Question about Aprilaire 700 Humidifier
Aprilaire Model 700 - not achieving 40% humidity
I live in a Townhome - 1600 sq.ft built 13 yrs ago. 3 yrs ago I purchased the Model 700 with the automatic control and external temperature sensor. I live near Washington D.C where average temperatures in Jan and Feb is around 30-35 F. Very rarely it drops to 10 F - once or twice a year. I have alway been suspicous of the efficiency of the humidifier. I recently got an authorized dealer to make the control manual and change the water panel. They found the solenoid faulty and replaced it under warranty. I now get 1 quart of water from the drain in 2 and half minutes and this appears to meet the specification. I was hopeful that by keeping the control at 45% I would get 40% at the least but I never see readings better than 33% - with my Brookstone monitor and also matching the "click" on the Aprilaire humidistat. I have checked with the authorized contractor and they now say that this is the best I can get. I somehow am not convinced and was hoping to hear from other Model 700 owners if they have this problem and how they deal with it. I plan to also work with the Aprilaire regional manager but would like some more facts when I meet with him.
  • 2 more comments
  • dennissoans Jan 26, 2009
    After some research I now realize that my furnace is running under 50% of the time when external temperature is 31 F (dewpoint 10 F and RH 38%). Inside temperature is 70 F and RH 29%. I believe the Model 700 is rated for 35% RH at 70% run time. It appears on cold days - around 12-15 F it gives me around 33%. This appears to be as designed. The reason my furnace is running only 50% is probably due to the fact that I have closed the basement vents and 2 rooms on the upper level.
  • Anonymous Jan 28, 2009
    I too live near D.C in Loudoun Co. and just moved into a new home. The builder installed a Aprilaire Model 700 and I am not getting anything past 33%. I have a hot water line connected to the humidifier. I have called the installers and I don't think they know what the problem is. I am a musician and have lots of instruments in my home and need the R.H. to be at least 40-45%. I have tried running the fan but it has not worked. Please inform me if you find a solution.
  • dennissoans Jan 28, 2009
    Yes, I have tried running the fan but it makes no difference at all. I have hot water supply to the humidifier. The capacity specification for the Model 700 is 4000 sq. ft so I believe I am well within that limit. The real reason is that the furnace is not running above 70% as this area had mild temperatures and other factors (closing vents to reduce demand) which I have listed. I am now leaning towards the Honeywell Steam Humidifier which supplies moisture on demand and is not dependant on the furnace. I am reasearching the pros and cons of that system. The claim is that it uses less water also and can be installed remotely - does not have to be installed on the supply duct.
  • Anonymous Feb 23, 2009
    I have the same problem, I can't get it above 32% humidity. I believe the fan on the Aprilaire probably can't overcome the pressure inside my duct work and the moist air is blowing out of the humidifier. Check to see if your unit is drawing outside air by holding tissue paper up to the vents on the outside of the humidifier. If the tissue paper moves away from the humidifier then have your service people hook the control to the burner, at least you'll get some moisture into the house before the heater blower motor comes on. When it comes time to replace, I'll use the bypass model.
    Problem Solver:
  • 17 Answers
If it is set up right, you should be able to run your fan 100% of the time and the humidifier will come on when there is a need for humidity. you can experiment with leaving the fan on and see if this helps. it will run your electric bill up a little and also you will have a lot of waste water. that is a drawback to the bypass type humidifiers. also a factor is if the water supply is hooked up to the hot or cold side. it will humidify better on the hot side, but you tend to get more deposits that plug the solenoid over time and you will be running your water heater quite a bit. 1600 sqft may be pushing the limit of this humidifier.
Posted on Jan 27, 2009
Why does humidifier function shut off after 45 seconds?
bacause of the following reason
.Timing defrost by turning off:
When defrost sensor temperature defrost temperature (Parameter F2) and at the same time the defrost
interval time reaches the set value F3 then can enter to defrost, the fan will turn on, the compressor and
heater will turn off.
After worked a defrost interval time (Parameter F3) time, it will enter the stop mode automatically and
compressor will turn off.; after a defrost time(Parameter F1) will exit the defrost mode and enter to
automatic temperature control mode.
Mar 05, 2015 | Humidifiers
Replaced water panel and the light keeps blinking to change it agai...model 700
Sorry to read about your problem, I hope this helps you out.
did you hit the reset
Digital Humidifier Control (Model 700): (Automatic or Manual mode) Check system operation and reset Change Water Panel indicator by setting the knob to "Test/Reset". With HVAC blower operating and HVAC calling for heat, humidifier will operate for one minute. DO NOT LEAVE IN TEST MODE AS HUMIDIFIER WILL NOT OPERATE.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 29, 2010 | Aprilaire 700 Humidifier
I purchased a home with a aprilaire model 224. How do I know if its working?
Here is a link to the owners manual. http://www.aprilaire.com/themes/aa/en/manuals/Humidifiers_Owners_Manual.pdf
You can also pickup some cheap humidity gauges at a hardware store to check the settings on your unit verses the actual humidity in the house.
Dec 19, 2010 | Aprilaire Humidifiers
Aprilaire 700. It works on fan on mode but not otherwise. It's never on and the humidity reading is always way below the setting. It should turn on automatically to bring the humidity up, right?
It appears your Aprilaire model 700 is wired to only operate when your HVAC fan is operated by your thermostat. Your HVAC installer can wire the humidifier control to operate the humidifier during a heat call, fan call or to turn on the fan when there is a need for humidification. Please contact your HVAC installer to have them change the wiring.
Thank you for giving us the opportunity to be of service
Sincerely,
Brad Uselmann
Technical Support
Research Products Corporation
www.aprilaire.com
Nov 01, 2010 | Aprilaire 700 Humidifier
I have aprilaire 700 humidifier, running nonstop with fan on. and still cant get the humidity above 16%. 3000sq. ft. home
Hi check out the stat is working also check water line valve is not stuck open or there is some thing stuck on the seating
Feb 17, 2010 | Aprilaire 550 Humidifier
How difficult is it to change from manual to automatic mode on my model 700 humidifier?
Based on the information that I have found changing the humidifier from a manual setting to an automatic setting is somewhat easy. It will require you to remove the little blue resistor that is located at the humidistat on the two screws labeled odt and replace that with an outdoor temperature sensor part 8052 that needs to be ran to the outside of the home. Depending on your technical abilities you may be able to perform this procedure, but may need to get a contactor involved.
Feb 09, 2010 | Aprilaire 700 Humidifier
I have an Aprilaire 550 hooked up to my furnace,
in order for the humidifier to come on with the heater there has to be a temperature sense curuit to turn it on/off at a certain temp, the humidity curcuit on the unit will turn it off at set %
Jan 31, 2010 | Aprilaire 550 Humidifier
Instructions manual seems to imply that two 24 Vac (10VA) transformers are required if the HUM or ECA terminal is used to power the automatic digital control. HUM or ECA terminals are 120 volts. The...
No, you do not need another one. Wire everything just as you see it in the wiring schematics and you will only need the transformer supplied with the unit.
Heatman101
Jan 25, 2010 | Aprilaire 700 Humidifier
Aprilaire 700 Humidifier Logo
243 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
