replacement system boards. (These were a different model, but the symptoms are typical of a dead system board.) I got the boards from a company called Blue Raven Technology (www.blueraven.com).
Before deciding the main board is bad, try another power supply to make sure that's not the problem. Also you might try clearing the CMOS memory on the system board (either by moving a jumper usually found near the backup battery, or by removing the battery itself). Sometimes corrupted CMOS data will keep the system from booting.
Posted on Nov 16, 2008
ginko
  • 19396 Answers
SOURCE: Bios default password
The BIOS default password is just blank, and it is not asked.
When you set a bios password, you are asked to enter a value, therefore if bios is asking the password, the password had been changed.
To reset the bios password if you do not know the password you need to access to motherboard and temporarily remove battery for few seconds.
Removing battery will reset bios and delete the password.
Unplug power cord before accessing the motherboard, and try not touching the motherboard with your finger.
Put battery back in place before restarting computer.
See also the following websites:
technibble.com/..
satyathakur.com/blog/
Posted on Mar 04, 2009
  • 124 Answers
SOURCE: My Dell Optiplex GX520 will not boot. There is no
If 1 & 2 are off ... then you have problems.
Memory modules are detected, but a memory failure has occurred.
  • If you have one memory module installed, reinstall it and restart the computer. (see Memory for instructions on how to remove and install memory modules.)
  • If you have two or more memory modules installed, remove the modules, reinstall one module, and then restart the computer. If the computer starts normally, reinstall an additional module. Continue until you have identified a faulty module or reinstalled all modules without error.
  • If available, install properly working memory of the same type into your computer.
  • If the problem persists, contact Dell (see Contacting Dell).
According to Dell's notes:
Their remedies are:
Posted on Jun 17, 2009
dwane4444
  • 219 Answers
SOURCE: Dell Optiplex GX520 PC won't boot - power light at
OK the first step is to remove the side of the case and check that all the leads are firmly inplace. - If this does not fix it post a comment.
Posted on Nov 02, 2009
How to solve orange solid light on my dell GX520 when i boot it
Nana, A solid amber power button on your GX520, indicates a motherboard failure. The motherboard will need replaced. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Solid orange power button on Optiplex GX520
My Dell Optiplex GX520 will not boot Forums
Dell Optiplex GX520 amber solid light no power
Aug 05, 2016 | Dell Computers & Internet
How to change boot options to usb in dell optiplex gx520
Go into BIOS buy pushing F2 when the machine boots. Once in BIOS, look for boot options and make sure to select USB/External Drive is an option.
Alos, make sure that your current BIOS is able to boot via USB. May have to update your system BIOS
Oct 23, 2012 | Dell OptiPlex GX520 PC Desktop
Dell Optiplex gX520 will not boot beyond the splash screen. Dell Optiplex gX520 will not boot beyond the splash screen. There are not post code beeps.The lights on the front panel are 1 and 4. Both are...
Sounds like you may have multiple problems. Suggest trying to eliminate possible causes by removing components. Remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged. Remove the components one at a time and see if the LED's change.
Dec 10, 2011 | Dell Optiplex GX520 Desktop PC - Intel...
Cpu fan of dell desktop otiplex gx520 running faster than usual with a loud noise . How can I resolve it?
Either your fan is dirty or your fan is malfunctioning. If you have a warranty then call Dell to replace the fan (they will run some test first), or if you know how to replace the fan i would suggest that first.
Dell usually comes with a Diagnostic Disk that you can boot from to troubleshoot, if you do not have the disk then the built in Diagnostic Utility can help you. This will also help tell you if there is anything else wrong with the machine, the test takes long so be patient.
To get to the Diagnostics Utility follow these steps:
1. Reboot the computer and press "F12" and you will be taken to a "Boot Menu".
2. Select the Diagnostic Utility (might have a different name)
3. Walk through he steps to test your computer. This Utility will test everything that's why the disk is better. The disk will allow you to choose which test to run.
If you do not have the built in Diagnostic Utility and do not have the disk then visit the Dell website, choose support and type in your Service Tag number. Then download the utility, this site can also determine if you still have a warranty on the machine (but your GX520 is quite old and might be out of warranty)
Please rate if this helps
Mar 15, 2011 | Dell OptiPlex GX520 PC Desktop
Dell optiplex gx520 will not boot
There might be sevral reasons :
  1. Check proper boot device in BIOS
  2. Remove any USB or storage media
  3. Check If your OS was not corrupted.
  4. Try to boot it from any BOOTABLE CD..
Try al of the above step & let me know if we can troubleshoot it more
Please rate this, if you like solution
Thanks
Mar 09, 2011 | Dell OptiPlex GX520 PC Desktop
I have a dell Optiplex Gx520.When i put it on,the power button is a steady yellow clor and the PC will not boot up.Please help. Thanks, Farous.
here is the link that explains what these lights mean and how to resolve it. http://support.dell.com/support/edocs/systems/dim4700/sm/adtshoot.htm
Nov 04, 2010 | Dell OptiPlex GX520 PC Desktop
I have a dell gx520 running xp home . I want to dual boot ubuntu but the cd rom will not read from ubuntu disk. It readsxp and music cd's ok so it is not the rom at fault
Make sure you set the BIOS to boot on the CD rom first. You can set it via the BIOS utility. Usually you press the F5 key and then go to boot options. And then place your CD ROM drive on the 1st boot priority.
Make sure also that your CD installer is working and not from a bad ISO download.
May 25, 2010 | Dell OptiPlex GX520n PC Desktop
Dell Optiplex GX520 PC won't boot - power light at front just blinks
Nov 02, 2009 | Dell OptiPlex GX520 PC Desktop
My Dell Optiplex 745 "No Boot Device Available"
No boot device means that the computer cannot find a drive that has a operating system files and therefore cannot boot up.
This usually means that the hard drive in the computer is faulty.
You need to get a new hard drive and install Windows on the hard drive, together with the drivers for the computer's installed devices and programs to get a working computer.
Sep 06, 2009 | Dell OptiPlex GX520 PC Desktop
No Boot Device Optiplex 745
Open up the PC to see if there is a hard drive in the PC. If there is, then it has just been wiped and you'll need to reinstall your OS.
Apr 17, 2009 | Dell OptiPlex GX520 PC Desktop
Computers & Internet Logo
139 people viewed this question
Alun Cox
