Question about Hotpoint WMA66 Front Load Washer
Washing machine tripped electric, now not working at all...also leaking
As above. help needed asap
  • 67 Answers
Poss blown control board due to motor,heater,interlock or leak if under warranty call them in. There are too many possibilities to explain them all but alot of the time there are wires that rub on the concrete weight, tilt the machine back and look undernerth near the weight UNPLUG THE MACHINE before working on appliance, if the fault is there you could make good the wires
Posted on Jul 12, 2007
Washing machine keeps tripping electric when the door locks
Washing machine tripping or fusing electrics
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 26, 2013 - A Washing machine tripping or fusing electrics is a fault you can't really deal with unless ... If washer has tripped the RCD or fused the plug but now won't work properly. ... Here's an article on Washing Machine Door Will Not Open ... If youkeep resetting it without fixing the cause of the tripping it can blow ...
6 common washing machine problems and how to solve them
www.appliancesonlineblog.com.au/.../6-common-washing-machine-prob...
Feb 10, 2014 - As mentioned earlier, front loader doors lock during the cycle to prevent the water from ... The washing machine keeps tripping the power!
Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and ...
? 7:00
https://www.youtube.com/watch?v=dx2vCzO8828
Jun 13, 2013 - Uploaded by ApplianceVideo.com
Yeah, keep it ... Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and will not always run - .... TROUBLESHOOTING Top Loading Washing Machines in ... Maytag Neptune Door Locked but No Spin - R11 is not burnt ...
Washing Machine keeps tripping the electrics -
Dec 29, 2015 | Washing Machines
Hoover primera washing machine keeps tripping electrics when tured on.
Possible that there is higher current drain which trips off the circuit. This can be due to moisture or dampness in the circuit , coils or the motor. You need to remove the top panel and dry using a dryer. check the connectors, check the main line , the motor circuit. Isolation of the motor or the heater can confirm the short if the circuit stays. Check the main power to the panel and allied circuit for possible capacitor leak or short.
Mar 16, 2013 | Washing Machines
Why does my washing machine trip the electric
run the machine, after it trips, unplug and carefully touch the motor,it may have a bad capacitor, or dry bearings causing it to draw excessive current,if these 2 things are not it, then look for a bare wire that may be touching case during this part of the cycle,and if you can get an "Amprobe" it reads current and check machines current draw during the start to trip current
Oct 27, 2009 | Hotpoint WMA58 Front Load Washer
Hotpoint 9537 washing machine tripping electric
You have a problem with Live feed shorting to earth on a main component. You need to switch off machine and seek a qualified electrician ASAP
Sep 03, 2009 | Washing Machines
Keeps tripping the electric
A few possibilities here,if wash element is grounding in Kohms this will trpp breaker,disconnect element and see will electrics trip,burnt terminals is also possibility at any point in washer especially at feed connections,grounding drain pump or motor windings can also cause tripping,disconnect also and then check,damp spots around electrics can also indicate water leaking onto electric components.safety guidlines and procedures should always be followed when checking and repairing electrical equipment
May 03, 2009 | Indesit W 123 Front Load Washer
Washing machine keeps tripping electric switch
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
when the power trips you will need to know at what point in the wash this happens if its when the machine is emptying then it would be a pump issue if the machine is emptying no problem then the issue is more likely to be the motor either of which would need to be replaced if you are having these problems.
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys.. rest assured if the power is tripping off then your home electrics are working fine & to confirm all sockets run from 1 main fuse all lights run from a second main fuse then there is a few other bits that run on there on fuses too i.e. cooker, power shower etc.. remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Jan 16, 2008 | Washing Machines
Hotpoint Aquarius WD64 - Tripping the electric?!
something is going down to earth, start by unplugging the motor and retesting, if it doesn't trip them check the motor carbons etc, if it trips then check the heater element for contact down to earth, replace if needed etc, then check the outlet pump the same way if i have helped rate me please ps when working on machine remove from power supply
Oct 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WMA66 Front Load Washer Logo
61 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
