Question about Food Mixers
Worn bowl lift nut on Hobart L800 mixer. - Food Mixers
  • 68 Answers
SOURCE: Hobart L800 Mixer Age & Bowl Question
The manufacter date is actually a two letter code on the data plate. But being the s/n is an "11", factory #11, it's old.
The key number for getting the right parts on a Hobart is the "ML" or "Spec" number. It is most always a five diget number.
As far as your actual problem -- I'm confused.
Posted on May 02, 2008
ricardok45
  • 135 Answers
SOURCE: Need oil/grease for Hobart 20 qt. mixer
Hi. Your A200 is in need of service. The grease's lifespan has expired. There are two ways of doing this. First, the expensive way. Call for a Hobart Tech to come and service the mixer. This will take about 4-5hrs to service at a rate around $100.00usd per hour, plus the cost of parts. He/she will need to change all seals, remove old grease and oil, check all bearings and gears for excessive wear and replace as necessary, this includes the planetary gear.
Now for the affordable solution. Unplug the mixer, remove the top cover. Gently use a small screwdriver to pry off the two circular metal dust caps found on the transmission housing, use a good flashlight to determine, through these openings, the quality, quantity and condition of the grease inside the transmission case. If there's a lot of oil you can remove much of it a bit at a time by using a wire coat hanger to which you can attach bits of cloth to absorb as much oil as you can. Once oil is removed, add new grease through these same holes until full (Chevron FM ALC EP-2, food grade lube). Run the mixer for a couple of minutes to distribute the new grease. Fill to the top once again and replace dust covers. Remove planetary, clean, inspect change seal and re-grease.
OPTION (mechanically challenging) You can do a more thorough job by removing the trans. cover completely, removing the 3 gear shafts inspect all bearings and gears, change seals on mainshaft and planetary. Remove old grease and oil, clean gearshafts and gears. Parts drawings are available from www.hobartservice.com It's free to register and then locate your parts drawings. Be sure that you have the correct files for your Model #, ML# if there is one and Spec.#, all found on the info plate.
When disassembling, take a digital photo of every step and lay the removed components on a piece of cardboard in the removed sequence. These practices will become valuable during re-assembly.
If this solution has assisted you, please rate it. ricardok45
Posted on Mar 20, 2009
  • 73 Answers
SOURCE: We have a hobart d300
https://feg.hobartcorp.com/resourcecenter/Discontinued%20Product%20Documentation/F3492.pdf
click link above for Owners Manual.
https://feg.hobartcorp.com/resourcecenter/Discontinued%20Product%20Documentation/F-3492-N.pdf
clink link above for parts Manual.
hope that helped
Posted on May 23, 2009
  • 20 Answers
SOURCE: Hobart L800 making noise
If you can send me your email address i can send you a parts catalog for your L800 They have no way to send a link here is my email address
onesharpstore@comcast.net
Posted on Jul 07, 2009
  • 109 Answers
SOURCE: Hobart Mixer bowl won't go up
If the worm screw is turning but not lifting the bowl, the bowl lift nut is stripped.
H600 part number is 24198.
To change it, you need to undo the screws down the right side yoke slide to release the yoke. You will need to lift the yoke to reach some of them. If you have some wood place it under the yoke and over the legs to protect the paint. On top of the yoke are two blots holding the keeper plate over the nut. One is the stop screw for bowl height. Don't loose this setting. remove the slide, edge the yoke forward a bit to free the worm. Run the old nut down the worm and off the bottom. When you run the new nut on, all the excess grease and metal shavings will start to build up. Clean as you go, or better still, brush with solvent or similar to clean the worm threads . relubricate, run the nut up above the yoke, reload the yoke and attach keeper plate, reload slide.
To adjust slide, snug screw near bottom keeping slide close to yoke, run yoke to top and tighten top screw just enough to hold slide in place, lower yoke to bottom, gently tap top of slide in a 1/16" and tighten top screw. Run yoke to top of slide. It should start to bind slightly in the last 2 inches of travel, which will stop the bowl from dropping in use. Tighten remaining screws.
