Question about Conair Compact Garment Steamer Iron
Conair steamer leaks water and wets my clothes.
Everything seems to work fine, the steamer heats up perfectly. But when I go to use the hand held steamer adapter it leaks water and therefore soaks my clothes.
  • Anonymous Mar 27, 2009
    BUY NEW ONE
  • Anonymous Mar 31, 2014
    Brand new unit. Heats up but no steam comes out. Yes there is water in it.
When I use mine I hang the hand held part from my closet door, while I am waiting for it to heat up. When the hose gets too much condensation, from the steam, it leaks out... This will also happen if you try to use in the motion of an iron. The hand held part needs to be at a vertical position at all time to prevent leaking.
Posted on May 18, 2009
How to fix a leaking water out where you put the water in the iron
Strip the whole iron and inspect that water bottle you will see how you can close it or you can use it without putting water ucan wet the cloth first
Sep 12, 2014 | Conair Irons
Conair steamer green light comes on but low water beeps. water full.
How To Use The Conair® Deluxe Fabric Steamer
www.conair.com/how-to-use-the-conair-reg-deluxe-f...
Conair CorporationThe Conair® Deluxe Fabric Steamer (model # GS11DR) conveniently rolls to any spot in your ... This unit comes with a rotating hanger. ... The switch will light to indicate when power is on. ... Note: If the low water indicator lamp becomes illuminated but the water tank is not empty, follow the instructions for decalcification.
[PDF]Instruction Booklet - ExtremeSteam® Upright ... - Conair
www.conair.com/.../gs95_13pa140688_ib_final.pdf
Conair CorporationMar 1, 2013 - ... water only. 8. Plug the steamer unit into a standard 120V AC power outlet. 9. ... Push button on T-nozzle - light will go on and steam will start.
Customer Reviews: Conair Extreme Steam Fabric Steamer ...
Aug 16, 2013 | Irons
Conair GS33 fabric steamer spews too much water..can't be normal, eh?
Are you setting the body of the steamer on a table? If part of the hose sits lower than the steamer body steam will condense in the hose and collect in the low spot. Steam pressure will push the water out through the nozzle. If your steamer starts to sputter lift the hose so that it is completely above the level of the water reservoir and let the water drain down. Its a good idea to keep the steamer body on the floor so the hose can never get lower than it.
Feb 03, 2010 | Conair Irons
Hand steamer conair GS15R will not produce steam. It is on, it is full of water, the body gets warm, and it makes noises like it is steaming but nothing comes out.
Hi.
The iron steam lines may be clogged with limescale.
Try first using descaling solution to clean the lines.
Do descaling several times.
If that does not work, then the thermostat may have started malfunctioning and cutting off earlier than normal. This will cause water not getting enough temperature, and iron not steaming.
Try using a descaler product, often that can fix the problem.
Jan 14, 2010 | Conair Irons
How do you fill the water tank on the steamer conair model GS15RN?
FOR HOUSEHOLD USE ONLY
FILLING INSTRUCTIONS
1. Place the unit on a stable surface.
2. While holding the water tank with one
hand, move the release lever toward the
power cord.
3. With the reservoir released, pull up on
the reservoir to remove it from the body of
the unit.
4. Turn the reservoir over, revealing the rubber
inlet cover.
5. Open the inlet cover and fill the tank
with everyday tap water (filtered water may
reduce hard water problems).
6. Close the inlet cover and return the
reservoir to its place, making sure that the
reservoir is secure.
Hope this helps! Hal
Jun 04, 2009 | Conair Compact Garment Steamer Iron
Steam not working
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Nov 06, 2008 | Conair Compact Garment Steamer Iron
Conair steamer
Fill it with boiling hot mixture of half water half vinegar. Let it sit two hours. Rinse and repeat as necessary. Hope this helps you out.
George
Jul 03, 2008 | Conair Compact Garment Steamer Iron
Conair GS4 Steamer
faa3e02.jpgthis is from conair instructions included with steamer, finally found it, hope it helps some!
Oct 28, 2007 | Conair Gs4 Iron
Conair Compact Garment Steamer Iron Logo
1,969 people viewed this question
Top Conair Irons Experts
ashburton
Glenn Smart
Glenn Smart
Piyal Perera
Piyal Perera
Are you a Conair Iron Expert? Answer questions, earn points and help others