Posted on Aug 08, 2009
What is the difference between a H800 and L800 mixer
I have used the H600. Nice piece of kitchen kit for hard use.
Model H600 is a heavy-duty 60-quart mixer which features a two-horsepower motor, a timer and a #12
Attachment Hub as standard equipment. With the use of bowl adapters and special agitators, 30- or 40-
quart bowls may be used on the H600.
Model L800 is a medium-duty 80-quart mixer designed primarily for use in general kitchen applications.
This mixer features a timer and #12 Attachment Hub as standard equipment and is powered by a
two-horsepower motor. With the use of bowl adapters and special agitators, 30-, 40- or 60- quart bowls
may be used on the L800.
A Bowl Guard is standard equipment on all H600 and L800 models.
A programmable timer controller is optional on H600 and L800 models.
These mixers can be ordered with a stainless steel finish.
A variety of attachments and accessories are available for all mixers. These are described in a separate Use and Applications Handbook, which is furnished with each mixer.
Here is your manual.
http://www.cvrsupply.com/manuals/hobart/Hobart_L800_Manual.pdf
May 07, 2016 | Food Mixers
RESET A HOBART 140 QT MIXER
The V-1401 has a power bowl lift that is belt driven by the same motor that is used to mix. Remove top cover to check the belt. If belt is good and not slipping, is the operator handle working on /in the bowl lift gear box? If not, could be broken shear pin on handle or worn out parts in gear box. Next thing to check is the output shaft of the bowl lift gear box. If it is turning when the operator handle is engaged and the bowl lift jack shaft is not turning there is a broken shear pin between the output shaft and jack shaft. If everything is good to this point the bowl lift yoke has a large brass nut on back side of it that the jack shaft goes through. If the nut is worn the bowl lift yoke will slip, fall and/or jam. to unstick and lower the bowl , one can turn the jack shaft by hand. WARNNING : if the nut is worn enough the yoke can drop suddenly and it is very heavy.
May 06, 2015 | Hobart 140 qt Mixer Model V-1401 Used Mint...
Hobart L800 will not stay on unless you hold start buuton
If it has a bowl guard on it then it could be the bowl height switch or the side switch on the contactor. If it does not have a bowl guard then it is more than likely the contactor side switch.Check www.hobartservice.com for your local Hobart office.
Mar 15, 2011 | Hobart D340-6007 Mixer
Hi, I have a used Hobart A200T and the bowl yoke piece moves up and down slightly, even under a light load. It makes an annoying clanking noise. It's as if a spring somewhere is looser than it should be....
You may be correct about a loose spring. Check this:
Carefully lay the mixer on its back side to access the bottom of the mixer. Remove the cover screen covering the opening in the bottom of the mixer. Using an extension and appropriate socket, be sure the nut of the bowl lift rod is snug, slightly compressing the spring of the bowl lift rod.
Jan 26, 2011 | Hobart A200 Stand Mixer
Bowl Lift Nut H 6001
At your local Hobart office.
www.hobartservice.com Click on "locate an office" and enter your zip.
Jul 30, 2010 | Hobart H600 Stand Mixer
Bowl lift on H660T will not raise bowl. The pinion gear turns the threaded rod, however; the screw just turns in the threaded block on the bowl yolk, without raising the bowl
The brass nut threads are worn.You have to remove the bowl yolk from the slides to get to the nut.I'm a hobart tech and repair these units often,any questions let me know----Tony.
Nov 23, 2009 | Hobart Food Mixers
Hobart HZ (h600?) Raising handle is acting up
You will need to confirm the model number. An H600 or L800 have a wheel to manually turn to raise and lower the bowl. The M802 and V1401 hav a belt driven bowl lift clutch, operated by a lever. When you push the lever up or down, you are engaging a small transmission between the motor and main housing. You would need to remove the top cover and see what's happenning. It may be there is something other than the proper spiral pin joining the lift lever to the clutch input shaft, giving alot of backlash and insufficient selector movement.
Aug 18, 2009 | Hobart H600 Stand Mixer
Feb 20, 2009 | Hobart N50 Stand Mixer
May 01, 2008 | Food Mixers
Food Mixers Logo
47 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
